[Geoserver-users] Problems with proxy.cgi on Mac OS X Server
Hello,
I have a problem with requests sent from proxy.cgi on OS X Server 10.5. When I run this
var kml =new OpenLayers.Layer.GML(“KML funnsted”, “http://borchbio.no:8080/geoserver/wms?bbox=583491.5599999999,6544090.26,666894.4400000001,6637003.74&styles=&request=GetMap&version=1.1.1&layers=kulturminner_ns:funnsted&width=544&height=550&srs=EPSG:32632&Format=kml”,
{projection: new OpenLayers.Projection(“EPSG:4326”),
format: OpenLayers.Format.KML,
formatOptions: {
extractStyles: true,
extractAttributes: true
against proxy.cgi on Ubuntu and Apache 2.2.8 I see that the cgi sends this:
Content Type: application/vnd.google-earth.kml+xml
Now this request goes to my OS X Server. When I use proxy.cgi on my server I see this in FireBug:
Content Type: application/vnd.ogc.se_xml;charset=UTF-8
I have checked all MIME types on the OS X Server and they are correct so if I could get the correct header request type it would handle it I guess but why does the CGI send this on OS X? Do I have to configure my proxy.cgi for OS X?
Any suggestions? Btw. If I run this URL directly in my browser (without proxy) I get a valid Google Earth file.
/asle
Just to bump this. Anyone out there using GeoServer on OS X?
/asle
2009/3/31 Asle Benoni <asle.benoni@anonymised.com>
Hello,
formatOptions: {
/asle
Hi Asle,
Yes, I develop on Mac OS. I have successfully set up a proxy for openlayers in the past with no issues. Are you using the one straight from the OpenLayers repo in the examples directory?
And I assume you are setting the OpenLayers.ProxyHost?
/asle
2009/3/31 Asle Benoni <asle.benoni@anonymised.com <mailto:asle.benoni@anonymised.com>>
    Hello,
    var kml =new OpenLayers.Layer.GML("KML funnsted",
    "http://borchbio.no:8080/geoserver/wms?bbox=583491.5599999999,6544090.26,666894.4400000001,6637003.74&styles=&request=GetMap&version=1.1.1&layers=kulturminner_ns:funnsted&width=544&height=550&srs=EPSG:32632&Format=kml
    <http://borchbio.no:8080/geoserver/wms?bbox=583491.5599999999,6544090.26,666894.4400000001,6637003.74&styles=&request=GetMap&version=1.1.1&layers=kulturminner_ns:funnsted&width=544&height=550&srs=EPSG:32632&Format=kml&gt;&quot;,
                  {projection: new OpenLayers.Projection("EPSG:4326"),
                   formatOptions: {
    sends this:
    *Content Type: application/vnd.google-earth.kml+xml*
    *Content Type: application/vnd.ogc.se_xml;charset=UTF-8*
    /asle
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Thanks.
Yes, I copied the recent one from OpenLayers and set this just after function init();
OpenLayers.ProxyHost = “/cgi-bin/proxy.cgi?url=”;
What OSX version do you have? Could you try to request this URL from your proxy.cgi and tell me if it works or if not if you are getting the same ContentType?
/asle
2009/4/1 Justin Deoliveira <jdeolive@anonymised.com.>
Hi Asle,
/asle
2009/3/31 Asle Benoni <asle.benoni@anonymised.com mailto:[asle.benoni@anonymised.com](mailto:asle.benoni@...84...)>
Hello,
<http://borchbio.no:8080/geoserver/wms?bbox=583491.5599999999,6544090.26,666894.4400000001,6637003.74&styles=&request=GetMap&version=1.1.1&layers=kulturminner_ns:funnsted&width=544&height=550&srs=EPSG:32632&Format=kml>”,
formatOptions: {
sends this:
/asle
Justin Deoliveira
Hi Asle,
I tried it out and it works fine for me, but i had to modify the proxy.cgi script to add borchio.no to the allowed hosts to proxy.
I am running Leopard (10.5.6).
-Justin
Asle Benoni wrote:
Thanks.
OpenLayers.ProxyHost = "/cgi-bin/proxy.cgi?url=";
/asle
2009/4/1 Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>>
    Hi Asle,
        /asle
        <mailto:asle.benoni@anonymised.com> <mailto:asle.benoni@anonymised.com
        <mailto:asle.benoni@anonymised.com>>>
           Hello,
        <http://borchbio.no:8080/geoserver/wms?bbox=583491.5599999999,6544090.26,666894.4400000001,6637003.74&styles=&request=GetMap&version=1.1.1&layers=kulturminner_ns:funnsted&width=544&height=550&srs=EPSG:32632&Format=kml&gt;&gt;&quot;,
                         {projection: new
                          formatOptions: {
           sends this:
        on my
        would
        I have
           /asle
        <mailto:Geoserver-users@lists.sourceforge.net>
    -- Justin Deoliveira
Justin Deoliveira
Do you have FireBug? Can you check what ContentType is sent? What version is your Apache?
