[Geoserver-users] problems with geoserver trunk and 1.7.3 data directory
Hi Justin
Mea Culpa! I did say trunk but meant nightly build (from yesterday). Sorry about that.
Stefan
Von: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Gesendet am: Donnerstag, 26. März 2009 23:14
An: Ziegler Stefan
Cc: geoserver-users
Betreff: Re: AW: Re: [Geoserver-users] problems with
geoserver trunk and
Hi Stephan,
So you say you are running on trunk? I guess you are running
the legacy
module? Unfortunately the old web module on trunk right now is pretty
much broken… and only functions read only.
I just started up the legacy web module on trunk and it
started up ok.
But after shutting down and starting up again it does not start up
properly. I will look into it a bit deeper.
-Justin
Ziegler Stefan wrote:
sure:
PROJCS[“WGS84 / Simple Mercator”, GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
SPHEROID[“WGS_1984”, 6378137.0, 298.257223563]],
PRIMEM[“Greenwich”,
0.0], UNIT[“degree”, 0.017453292519943295],
PROJECTION[“Mercator_1SP_Google”],
PARAMETER[“latitude_of_origin”, 0.0],
PARAMETER[“central_meridian”, 0.0], PARAMETER[“scale_factor”, 1.0],
PARAMETER[“false_easting”, 0.0], PARAMETER[“false_northing”,
0.0],UNIT[“m”, 1.0], AXIS[“x”, EAST], AXIS[“y”, NORTH],
AUTHORITY[“EPSG”,“54004”]]
2009-03-26 10:39:32,450 WARN [geoserver.confg] - Error
occured loading
service: wms
2009-03-26 10:39:34,971 WARN
[support.DisposableBeanAdapter] - Couldn’t
find a destroy method named ‘destroy’ on bean with name
‘gwcDefaultStorageFinder’
2009-03-26 10:39:34,982 ERROR [context.ContextLoader] - Context
initialization failed
org.springframework.beans.factory.BeanCreationException:
Error creating
bean with name ‘wmsConfig’ defined in URL
[jar:file:/usr/local/apache-tomcat-5.5.25/webapps/geoserver-de
vel/WEB-INF/lib/wms-1.7.3-SNAPSHOT.jar!/applicationContext.xml]:
Instantiation of bean failed; nested exception is
org.springframework.beans.BeanInstantiationException: Could not
instantiate bean class [org.vfny.geoserver.config.WMSConfig]:
Constructor threw exception; nested exception is
java.lang.NullPointerException
at
org.springframework.beans.factory.support.ConstructorResolver.
autowireConstructor(ConstructorResolver.java:254)
at
org.springframework.beans.factory.support.AbstractAutowireCapa
bleBeanFactory.autowireConstructor(AbstractAutowireCapableBean
Factory.java:925)
at
bleBeanFactory.createBeanInstance(AbstractAutowireCapableBeanF
actory.java:835)
at
bleBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory
.java:440)
at
bleBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at
bleBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at
org.springframework.beans.factory.support.AbstractBeanFactory$
1.getObject(AbstractBeanFactory.java:264)
at
org.springframework.beans.factory.support.DefaultSingletonBean
Registry.getSingleton(DefaultSingletonBeanRegistry.java:221)
at
org.springframework.beans.factory.support.AbstractBeanFactory.
doGetBean(AbstractBeanFactory.java:261)
at
getBean(AbstractBeanFactory.java:185)
at
getBean(AbstractBeanFactory.java:164)
at
org.springframework.beans.factory.support.DefaultListableBeanF
actory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
at
org.springframework.context.support.AbstractApplicationContext
.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
at
.refresh(AbstractApplicationContext.java:381)
at
org.springframework.web.context.ContextLoader.createWebApplica
tionContext(ContextLoader.java:255)
at
org.springframework.web.context.ContextLoader.initWebApplicati
onContext(ContextLoader.java:199)
at
org.springframework.web.context.ContextLoaderListener.contextI
nitialized(ContextLoaderListener.java:45)
at
org.apache.catalina.core.StandardContext.listenerStart(Standar
dContext.java:3764)
at
org.apache.catalina.core.StandardContext.start(StandardContext
.java:4216)
at
org.apache.catalina.core.ContainerBase.addChildInternal(Contai
nerBase.java:760)
at
org.apache.catalina.core.ContainerBase.addChild(ContainerBase.
