Hello,
After upgrading to Geoserver 1.7.3 and now using OracleNG from 1.6.3 with Oracle-Datastore, I get an error when rendering the WMS and during GetFeatureInfo.
I can see the FeatureType defined correctly.
The demo map displays an empty map and on GetFeatureInfo I get an exception:
java.lang.RuntimeException: java.io.IOException: Error occured calculating count java.io.IOException: Error occured calculating count Error occured calculating count ORA-29902: Fehler bei der Ausf�hrung von Routine ODCIIndexStart() ORA-13208: Interner Fehler beim Auswerten von Operator [window SRID does not match layer SRID] ORA-06512: in "MDSYS.SDO_INDEX_METHOD_10I", Zeile 286
I attached the full stacktrace.
I also attached the commands to create the table and index on my Oracle 10g (version 10.2.0.1.0).
I also noticed that the featureType configuration does not display a Native CRS WKT (just "-").
Is there a know issue/bug?
As you can see I do not use WGS84, but EPSG:31285
And as mentioned above, I got a preview map with the old Oracle datastore. It's not possible to use the old datastore, because it offers no support for NVARCHAR2-fields.
Best regards,
Bernhard Kiselka
PRISMA solutions
Bernhard Kiselka
Telefon: +43 2236 47975 25
E-Mail: bernhard.kiselka@anonymised.com
PRISMA solutions EDV-Dienstleistungen GmbH
Adresse: Klostergasse 18, 2340 Mödling, Austria
http://www.prisma-solutions.at
20090320_geoserver_oracle_connectiontest_script.txt (1.49 KB)
20090320_geoserver_oracle_connectiontest_stacktrace.txt (16 KB)