I am trying to pin this down. I have added the domain, else I would get a “not allowed domain…” The attached screenshot is my proxy.cgi.
/asle
2009/4/2 Justin Deoliveira <jdeolive@anonymised.com.>
Hi Asle,
-Justin
Asle Benoni wrote:
Thanks.
/asle
2009/4/1 Justin Deoliveira <jdeolive@anonymised.com mailto:[jdeolive@anonymised.com](mailto:jdeolive@...1671...)>
Hi Asle,
/asle
mailto:[asle.benoni@anonymised.com](mailto:asle.benoni@anonymised.com) <mailto:asle.benoni@anonymised.com
mailto:[asle.benoni@anonymised.com](mailto:asle.benoni@anonymised.com)>>
Hello,
<http://borchbio.no:8080/geoserver/wms?bbox=583491.5599999999,6544090.26,666894.4400000001,6637003.74&styles=&request=GetMap&version=1.1.1&layers=kulturminner_ns:funnsted&width=544&height=550&srs=EPSG:32632&Format=kml>>”,
{projection: new
formatOptions: {
sends this:
on my
would
I have
/asle
mailto:[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@anonymised.comrge.net)
– Justin Deoliveira
Justin Deoliveira
Hi Asle,
Here is the info from FireBug:
Response Headers
Date: Mon, 06 Apr 2009 03:48:20 GMT
Server: Apache/2.2.9 (Unix) mod_ssl/2.2.9 OpenSSL/0.9.7l DAV/2
Keep-Alive: timeout=5, max=95
Connection: Keep-Alive
Transfer-Encoding: chunked
Content-Type: application/vnd.google-earth.kml+xml
Request Headers
Host: localhost
User-Agent: Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10.5; en-US; rv:1.9.0.8) Gecko/2009032608 Firefox/3.0.8
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Language: en-us,en;q=0.5
Accept-Encoding: gzip,deflate
Accept-Charset: ISO-8859-1,utf-8;q=0.7,*;q=0.7
Keep-Alive: 300
Connection: keep-alive
Referer: http://localhost/~jdeolive/asle.html
Response:
<kml xmlns="http://www.opengis.net/kml/2.2&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi
:schemaLocation="http://www.opengis.net/kml/2.2 http://schemas.opengis.net/kml/2.2.0/ogckml22.xsd&quot;&gt;
    <Document xmlns:atom="http://purl.org/atom/ns#&quot;&gt;
       <name>kulturminner_ns:funnsted</name>
       <Placemark id="funnsted.nfm-3907eb51_1206c4108d4_47f9">
          <name><![CDATA[<div style="font:11px tahoma,sans-serif;color:red;font-weight:bold">Spydslaug
  ,i matr Spjøslag (Funnsted)</div>
]]></name>
          <description><![CDATA[<div style="font:12px tahoma; color:teal;">
Kommune: <b>Rakkestad</b><br/>
Link til <a href="http://naturkart/no/Kulturminnekart/PDF/49158.pdf&quot; target="_blank">PDF ark</a><br/
Tjenesten baserer seg p&aring; OpenLayers<br/>
<a href="http://openlayers.org" target="_blank"><img src="http://www.charcoaldesign.co.uk/images/weblog
.openlayers.png" border="0" alt="/></a>
</div>]]></description>
          <LookAt>
             <longitude>11.265374540874582</longitude>
             <latitude>59.38922243285316</latitude>
             <heading>10.0</heading>
             <tilt>10.0</tilt>
             <range>700</range>
          </LookAt>
          <Style>
             <IconStyle>
                <color>ffffffff</color>
                <colorMode>normal</colorMode>
                <Icon>
<href>http://maps.google.com/mapfiles/kml/pal4/icon25.png&lt;/href&gt;
                </Icon>
             </IconStyle>
             <LabelStyle>
                <color>00ffffff</color>
             </LabelStyle>
          </Style>
          <Point>
             <coordinates>11.265374540874582,59.38922243285316</coordinates>
          </Point>
       </Placemark>
I am trying to pin this down. I have added the domain, else I would get a "not allowed domain..." The attached screenshot is my proxy.cgi.
/asle
2009/4/2 Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>>
    Hi Asle,
    proxy.cgi script to add borchio.no <http://borchio.no> to the
    -Justin
    Asle Benoni wrote:
        Thanks.
        /asle
        <mailto:jdeolive@anonymised.com> <mailto:jdeolive@anonymised.com
        <mailto:jdeolive@anonymised.com>>>
           Hi Asle,
               /asle
        <mailto:asle.benoni@anonymised.com>> <mailto:asle.benoni@anonymised.com
        <mailto:asle.benoni@anonymised.com>>>>
                  Hello,
        OS X Server
        <http://borchbio.no:8080/geoserver/wms?bbox=583491.5599999999,6544090.26,666894.4400000001,6637003.74&styles=&request=GetMap&version=1.1.1&layers=kulturminner_ns:funnsted&width=544&height=550&srs=EPSG:32632&Format=kml&gt;&gt;&gt;&quot;,
                                {projection: new
                                 formatOptions: {
        that the cgi
                  sends this:
        proxy.cgi
               on my
        they are
        type it
               would
        X? Do
               I have
        browser
                  /asle
        <mailto:Geoserver-users@lists.sourceforge.net>>
Justin Deoliveira
I am back to this problem again. I am not able to use KML request to my OS X Server when I use proxy.cgi. If I put this on any other linux server it works fine. It is definetely the Apache on OS X Server.
