Running GeoServer 1.7.0, JVM 1.7 using the bundled Jetty webserver on a Windows x64 platform.
I am having problems with managing ImageMosaic coverage stores via the REST interface.
When I delete an ImageMosaic coverage store via REST with the purge=all or purge=metadata option set the following exception is thrown (full stack trace at the bottom of mail):
Caused by: java.lang.UnsupportedOperationException: Schema removal not supported
at org.geotools.data.store.ContentDataStore.removeSchema(ContentDataStore.java:737)
at org.geotools.gce.imagemosaic.catalog.GTDataStoreGranuleCatalog.removeType(GTDataStoreGranuleCatalog.java:573)
at org.geotools.gce.imagemosaic.catalog.CachingDataStoreGranuleCatalog.removeType(CachingDataStoreGranuleCatalog.java:257)
at org.geotools.gce.imagemosaic.RasterManager.removeStore(RasterManager.java:1297)
at org.geotools.gce.imagemosaic.ImageMosaicReader.removeCoverage(ImageMosaicReader.java:1139)
at org.geotools.gce.imagemosaic.ImageMosaicReader.delete(ImageMosaicReader.java:1288)
at org.geoserver.catalog.CoverageDimensionCustomizerReader$CoverageDimensionCustomizerStructuredReader.delete(CoverageDimensionCustomizerReader.java:122)
at org.geoserver.catalog.rest.CoverageStoreResource.delete(CoverageStoreResource.java:139)
at org.geoserver.catalog.rest.CoverageStoreResource.handleObjectDelete(CoverageStoreResource.java:120)
at org.geoserver.rest.ReflectiveResource.handleDelete(ReflectiveResource.java:225)
It seems that the support files generated by ImageMosaic, especially the .properties file, are not deleted.
This has the consequence that if I try to generate a new ImageMosaic coverage store with the same name and uploading the same data, the image mosaic is not properly generated, and when trying to access the layer in the coverage store from a WMS client, the GeoServer does not produce any output.
I have to delete the .properties file manually in order to be able to re-generate the ImageMosaic coverage store.
Is this the expected behaviour of an ImageMosaic coverage store? If so, is there a way to circumvent this behaviour, that enables me to re-generate a deleted coverage store using the same name and uploading the same data?
Best Regards
Morten
Full stack trace:
74393199 [btpool0-5] ERROR org.geoserver.rest -
org.geoserver.rest.RestletException: java.lang.UnsupportedOperationException: Schema removal not supported
at org.geoserver.rest.ReflectiveResource.handleException(ReflectiveResource.java:326)
at org.geoserver.rest.ReflectiveResource.handleDelete(ReflectiveResource.java:228)
at org.restlet.Finder.handle(Finder.java:300)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:205)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:87)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doDelete(FrameworkServlet.java:811)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:733)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:201)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:76)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
… 84 more
