[Geoserver-users] problems with sld filter, postgresql 8.3 and geoserver 1.7.3
Ok, here’s the bug report:
http://jira.codehaus.org/browse/GEOS-2779
regards
Stefan
Von: Andrea Aime [mailto:aaime@anonymised.com]
Gesendet am: Montag, 23. März 2009 16:33
An: Ziegler Stefan
Cc: geoserver-users
Betreff: Re: AW: Re: AW: Re: [Geoserver-users] problems with
sld filter,
Ziegler Stefan ha scritto:
I’ve tried to quickly reproduce with some postgis data I have
without luck. Can you open a bug report on jira.codehaus.org
adding full SLD and a sql dump of your postgis data, complete
enough to reproduce the issue?
Sure (just give me some time). Which Posgresql version do
you use? It
should only happen with 8.3 and greater.
I use 8.3.5, and I also checked the SQL generated in the debugger
and there was no lower call. That’s why I need more detail.
Andrea Aime
OpenGeo - http://opengeo.org