From Firebug I see these response headers (attached image):
Content-Type application/vnd.ogc.se_xml;charset=UTF-8
There is the problem. On any other linux server the proxy.cgi sends the correct header:
Content-Type application/vnd.google-earth.kml+xml
Have you or anyone every encountered this and how to fix it? I am desperate since I cannot use KML width geoserver on this server.
/asle
2009/4/6 Justin Deoliveira <jdeolive@anonymised.com>
  • Vis sitert tekst -
Hi Asle,
Response Headers
Request Headers
Host: localhost
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,/;q=0.8
Keep-Alive: 300
Response:
<![CDATA[
Spydslaug ,i matr Spjøslag (Funnsted)
<![CDATA[
Kommune: Rakkestad
Link til PDF ark<br/
Tjenesten baserer seg på OpenLayers
<img src=“http://www.charcoaldesign.co.uk/images/weblog
.openlayers.png” border=“0” alt="/>
]]> 11.265374540874582 59.38922243285316 10.0 10.0 700 ffffffff normal
00ffffff
/asle
2009/4/2 Justin Deoliveira <jdeolive@anonymised.com mailto:[jdeolive@anonymised.com](mailto:jdeolive@...1671...)>
Hi Asle,
-Justin
Asle Benoni wrote:
Thanks.
/asle
mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com) <mailto:jdeolive@anonymised.com
mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)>>
Hi Asle,
/asle
mailto:[asle.benoni@anonymised.com](mailto:asle.benoni@anonymised.com)> <mailto:asle.benoni@anonymised.com
mailto:[asle.benoni@anonymised.com](mailto:asle.benoni@anonymised.com)>>>
Hello,
OS X Server
<http://borchbio.no:8080/geoserver/wms?bbox=583491.5599999999,6544090.26,666894.4400000001,6637003.74&styles=&request=GetMap&version=1.1.1&layers=kulturminner_ns:funnsted&width=544&height=550&srs=EPSG:32632&Format=kml>>>”,
{projection: new
formatOptions: {
that the cgi
sends this:
proxy.cgi
on my
they are
type it
would
X? Do
I have
browser
/asle
<mailto:Geoserver-users@anonymised.comet
mailto:[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@anonymised.comrge.net)>
– Justin Deoliveira
– Justin Deoliveira
Justin Deoliveira
2009/5/9 Asle Benoni <asle.benoni@anonymised.com>
/asle
Hi Asle,
Response Headers
Request Headers
Host: localhost
Keep-Alive: 300
Response:
<![CDATA[
<![CDATA[
Kommune: Rakkestad
00ffffff
/asle
Hi Asle,
-Justin
Asle Benoni wrote:
Thanks.
/asle
Hi Asle,
/asle
Hello,
OS X Server
{projection: new
formatOptions: {
that the cgi
sends this:
proxy.cgi
on my
they are
type it
would
X? Do
I have
browser
/asle
– Justin Deoliveira
– Justin Deoliveira
Justin Deoliveira
Can you keep replies on the public list. Thanks.
I mean the tomcat log, catalog.out.
-Justin
Asle Benoni wrote:
Thanks. Do you mean the Apache log or Tomcat log?
/asle
2009/5/11 Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>>
    Hi Asle,
    Hmmm... the content type *application/vnd.ogc.se_xml;charset=UTF-8*
    means that an exception occurred internally, so it may be a false
    positive. When you make the request do you see any problems in the log?
    Asle Benoni wrote:
        Content-Type *application/vnd.ogc.se_xml;charset=UTF-8*
        Content-Type *application/vnd.google-earth.kml+xml*
        /asle
           Hi Asle,
           Response Headers
           Request Headers
           Host: localhost
        en-US;
           Accept:
           Keep-Alive: 300
        <http://localhost/~jdeolive/asle.html&gt;
           Response:
           ]]></name>
           color:teal;">
           Link til <a
                   <LookAt>
                      <tilt>10.0</tilt>
                      <range>700</range>
                   </LookAt>
                   <Style>
                      <IconStyle>
                         <Icon>
                         </Icon>
                      </IconStyle>
                      <LabelStyle>
                      </LabelStyle>
                   </Style>
                   <Point>
                   </Point>
                </Placemark>
        screenshot is
               my proxy.cgi.
