I have been using the REST API with Geoserver to POST and DELETE raster layers (coveragestore / coverages) dynamically. I have noticed a problem with deleting coveragestores recursively in v2.2.4. I was wondering if anyone else has seen this problem.
Prior to v2.2.4 the following command would work to delete a coveragestore and its layers
% curl –u : -XDELETE http://localhost:8180/geoserver/rest/workspaces/<WORKSPACE_NAME>/coveragestores/<COVERAGESTORE_NAME>?recurse=true
This seemed to stop working. POSTing coveragestores/coverages still works fine and deleting a workspace recursively works too?
The reallycd / strange thing is that I get a 404 back indicating the layer does not exist in Geoserver when it does.
Here is the error thrown in the server log
11:23:43,271 ERROR [org.geoserver.rest] (http–0.0.0.0-8180-18) No such coverage store: TEST_WORKSPACE,TEST_COVERAGESTORE
11:23:43,272 ERROR [org.geoserver.rest] (http–0.0.0.0-8180-18) : org.geoserver.rest.RestletException
at org.geoserver.catalog.rest.CoverageStoreFinder.findTarget(CoverageStoreFinder.java:31) [restconfig-2.2.4.jar:]
at org.restlet.Finder.handle(Finder.java:268) [org.restlet-1.0.8.jar:]
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:37) [rest-2.2.4.jar:]
at org.restlet.Filter.doHandle(Filter.java:105) [org.restlet-1.0.8.jar:]
at org.restlet.Filter.handle(Filter.java:134) [org.restlet-1.0.8.jar:]
at org.restlet.Router.handle(Router.java:444) [org.restlet-1.0.8.jar:]
at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:204) [rest-2.2.4.jar:]
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129) [com.noelios.restlet.ext.servlet-1.0.8.jar:]
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:86) [rest-2.2.4.jar:]
Environment:
Linux RHEL 5
Jboss 7
Java 7
Has anyone experienced this?
Thanks
-robert
