[Geoserver-users] Problems with Geoserver
Hi all, I make a war with my Geoserver’s installation and I try to deploy in other computer. I change the catalog.xml with new values to mysql connection in the new pc, and generate this error:
03 jul 14:48:53 WARN [geoserver.securit] - Rule ..r=* is overriding another rule targetting the same resource
03 jul 14:48:53 WARN [geoserver.securit] - Rule ..w=* is overriding another rule targetting the same resource
03 jul 14:48:53 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown…
03 jul 14:48:53 INFO [geoserver.global] - Done disposing datastores.
03 jul 14:48:53 INFO [geoserver.catalog] - Disposing datastore ‘osmius’
03 jul 14:48:53 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.
factory.BeanCreationException: Error creating bean with name ‘gwcMetaStore’ defined in URL [jar:file:/usr/local/tools/apache-tomcat-5.5.25/webapps/geoserver/WEB-INF/lib/gwc-1.7.5.jar!/applicationContext.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.geowebcache.storage.metastore.jdbc.JDBCMetaBackend]: Constructor threw exception; nested exception is java.lang.OutOfMemoryError: Java heap space
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:254)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:3764)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4216)
at org.apache.catalina.manager.ManagerServlet.start(ManagerServlet.java:1173)
at org.apache.catalina.manager.HTMLManagerServlet.start(HTMLManagerServlet.java:545)
at org.apache.catalina.manager.HTMLManagerServlet.doGet(HTMLManagerServlet.java:105)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:525)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:151)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:874)
at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:665)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:528)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:81)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:689)
at java.lang.Thread.run(Thread.java:595)
Caused by: org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.geowebcache.storage.metastore.jdbc.JDBCMetaBackend]: Constructor threw exception; nested exception is java.lang.OutOfMemoryError: Java heap space
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:115)
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:87)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:248)
… 39 more
Caused by: java.lang.OutOfMemoryError: Java heap space
at org.h2.command.CommandRemote.prepare(CommandRemote.java:82)
at org.h2.command.CommandRemote.(CommandRemote.java:48)
at org.h2.engine.SessionRemote.prepareCommand(SessionRemote.java:420)
at org.h2.jdbc.JdbcConnection.prepareCommand(JdbcConnection.java:1049)
at org.h2.jdbc.JdbcConnection.rollbackInternal(JdbcConnection.java:1304)
at org.h2.jdbc.JdbcConnection.closeConnection(JdbcConnection.java:311)
at org.h2.jdbc.JdbcConnection.close(JdbcConnection.java:287)
at org.geowebcache.storage.metastore.jdbc.JDBCMBWrapper.checkTables(JDBCMBWrapper.java:173)
at org.geowebcache.storage.metastore.jdbc.JDBCMBWrapper.(JDBCMBWrapper.java:131)
at org.geowebcache.storage.metastore.jdbc.JDBCMetaBackend.(JDBCMetaBackend.java:71)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:494)
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:100)
03 jul 14:48:53 ERROR [[localhost].[/geoserver]] - Excepción enviando evento inicializado de contexto a instancia de escuchador de clase org.springframework.web.context.ContextLoaderListener
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘gwcMetaStore’ defined in URL [jar:file:/usr/local/tools/apache-tomcat-5.5.25/webapps/geoserver/WEB-INF/lib/gwc-1.7.5.jar!/applicationContext.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.geowebcache.storage.metastore.jdbc.JDBCMetaBackend]: Constructor threw exception; nested exception is java.lang.OutOfMemoryError: Java heap space
… 39 more
03-jul-2009 14:48:53 org.apache.catalina.core.StandardContext start
GRAVE: Error listenerStart
GRAVE: Falló en arranque del Contexto [/geoserver] debido a errores previos
Do you know wich is the problem??.
Thanks to all.
michogar
Analista Programador SIG
GNU/Linux Counter 462666
http://www.openstreetmap.org/user/michogar
Una visión personal:
http://michogar.blogspot.com
El día a día:
http://twitter.com/michogar
Seems to be an issue with geowebcache. Arne can hopefully provide more information.
For the time being, if you are not using geowebcache as a workaround you can simply remove gwc-*.jar from geoserver/WEB-INF/lib and it should fix the problem.
-Justin
Micho Gar wrote:
Hi all, I make a war with my Geoserver's installation and I try to deploy in other computer. I change the catalog.xml with new values to mysql connection in the new pc, and generate this error:
03 jul 14:48:53 WARN [geoserver.securit] - Rule *.*.r=* is overriding another rule targetting the same resource
03 jul 14:48:53 WARN [geoserver.securit] - Rule *.*.w=* is overriding another rule targetting the same resource
03 jul 14:48:53 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
03 jul 14:48:53 INFO [geoserver.catalog] - Disposing datastore 'osmius'
factory.BeanCreationException: Error creating bean with name 'gwcMetaStore' defined in URL [jar:file:/usr/local/tools/apache-tomcat-5.5.25/webapps/geoserver/WEB-INF/lib/gwc-1.7.5.jar!/applicationContext.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.geowebcache.storage.metastore.jdbc.JDBCMetaBackend]: Constructor threw exception; nested exception is java.lang.OutOfMemoryError: Java heap space
        ... 39 more
        at org.h2.command.CommandRemote.<init>(CommandRemote.java:48)
        at org.geowebcache.storage.metastore.jdbc.JDBCMBWrapper.<init>(JDBCMBWrapper.java:131)
        at org.geowebcache.storage.metastore.jdbc.JDBCMetaBackend.<init>(JDBCMetaBackend.java:71)
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'gwcMetaStore' defined in URL [jar:file:/usr/local/tools/apache-tomcat-5.5.25/webapps/geoserver/WEB-INF/lib/gwc-1.7.5.jar!/applicationContext.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.geowebcache.storage.metastore.jdbc.JDBCMetaBackend]: Constructor threw exception; nested exception is java.lang.OutOfMemoryError: Java heap space
        ... 39 more
Thanks to all.
# michogar
# Analista Programador SIG
# GNU/Linux Counter 462666
# http://www.openstreetmap.org/user/michogar
El día a día:
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