               /asle
        <mailto:jdeolive@anonymised.com>> <mailto:jdeolive@anonymised.com
                  Hi Asle,
        modify the
        <http://borchio.no>
                  -Justin
                  Asle Benoni wrote:
                      Thanks.
        set this
               just
               this URL
        not if
               you are
                      /asle
        <mailto:jdeolive@anonymised.com>>> <mailto:jdeolive@anonymised.com
        <mailto:jdeolive@anonymised.com>>>>>
                         Hi Asle,
        set up a
               proxy for
        using
               the one
               directory?
               GeoServer on OS X?
                             /asle
        <mailto:asle.benoni@anonymised.com>>>> <mailto:asle.benoni@anonymised.com
        <mailto:asle.benoni@anonymised.com>>>>>>
                                Hello,
               proxy.cgi on
                      OS X Server
        funnsted",
        <http://borchbio.no:8080/geoserver/wms?bbox=583491.5599999999,6544090.26,666894.4400000001,6637003.74&styles=&request=GetMap&version=1.1.1&layers=kulturminner_ns:funnsted&width=544&height=550&srs=EPSG:32632&Format=kml&gt;&gt;&gt;&gt;
        <http://borchbio.no:8080/geoserver/wms?bbox=583491.5599999999,6544090.26,666894.4400000001,6637003.74&styles=&request=GetMap&version=1.1.1&layers=kulturminner_ns:funnsted&width=544&height=550&srs=EPSG:32632&Format=kml&gt;&gt;&gt;&gt;&gt;&quot;,
                                              {projection: new
                                               format:
                                               formatOptions: {
        2.2.8 I see
                      that the cgi
                                sends this:
                                *Content Type:
        When I use
                      proxy.cgi
                             on my
                                *Content Type:
               Server and
                      they are
               request
                      type it
                             would
               this on OS
                      X? Do
                             I have
               directly in my
                      browser
        Earth file.
                                /asle
        <mailto:Geoserver-users@lists.sourceforge.net>>>
        <mailto:Geoserver-users@lists.sourceforge.net>>>>
Justin Deoliveira
Sorry, forgot to change the recepient :frowning:
Anyway I am definite there is something with proxy.cgi since I also have problems when trying a WFS call. Here is the errors in catalina.out when I do the call for the KML:
11 May 16:30:33 INFO [geoserver.filters] - 85.196.85.67 “GET /geoserver/wms?bbox=583491.5599999999,6544090.26,666894.4400000001,6637003.74” “Python-urllib/2.5” “”
11 May 16:30:33 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Could not determine geoserver request from http request org.apache.catalina.connector.RequestFacade@anonymised.com
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:389)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:208)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:69)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Thread.java:613)
11 May 16:30:33 INFO [geoserver.filters] - 85.196.85.67 “GET /geoserver/wms?bbox=583491.5599999999,6544090.26,666894.4400000001,6637003.74” took 2ms
11 May 17:09:46 INFO [geoserver.filters] - 85.196.85.67 “GET /geoserver/wms?bbox=583491.5599999999,6544090.26,666894.4400000001,6637003.74” “Python-urllib/2.5” “”
11 May 17:09:46 ERROR [geoserver.ows] -
11 May 17:09:46 INFO [geoserver.filters] - 85.196.85.67 “GET /geoserver/wms?bbox=583491.5599999999,6544090.26,666894.4400000001,6637003.74” took 11ms
2009/5/11 Justin Deoliveira <jdeolive@anonymised.com>
-Justin
/asle
2009/5/11 Justin Deoliveira <jdeolive@anonymised.com mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)>
Hi Asle,
Hmmm… the content type application/vnd.ogc.se_xml;charset=UTF-8
Asle Benoni wrote:
/asle
Hi Asle,
Response Headers
Request Headers
Host: localhost
en-US;
Accept:
Keep-Alive: 300
<http://localhost/%7Ejdeolive/asle.html>
Response:
<![CDATA[
Spydslaug
,i matr Spjųslag (Funnsted)
<![CDATA[
Kommune: Rakkestad
<img
src=“
00ffffff
screenshot is
my proxy.cgi.
/asle
mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)> <mailto:jdeolive@anonymised.com
<mailto:jdeolive@anonymised.com mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)>>>
Hi Asle,
modify the
<http://borchio.no>
-Justin
Asle Benoni wrote:
Thanks.
set this
just
this URL
not if
you are
/asle
mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)>> <mailto:jdeolive@anonymised.com
mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)>>>>
Hi Asle,
set up a
proxy for
using
the one
directory?
GeoServer on OS X?
/asle
<asle.benoni@anonymised.com mailto:[asle.benoni@anonymised.com](mailto:asle.benoni@anonymised.com..)