java:740)
at
org.apache.catalina.core.StandardHost.addChild(StandardHost.java:544)
at
org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:825)
at
org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:714)
at
org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:490)
at
org.apache.catalina.startup.HostConfig.start(HostConfig.java:1138)
at
org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConf
ig.java:311)
at
org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(L
ifecycleSupport.java:120)
at
org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1022)
at
org.apache.catalina.core.StandardHost.start(StandardHost.java:736)
at
org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1014)
at
org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
at
org.apache.catalina.core.StandardService.start(StandardService
.java:448)
at
org.apache.catalina.core.StandardServer.start(StandardServer.java:700)
at org.apache.catalina.startup.Catalina.start(Catalina.java:552)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:295)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:433)
Caused by:
not instantiate bean class [org.vfny.geoserver.config.WMSConfig]:
at
org.springframework.beans.BeanUtils.instantiateClass(BeanUtils
.java:115)
at
org.springframework.beans.factory.support.SimpleInstantiationS
trategy.instantiate(SimpleInstantiationStrategy.java:87)
at
autowireConstructor(ConstructorResolver.java:248)
… 41 more
Caused by: java.lang.NullPointerException
at org.vfny.geoserver.global.Service.toDTO(Service.java:177)
at org.vfny.geoserver.global.WMS.toDTO(WMS.java:285)
at org.vfny.geoserver.config.WMSConfig.(WMSConfig.java:144)
at
sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at
sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unkn
own Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at
.java:100)
… 43 more
2009-03-26 10:39:34,984 ERROR [[localhost].[/geoserver-devel]] -
Exception sending context initialized event to listener
instanceof class
Error creating
at
at
Factory.java:925)
at
actory.java:835)
at
.java:440)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
dContext.java:3764)
at
.java:4216)
at
nerBase.java:760)
at
java:740)
at
at
at
at
at
at
ig.java:311)
at
at
at
at
at
at
.java:448)
at
Caused by:
at
.java:115)
at
at
… 41 more
at
at
at
own Source)
at
.java:100)
… 43 more
Stefan
Gesendet am: Donnerstag, 26. März 2009 16:30
An: Ziegler Stefan
Cc: geoserver-users
Betreff: Re: [Geoserver-users] problems with geoserver
trunk and 1.7.3
data directory
Hi Stefan,
Can you include the entire stack trace from the log. The
one below is
cut off and we are unable to tell where the error is
occurring. Thanks.
-Justin
Hi
I’m running into problems with todays trunk version and
with an existing
data directory which worked with GS 1.7.3.
catalina.out:
WARNUNG: Native library load
failed.java.lang.UnsatisfiedLinkError: no
gdaljni in java.library.path
26.03.2009 10:39:34
org.apache.catalina.core.StandardContext start
SCHWERWIEGEND: Error listenerStart
26.03.2009 10:39:34
SCHWERWIEGEND: Context [/geoserver-devel] startup failed
due to previous
errors
26.03.2009 10:39:35
org.apache.catalina.startup.HostConfig deployWAR
geoserver.log:
occured loading
service: wms
Error creating
at
at
Factory.java:925)
Any hints why this happens and what the errors exactly mean are
appreciated!
regards
Stefan
Mit freundlichem Gruss
Stefan Ziegler
Leiter Aufsicht
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon 032 627 75 96
Telefax 032 627 75 98
stefan.ziegler@anonymised.com
http://www.so.ch
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Justin Deoliveira
