[Geoserver-users] problems with geoserver trunk and 1.7.3 data directory
Hi Justin
can I send you the download link for the data directory to your private email account?
I think the problem is the “Grundbuchplan” layer group. If you replace the specific sld with “default_polygon” it works smoothly.
regards
Stefan
Von: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Gesendet am: Dienstag, 31. März 2009 01:35
An: Ziegler Stefan
Cc: geoserver-users
Betreff: Re: AW: AW: Re: [Geoserver-users] problems with
geoserver trunk
Hi Stefan,
Interesting. I recently fixed an issue surrounding layer groups, with
regard to spaces and commas. It could be that is causing you an issue.
Would it be possible to share the data directory you are
working against
so I can test locally? If you don’t want to share all the
data in it no
problem, just cut it down to something that reproduces the
problem and
share that.
-Justin
Ziegler Stefan wrote:
Hi Justin
I still have major problems using a nightly build with an
existing data
directory. I think I was able to track it down to WMS base
layer groups:
a) I can define a layer group with several wms layers
without styles →
works fine.
b) layer group with same layers and each with
“default_polygon” style →
works fine.
c) layer group with same layers and some homemade slds. And
now it gets
strange: I can apply and save in GS user interface.
Restarting GeoServer
ends with this error:
30 Mrz 10:50:17 INFO [geoserver.wms] - Processed layer group
‘Liegenschaften_projektiert’
group ‘Grundbuchplan’
30 Mrz 10:50:17 WARN [geoserver.confg] - Error occured
loading service: wms
30 Mrz 10:50:17 INFO [geoserver.confg] -
java.lang.IllegalArgumentException: Layer group has
different number of
styles than layers
at
org.geoserver.catalog.impl.CatalogImpl.validate(CatalogImpl.java:705)
at org.geoserver.catalog.impl.CatalogImpl.add(CatalogImpl.java:683)
at org.geoserver.wms.WMSLoader.load(WMSLoader.java:151)
at
org.geoserver.config.util.LegacyServiceLoader.load(LegacyServi
ceLoader.java:45)
at
org.geoserver.config.util.LegacyConfigurationImporter.imprt(Le
gacyConfigurationImporter.java:160)
at
org.geoserver.config.GeoServerLoader.initialize(GeoServerLoade
r.java:131)
at
org.geoserver.config.GeoServerLoader.postProcessBeforeInitiali
zation(GeoServerLoader.java:81)
at
org.springframework.beans.factory.support.AbstractAutowireCapa
bleBeanFactory.applyBeanPostProcessorsBeforeInitialization(Abs
tractAutowireCapableBeanFactory.java:350)
at
bleBeanFactory.initializeBean(AbstractAutowireCapableBeanFacto
ry.java:1330)
at
bleBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory
.java:473)
at
bleBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at
bleBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at
org.springframework.beans.factory.support.AbstractBeanFactory$
1.getObject(AbstractBeanFactory.java:264)
at
org.springframework.beans.factory.support.DefaultSingletonBean
Registry.getSingleton(DefaultSingletonBeanRegistry.java:221)
at
org.springframework.beans.factory.support.AbstractBeanFactory.
doGetBean(AbstractBeanFactory.java:261)
at
getBean(AbstractBeanFactory.java:185)
at
getBean(AbstractBeanFactory.java:164)
at
org.springframework.beans.factory.support.BeanDefinitionValueR
esolver.resolveReference(BeanDefinitionValueResolver.java:269)
at
esolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
at
org.springframework.beans.factory.support.ConstructorResolver.
resolveConstructorArguments(ConstructorResolver.java:495)
at
autowireConstructor(ConstructorResolver.java:162)
at
bleBeanFactory.autowireConstructor(AbstractAutowireCapableBean
Factory.java:925)
at
bleBeanFactory.createBeanInstance(AbstractAutowireCapableBeanF
actory.java:835)
at
.java:440)
at
at
at
at
at
at
at
at
at
at
at
at
Factory.java:925)
at
actory.java:835)
at
.java:440)
at
at
at
at
at
at
at
at
org.springframework.beans.factory.support.DefaultListableBeanF
actory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
at
org.springframework.context.support.AbstractApplicationContext
.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
at
.refresh(AbstractApplicationContext.java:381)
at
org.springframework.web.context.ContextLoader.createWebApplica
tionContext(ContextLoader.java:255)
at
org.springframework.web.context.ContextLoader.initWebApplicati
onContext(ContextLoader.java:199)
at
org.springframework.web.context.ContextLoaderListener.contextI
nitialized(ContextLoaderListener.java:45)
at
org.apache.catalina.core.StandardContext.listenerStart(Standar
dContext.java:3764)
at
org.apache.catalina.core.StandardContext.start(StandardContext
.java:4216)
at
org.apache.catalina.core.ContainerBase.addChildInternal(Contai
nerBase.java:760)
at
org.apache.catalina.core.ContainerBase.addChild(ContainerBase.
java:740)
at
org.apache.catalina.core.StandardHost.addChild(StandardHost.java:544)
at
org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:825)
at
org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:714)
at
org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:490)
at
org.apache.catalina.startup.HostConfig.start(HostConfig.java:1138)
at
org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConf
ig.java:311)
at
org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(L
ifecycleSupport.java:120)
at
org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1022)
at
org.apache.catalina.core.StandardHost.start(StandardHost.java:736)
at
org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1014)
at
org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
at
org.apache.catalina.core.StandardService.start(StandardService
.java:448)
at
org.apache.catalina.core.StandardServer.start(StandardServer.java:700)
at org.apache.catalina.startup.Catalina.start(Catalina.java:552)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:295)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:433)
30 Mrz 10:50:17 INFO [util.ApplicationContextProvider] - No context
parameter, system or Java environment variables found for
GEOSERVER_WMS_URL
By inserting an coma in the layer definition inservice.xml
(sogis:kva_av_bdbed,sogis:kva_av_eopoly</baseM
apLayers>)
I’m able to restart GeoServer but after restarting the
layer definition
disappeared from service.xml…
regards
Stefan
Justin Deoliveira
OpenGeo - http://opengeo.org