<mailto:asle.benoni@anonymised.com mailto:[asle.benoni@anonymised.com](mailto:asle.benoni@anonymised.com)>
mailto:[asle.benoni@anonymised.com](mailto:asle.benoni@anonymised.com)>>> <mailto:asle.benoni@anonymised.com
mailto:[asle.benoni@anonymised.com](mailto:asle.benoni@anonymised.com)>>>>>
Hello,
proxy.cgi on
OS X Server
funnsted”,
<http://borchbio.no:8080/geoserver/wms?bbox=583491.5599999999,6544090.26,666894.4400000001,6637003.74&styles=&request=GetMap&version=1.1.1&layers=kulturminner_ns:funnsted&width=544&height=550&srs=EPSG:32632&Format=kml>>>>
<http://borchbio.no:8080/geoserver/wms?bbox=583491.5599999999,6544090.26,666894.4400000001,6637003.74&styles=&request=GetMap&version=1.1.1&layers=kulturminner_ns:funnsted&width=544&height=550&srs=EPSG:32632&Format=kml>>>>>”,
{projection: new
format:
formatOptions: {
2.2.8 I see
that the cgi
sends this:
Content Type:
When I use
proxy.cgi
on my
Content Type:
Server and
they are
request
type it
would
this on OS
X? Do
I have
directly in my
browser
Earth file.
/asle
<mailto:Geoserver-users@anonymised.coms.sourceforge.net
mailto:[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@anonymised.comrge.net)>>
mailto:[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@anonymised.comrge.net)>>>
– Justin Deoliveira
– Justin Deoliveira
– Justin Deoliveira
– Justin Deoliveira
Justin Deoliveira
Hello again,
I wonder if anyone can send me their working proxy.cgi. I also wonder how to check if something is missing on my OS X Server. Maybe some of the import python modules
import urllib2
import cgi
import sys, os
Is there a way to check directly if the proxy.cgi is working?
/asle
2009/5/11 Asle Benoni <asle.benoni@anonymised.com>
-Justin
/asle
Hi Asle,
Asle Benoni wrote:
/asle
Hi Asle,
Response Headers
Request Headers
Host: localhost
en-US;
Accept:
Keep-Alive: 300
Response:
<![CDATA[
Spydslaug
<![CDATA[
Kommune: Rakkestad
<img
src=“
00ffffff
screenshot is
my proxy.cgi.
/asle
Hi Asle,
modify the
<http://borchio.no>
-Justin
Asle Benoni wrote:
Thanks.
set this
just
this URL
not if
you are
/asle
Hi Asle,
set up a
proxy for
using
the one
directory?
GeoServer on OS X?
/asle
Hello,
proxy.cgi on
OS X Server
funnsted”,
{projection: new
format:
formatOptions: {
2.2.8 I see
that the cgi
sends this:
Content Type:
When I use
proxy.cgi
on my
Content Type:
Server and
they are
request
type it
would
this on OS
X? Do
I have
directly in my
browser
Earth file.
/asle
– Justin Deoliveira
– Justin Deoliveira
– Justin Deoliveira
– Justin Deoliveira
Justin Deoliveira
Hi Asle,
Attached is the proxy.cgi I use. Is our server public? I can try again on my system to see if I can get it to work. Just provide the relevant snippet of the OL map you are using.
-Justin
Asle Benoni wrote:
Hello again,
import urllib2
import cgi
import sys, os
/asle
2009/5/11 Asle Benoni <asle.benoni@anonymised.com <mailto:asle.benoni@anonymised.com>>
    11 May 16:30:33 INFO [geoserver.filters] - 85.196.85.67 "GET
    /geoserver/wms?bbox=583491.5599999999,6544090.26,666894.4400000001,6637003.74"
    "Python-urllib/2.5" ""
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
    took 2ms
    11 May 17:09:46 INFO [geoserver.filters] - 85.196.85.67 "GET
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
              at
    took 11ms
        -Justin
            /asle
               Hi Asle,
            a false
               Asle Benoni wrote:
            put this on
            definetely the
            image):
            proxy.cgi
            fix it? I
            on this server.
                   /asle
                      Hi Asle,
                      Response Headers
                      Request Headers
                      Host: localhost
            OS X 10.5;
                   en-US;
                      Accept:
                      Keep-Alive: 300
                      Response:
                           <Placemark
                       ,i matr Spjųslag (Funnsted)</div>
                      ]]></name>
                      color:teal;">
                      Link til <a
                              <LookAt>
                                 <tilt>10.0</tilt>
                                 <range>700</range>
                              </LookAt>
                              <Style>
                                 <IconStyle>
                                    <Icon>
                                    </Icon>
                                 </IconStyle>
                                 <LabelStyle>
                                 </LabelStyle>
                              </Style>
                              <Point>
                              </Point>
                           </Placemark>
            domain, else I
                   screenshot is
                          my proxy.cgi.
                          /asle
                             Hi Asle,
            but i had to
                   modify the
            <http://borchio.no> <http://borchio.no>
                   <http://borchio.no>
                             -Justin
                             Asle Benoni wrote:
                                 Thanks.
            OpenLayers and
                   set this
                          just
            try to request
                          this URL
            works or if
                   not if
                          you are
                                 /asle
            <mailto:jdeolive@anonymised.com>>>>>>
                                    Hi Asle,
            successfully
                   set up a
                          proxy for
            issues. Are you
                   using
                          the one
            the examples
                          directory?
            there using
                          GeoServer on OS X?
