[Geoserver-users] Problems with REST on some coveragestores
I have a geoserver version 2.7.0 running on Ubuntu 14.4. and I am using the REST interface to create new coveragestores and layers or to add further data to an existing coveragestore. In general this is working quite good.
I have some python scripts sending the REST requests to the server, via python package ‘requests’. But since a few days I have problems ingesting new data to some of my coveragestores. For other coveragestores everything is still working without problems. I am always using the same requests.
POST-Reqeust to the URL:
http://ipaddress/geoserver/rest/workspaces/my-workspace/coveragestores/my-coveragestore/file.imagemosaic
A zip file with one tif image is sent.
I also tried the corresponding request via curl:
curl -v -u username:password -XPOST -H “Content-type:application/zip” --data-binary @path-to-zip http://ipaddress/geoserver/rest/workspaces/my-workspace/coveragestores/my-coveragestore/file.imagemosaic
The result is the same. The data is not included into the coveragestore. But I don’t get any error message. The HTTP return code is ‘202 - Accepted’ and the tif file is copied to the geoserver to the correct data directory of the coveragestore but it is not included into the coveragestore. We are using a database with the following database.properties file for the coveragestores:
JNDI specific
SPI=org.geotools.data.postgis.PostgisNGJNDIDataStoreFactory
jndiReferenceName=jdbc/postgres
Loose\ bbox=true
preparedStatements=false
Looking through the log files of geoserver and postgresql I could not find any error message.
/var/lib/tomcat/geoserver_master/logs/catalina.out
/var/lib/tomcat/geoserver_master/logs/localhost_access_log.2015-06-01.txt
/var/log/postgresql/postgresql-9.3-main.log
Everything looks normal. But the image is not ingested to the coveragestore. The strange thing is that for some coveragestores it is still working and for others I have these problem which just occured from one day to the other.
Does anyone has an idea? Are the maybe some more logfiles I could check?
Thanks.
Sabine
