Manolo,
If every orthophoto has a different resolution, (pixel size different in x,y) there are two ways to do this:
A different layer for each ortho, let GeoServer resolve the differences. Not too speedy, but might work if you have only a few.
Use Gdal to convert all the orthos into a common format/resolution/projection, then use the Mosaicing plugin in GDAL to display them. Jpeg2k might be a likely suspect for the format, although I don’t know.
For either, you can then use the GeoWebCache to speed up the access by the end user. However, I haven’t been able to get GeoWebCache to work (yet!), so this may be wishful thinking.
Roger
Roger Bedell, President Sylvan Ascent Inc.
800-362-8971
+34 626 855 662
roger@anonymised.com
www.sylvanascent.com
www.topodepot.com
From: Manolo texaco [mailto:manolo.texaco@anonymised.com]
Sent: Tue 10/28/2008 6:11 AM
Subject: [Geoserver-users] Process orthophotos to plugins mosaics
Hello!
At first, sorry my poor English.
My mother language is Spanish.
I want share, via webbroser, a recents orthophotos take on the air.
I read in others formuns that, the ortophotos required a pre-process
to make a mosaic, to resolved “errors”.
I find “er mapper” software to do this, but always I tray to use
opensorce software.
I want know if exists any opensource solutions to pre-process the
orthophotos and make the mosaic.
In additions, I have georeferencing in shape file of the orthophotos.
But I think that, I can’t use this shape file to implements my mosaic
in geoserver because, each orthophoto have a diferent resolution.
The orthophoto format is “.PMI” but I think that this format is JPG
with PMI extensions.
thanks for all!
This SF.Net email is sponsored by the Moblin Your Move Developer’s challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