                                        /asle
            <mailto:asle.benoni@anonymised.com>>>>>>>
                                           Hello,
            requests sent from
                          proxy.cgi on
                                 OS X Server
                                           var kml =new
                   funnsted",
            <http://borchbio.no:8080/geoserver/wms?bbox=583491.5599999999,6544090.26,666894.4400000001,6637003.74&styles=&request=GetMap&version=1.1.1&layers=kulturminner_ns:funnsted&width=544&height=550&srs=EPSG:32632&Format=kml&gt;&gt;&gt;&gt;&gt;&gt;&quot;,
                                                         {projection: new
                                                          format:
                                                          formatOptions: {
            and Apache
                   2.2.8 I see
                                 that the cgi
                                           sends this:
                                           *Content Type:
            OS X Server.
                   When I use
                                 proxy.cgi
                                        on my
                                           *Content Type:
            on the OS X
                          Server and
                                 they are
            correct header
                          request
                                 type it
                                        would
            does the CGI send
                          this on OS
                                 X? Do
                                        I have
            OS X?
            run this URL
                          directly in my
                                 browser
            Google
                   Earth file.
                                           /asle
            <mailto:Geoserver-users@lists.sourceforge.net>>>>>
            geospatial.
The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
production scanning environment may not be a perfect world - but thanks to
Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
Series Scanner you'll get full speed at 300 dpi even with all image processing features enabled. http://p.sf.net/sfu/kodak-com
Justin Deoliveira
proxy.cgi (2.41 KB)
Thanks. Replacing proxy.cgi had no effect.
This is the OL code that works fine from another linux server. I have the same problem with WFS:
var kml =new OpenLayers.Layer.GML(“KML arkelogisk minne”, “http://borchbio.no:8080/geoserver/wms?bbox=583491.5599999999,6544090.26,666894.4400000001,6637003.74&styles=&request=GetMap&version=1.1.1&layers=kulturminner_ns:arkminne&width=544&height=550&srs=EPSG:32632&service=WMS&Format=kml&request=getmap&”,
formatOptions: {
/asle
2009/5/13 Justin Deoliveira <jdeolive@anonymised.com>
Hi Asle,
-Justin
Asle Benoni wrote:
Hello again,
import urllib2
import cgi
import sys, os
/asle
2009/5/11 Asle Benoni <asle.benoni@anonymised.com mailto:[asle.benoni@anonymised.com](mailto:asle.benoni@...84...)>
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
took 2ms
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
took 11ms
-Justin
/asle
Hi Asle,
a false
Asle Benoni wrote:
put this on
definetely the
image):
proxy.cgi
fix it? I
on this server.
/asle
Hi Asle,
Response Headers
Request Headers
Host: localhost
OS X 10.5;
en-US;
Accept:
Keep-Alive: 300
Response:
<![CDATA[
Spydslaug
<![CDATA[
Kommune: Rakkestad
<img
src=“
00ffffff
domain, else I
screenshot is
my proxy.cgi.
/asle
<jdeolive@anonymised.com mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com..1671...)
Hi Asle,
but i had to
modify the
<http://borchio.no>
-Justin
Asle Benoni wrote:
Thanks.
OpenLayers and
set this
just
try to request
this URL
works or if
not if
you are
/asle
<mailto:jdeolive@anonymised.com…
mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)>>>>>
Hi Asle,
successfully
set up a
proxy for
issues. Are you
using
the one
the examples
directory?
there using
GeoServer on OS X?
/asle
<asle.benoni@anonymised.com mailto:[asle.benoni@anonymised.com](mailto:asle.benoni@anonymised.com)
<mailto:asle.benoni@anonymised.com4…
mailto:[asle.benoni@anonymised.com](mailto:asle.benoni@anonymised.com)>>>>>>
Hello,
requests sent from
proxy.cgi on
OS X Server
var kml =new
funnsted”,
[Melding avkuttet]
#!/usr/bin/env python
“”“This is a blind proxy that we use to get around browser
restrictions that prevent the Javascript from loading pages not on the
same server as the Javascript. This has several problems: it’s less
efficient, it might break some sites, and it’s a security risk because
people can use this proxy to browse the web and possibly do bad stuff
with it. It only loads pages via http and https, but it can load any
content type. It supports GET and POST requests.”“”
import urllib2
import cgi
import sys, os
Designed to prevent Open Proxy type stuff.
