[Geoserver-users] Problems with REST on some coveragestores
Hello,
The issue comes probably from the open connections to your database.
If you have a standard postgres/postgis installation the number of simultanous connection has limits.
You can augment this limit but, if the flow introduces always new coverages then soon or later this will happen again.
The best solution is to work with a jndi datasource defined in your tomcat/jetty container and use this connection in
the geoserver definition.
Best regards,
Eric Smets
Eric Smets                                    [eric.smets@anonymised.com](mailto:eric.smets@anonymised.com)
FKS bvba - Formal and Knowledge Systems       [http://www.fks.be](http://www.fks.be/)/
Schampbergstraat 32                           Tel:  ++32-(0)11-21 49 11
B-3511 Hasselt                                Fax:  ++32-(0)11-22 04 19
-----Oorspronkelijk bericht-----
Afzender: Sabine Ohlendorf sabine.ohlendorf@anonymised.com
Verstuurd: Maandag 1 Juni 2015 12:26
Aan: Geoserver Mailinglist geoserver-users@lists.sourceforge.net
Onderwerp: [Geoserver-users] Problems with REST on some coveragestores
I have a geoserver version 2.7.0 running on Ubuntu 14.4. and I am using the REST interface to create new coveragestores and layers or to add further data to an existing coveragestore. In general this is working quite good.
I have some python scripts sending the REST requests to the server, via python package ‘requests’. But since a few days I have problems ingesting new data to some of my coveragestores. For other coveragestores everything is still working without problems. I am always using the same requests.
POST-Reqeust to the URL:
http://ipaddress/geoserver/rest/workspaces/my-workspace/coveragestores/my-coveragestore/file.imagemosaic
A zip file with one tif image is sent.
I also tried the corresponding request via curl:
curl -v -u username:password -XPOST -H “Content-type:application/zip” --data-binary @path-to-zip http://ipaddress/geoserver/rest/workspaces/my-workspace/coveragestores/my-coveragestore/file.imagemosaic
The result is the same. The data is not included into the coveragestore. But I don’t get any error message. The HTTP return code is ‘202 - Accepted’ and the tif file is copied to the geoserver to the correct data directory of the coveragestore but it is not included into the coveragestore. We are using a database with the following database.properties file for the coveragestores:
JNDI specific
SPI=org.geotools.data.postgis.PostgisNGJNDIDataStoreFactory
jndiReferenceName=jdbc/postgres
Loose\ bbox=true
preparedStatements=false
Looking through the log files of geoserver and postgresql I could not find any error message.
/var/lib/tomcat/geoserver_master/logs/catalina.out
/var/lib/tomcat/geoserver_master/logs/localhost_access_log.2015-06-01.txt
/var/log/postgresql/postgresql-9.3-main.log
Everything looks normal. But the image is not ingested to the coveragestore. The strange thing is that for some coveragestores it is still working and for others I have these problem which just occured from one day to the other.
Does anyone has an idea? Are the maybe some more logfiles I could check?
Thanks.
Sabine
Geoserver-users mailing list
On Mon, Jun 1, 2015 at 12:31 PM, Eric Smets <eric.smets@anonymised.com> wrote:
Hello,
By the way, the issue of leaking connections in mosaics backed by jdbc
stores should be solved in 2.7.1,
and in 2.6.x nightly builds too
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
@Eric:thanks for the hint. We are already working with a jndi datasource.
@Andrea: good to know :slight_smile:
Sabine
On Mon, Jun 1, 2015 at 12:31 PM, Eric Smets <eric.smets@anonymised.com51…> wrote:
Hello,
By the way, the issue of leaking connections in mosaics backed by jdbc stores should be solved in 2.7.1,
Ing. Andrea Aime
@geowolf
Technical Lead
by chance I found the solution of the problem myself:
I found out that I was trying to ingest 32bit tif data to a layer with datatype 64bits. That was the reason why it didn't accept the data.
Still it is strange that this didn't throw an error or appeared in any logfile. It would have been good to receive an Error as answer on the REST request.
Sabine
On Tue, Jun 2, 2015 at 1:31 PM, Sabine Ohlendorf <sabine.ohlendorf@anonymised.com.>
wrote:
It is documented, see point 2 in the documentation
http://docs.geoserver.org/latest/en/user/tutorials/image_mosaic_plugin/imagemosaic.html
request.
Indeed it would be nice. You can file a request for improvement at
https://osgeo-org.atlassian.net/projects/GEOS
Pull request are welcomed too :slight_smile:
Ing. Andrea Aime
@geowolf
Technical Lead
