[Geoserver-users] problems with sld filter, postgresql 8.3 and geoserver 1.7.3
I’ve tried to quickly reproduce with some postgis data I have
without luck. Can you open a bug report on jira.codehaus.org
adding full SLD and a sql dump of your postgis data, complete
enough to reproduce the issue?
Sure (just give me some time). Which Posgresql version do you use? It should only happen with 8.3 and greater.
Stefan
Andrea Aime
OpenGeo - http://opengeo.org
Ziegler Stefan ha scritto:
I've tried to quickly reproduce with some postgis data I have
I use 8.3.5, and I also checked the SQL generated in the debugger
and there was no lower call. That's why I need more detail.
Andrea Aime