allowedHosts = [‘www.openlayers.org’, ‘openlayers.org’,
labs.metacarta.com’, ‘world.freemap.in’,
prototype.openmnnd.org’, ‘geo.openplans.org’,
sigma.openplans.org’, ‘demo.opengeo.org’,
www.openstreetmap.org’, ‘borchbio.no:8080’]
method = os.environ[“REQUEST_METHOD”]
if method == “POST”:
qs = os.environ[“QUERY_STRING”]
d = cgi.parse_qs(qs)
if d.has_key(“url”):
url = d[“url”][0]
else:
url = “http://www.openlayers.org
else:
fs = cgi.FieldStorage()
url = fs.getvalue(‘url’, “http://www.openlayers.org”)
try:
host = url.split(“/”)[2]
if allowedHosts and not host in allowedHosts:
print “Status: 502 Bad Gateway”
print “Content-Type: text/plain”
print
print “This proxy does not allow you to access that location (%s).” % (host,)
print
print os.environ
elif url.startswith(“http://”) or url.startswith(“https://”):
length = int(os.environ[“CONTENT_LENGTH”])
headers = {“Content-Type”: os.environ[“CONTENT_TYPE”]}
body = sys.stdin.read(length)
r = urllib2.Request(url, body, headers)
y = urllib2.urlopen(r)
else:
y = urllib2.urlopen(url)
print content type header
i = y.info()
if i.has_key(“Content-Type”):
print “Content-Type: %s” % (i[“Content-Type”])
else:
print
print y.read()
y.close()
else:
print
print “Illegal request.”
except Exception, E:
print “Status: 500 Unexpected Error”
print
print “Some unexpected error occurred. Error text was:”, E
Just tried it and it worked ok on Mac OS X leopard.
YOu may want to query the openlayers list, there might be folks there that have more experience with these matters, since that is where the proxy script originates from.
-Justin
var kml =new OpenLayers.Layer.GML("KML arkelogisk minne", "http://borchbio.no:8080/geoserver/wms?bbox=583491.5599999999,6544090.26,666894.4400000001,6637003.74&styles=&request=GetMap&version=1.1.1&layers=kulturminner_ns:arkminne&width=544&height=550&srs=EPSG:32632&service=WMS&Format=kml&request=getmap&&quot;,
                formatOptions: {
/asle
2009/5/13 Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>>
    Hi Asle,
    -Justin
    Asle Benoni wrote:
        Hello again,
        import urllib2
        import cgi
        import sys, os
        /asle
        I also
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
           took 2ms
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
                     at
           took 11ms
               -Justin
                   /asle
                      Hi Asle,
        may be
                   a false
                      Asle Benoni wrote:
        to use KML
        proxy.cgi. If I
                   put this on
                   definetely the
        (attached
                   image):
                          Content-Type
        server the
                   proxy.cgi
                          Content-Type
        how to
                   fix it? I
        geoserver
                   on this server.
                          /asle
                             Hi Asle,
                             Response Headers
                             Content-Type:
                             Request Headers
                             Host: localhost
        Intel Mac
                   OS X 10.5;
                          en-US;
                             Accept:
                             Keep-Alive: 300
                             Referer:
                             Response:
                               <Document
                                  <Placemark
                             ]]></name>
                             color:teal;">
                             Link til <a
                                     <LookAt>
                                        <tilt>10.0</tilt>
                                        <range>700</range>
                                     </LookAt>
                                     <Style>
                                        <IconStyle>
                                           <Icon>
                                           </Icon>
                                        </IconStyle>
                                        <LabelStyle>
                                        </LabelStyle>
                                     </Style>
                                     <Point>
                                     </Point>
                                  </Placemark>
        added the
                   domain, else I
        attached
                          screenshot is
                                 my proxy.cgi.
                                 /asle
        <mailto:jdeolive@anonymised.com>>>> <mailto:jdeolive@anonymised.com
                                    Hi Asle,
                   but i had to
                          modify the
        <http://borchio.no>
                          <http://borchio.no>
                                    -Justin
                                    Asle Benoni wrote:
                                        Thanks.
                   OpenLayers and
                          set this
                                 just
        Could you
                   try to request
                                 this URL
        if it
                   works or if
                          not if
                                 you are
                                        /asle
        <mailto:jdeolive@anonymised.com>>>>>>>
                                           Hi Asle,
                   successfully
                          set up a
                                 proxy for
                   issues. Are you
                          using
                                 the one
        repo in
                   the examples
                                 directory?
                   there using
                                 GeoServer on OS X?
                                               /asle
        <mailto:asle.benoni@anonymised.com>>>>>>>>
                                                  Hello,
                   requests sent from
                                 proxy.cgi on
                                        OS X Server
                                                  var kml =new
                          funnsted",
    [Melding avkuttet] #!/usr/bin/env python
    """This is a blind proxy that we use to get around browser
    same server as the Javascript. This has several problems: it's less
    efficient, it might break some sites, and it's a security risk because
    content type. It supports GET and POST requests."""
    import urllib2
    import cgi
    import sys, os
    # Designed to prevent Open Proxy type stuff.
    allowedHosts = ['www.openlayers.org <http://www.openlayers.org>',
    'openlayers.org <http://openlayers.org>',
                   'labs.metacarta.com <http://labs.metacarta.com>',
    'world.freemap.in <http://world.freemap.in>',
                   'prototype.openmnnd.org
    <http://prototype.openmnnd.org>', 'geo.openplans.org
    <http://geo.openplans.org>',
                   'sigma.openplans.org <http://sigma.openplans.org>',
    'demo.opengeo.org <http://demo.opengeo.org>',
                   'www.openstreetmap.org
    <http://www.openstreetmap.org>', 'borchbio.no:8080
    <http://borchbio.no:8080>']
    method = os.environ["REQUEST_METHOD"]
    if method == "POST":
       qs = os.environ["QUERY_STRING"]
       if d.has_key("url"):
           url = d["url"][0]
       else:
           url = "http://www.openlayers.org"
    else:
       url = fs.getvalue('url', "http://www.openlayers.org")
    try:
       host = url.split("/")[2]
           print "Status: 502 Bad Gateway"
           print "Content-Type: text/plain"
           print
           print "This proxy does not allow you to access that location
    (%s)." % (host,)
           print
           print os.environ
       elif url.startswith("http://") or url.startswith("https://"):
               length = int(os.environ["CONTENT_LENGTH"])
               headers = {"Content-Type": os.environ["CONTENT_TYPE"]}
           else:
           # print content type header
           i = y.info <http://y.info>()
           if i.has_key("Content-Type"):
               print "Content-Type: %s" % (i["Content-Type"])
           else:
           print
           print y.read()
           y.close()
       else:
           print
           print "Illegal request."
       print "Status: 500 Unexpected Error"
       print
       print "Some unexpected error occurred. Error text was:", E
Justin Deoliveira
Thanks for testing!
I have posted this several times on the OpenLayers list without any response. So it seems it must be something with i.ex. Apache on Mac OS X Server contrary Leopard OS X Client.
I am also testing another proxy in PHP (http://www.daniweb.com/code/snippet494.html) without any luck yet.
Thanks for your efforts anyway. I guess I might just downgrade from OS X Server to Leopard client.
/asle
Den 13. mai. 2009 kl. 20.44 skrev Justin Deoliveira:
-Justin
var kml =new OpenLayers.Layer.GML("KML arkelogisk minne", "http://borchbio.no:8080/geoserver/wms?bbox=583491.5599999999,6544090.26,666894.4400000001,6637003.74&styles=&request=GetMap&version=1.1.1&layers=kulturminner_ns:arkminne&width=544&height=550&srs=EPSG:32632&service=WMS&Format=kml&request=getmap&&quot;, {projection: new OpenLayers.Projection("EPSG:4326"),
               formatOptions: {
/asle
2009/5/13 Justin Deoliveira <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com1…>>
   Hi Asle,
   -Justin
   Asle Benoni wrote:
       Hello again,
       import urllib2
       import cgi
       import sys, os
       /asle
       I also
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
          took 2ms
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
                    at
          took 11ms
              -Justin
                  /asle
                     Hi Asle,
       may be
                  a false
                     Asle Benoni wrote:
       to use KML
       proxy.cgi. If I
                  put this on
                  definetely the
       (attached
                  image):
                         Content-Type
       server the
                  proxy.cgi
                         Content-Type
       how to
                  fix it? I
       geoserver
                  on this server.
                         /asle
                            Hi Asle,
                            Response Headers
                            Content-Type:
                            Request Headers
                            Host: localhost
       Intel Mac
                  OS X 10.5;
                         en-US;
                            Accept:
                            Keep-Alive: 300
                            Referer:
                            Response:
                              <Document
                                 <Placemark
                            ]]></name>
                            color:teal;">
                            Link til <a
                                    <LookAt>
                                       <tilt>10.0</tilt>
                                       <range>700</range>
                                    </LookAt>
                                    <Style>
                                       <IconStyle>
                                          <Icon>
                                          </Icon>
                                       </IconStyle>
                                       <LabelStyle>
                                       </LabelStyle>
                                    </Style>
                                    <Point>
                                    </Point>
                                 </Placemark>
       added the
                  domain, else I
       attached
                         screenshot is
                                my proxy.cgi.
                                /asle
                                   Hi Asle,
                  but i had to
                         modify the
       <http://borchio.no>
                         <http://borchio.no>
                                   -Justin
                                   Asle Benoni wrote:
                                       Thanks.
                  OpenLayers and
                         set this
                                just
       Could you
                  try to request
                                this URL
       if it
                  works or if
                         not if
                                you are
                                       /asle
                                          Hi Asle,
                  successfully
                         set up a
                                proxy for
                  issues. Are you
                         using
                                the one
       repo in
                  the examples
                                directory?
                  there using
                                GeoServer on OS X?
                                              /asle
                                                 Hello,
                  requests sent from
                                proxy.cgi on
                                       OS X Server
                                                 var kml =new
                         funnsted",
   import urllib2
   import cgi
   import sys, os
          url = d["url"][0]
      else:
   else:
   try:
          print
   (%s)." % (host,)
          print
          print os.environ
          else:
          else:
          print
          print y.read()
          y.close()
      else:
          print
      print
Justin Deoliveira
