[Geoserver-users] Projection centered on the Pacific Ocean
Good afternoon
I need to display some maps which are centered on the Pacific Ocean. After
having spend some times, looking at the different SRS available in
GeoServer, i run a bunch of test with the EPSG=3349.
This is the type of map, i obtain:
http://www.fao.org/figis/geoserver/wms?bbox=-22041257.773878,-14322638.1338445,22041257.773878,13613811.2422463&styles=&Format=application/openlayers&request=GetMap&version=1.1.1&layers=fifao:UN_CONTINENT&width=800&height=362&srs=EPSG:3349
It is effectively centered on the Pacific ocean but, many polygons are not
correctly displayed.
Normal view with EPSG:4326:
http://www.fao.org/figis/geoserver/wms?bbox=-198.0,-98.68118000000004,198.0,92.30478000000085&styles=&Format=application/openlayers&request=GetMap&version=1.1.1&layers=fifao:UN_CONTINENT&width=800&height=362&srs=EPSG:4326
Is it a bug of GeoServer or did I make some mistakes defining the parameters
of my map?Is it the correct SRS with the right bounding box?
My data is extracted from an Oracle DB and i am using GeoServer 1.6.5. I
tried with the 1.7.0-RC1-pre version, it have obtained a white page.
Thanks for helping me.
Sylvain
View this message in context: http://www.nabble.com/Projection-centered-on-the-Pacific-Ocean-tp18983741p18983741.html
Hi Sylvain,
I am forwarding your request to the Geotools list. There are people there who are far more knowledgeable about referencing systems and in particular the GeoServer implementation and can better answer your question.
springrider wrote:
Good afternoon
This is the type of map, i obtain: http://www.fao.org/figis/geoserver/wms?bbox=-22041257.773878,-14322638.1338445,22041257.773878,13613811.2422463&styles=&Format=application/openlayers&request=GetMap&version=1.1.1&layers=fifao:UN_CONTINENT&width=800&height=362&srs=EPSG:3349 It is effectively centered on the Pacific ocean but, many polygons are not
Sylvain
Justin Deoliveira
Software Engineer, OpenGeo
http://opengeo.org
This looks like a standard 'edge of the earth' issue. Your data has
been clipped so that these artifacts don't appear in EPSG:4326 (look
around Egvekinot). The problem here is that when a polygon, such as
Africa, extends beyond the edge of the map the points are being
projected to the other side of the view. The results are the horizontal
lines as the polygon races across the map. You will likely need to do
data preparation to split some continents across your edge of the world.
Mark Leslie
Geospatial Software Architect
LISAsoft
Ph: +61 2 8570 5000 Fax: +61 2 8570 5099 Mob: +61
Suite 112, Jones Bay Wharf 19-21 Pirrama Rd Pyrmont NSW 2009
LISAsoft is part of the A2end Group of Companies
http://www.ardec.com.au
http://www.lisasoft.com
http://www.terrapages.com
springrider wrote:
Good afternoon
Sylvain
Thanks for your replies.
I can not technically reshape my data. In fact from the same geographical
data source, i want to apply different projections (4326, Antartica
projection, pacific centered projection).
I need to find a solution to have my data projected based on a meridian
centered on the pacific.
Anyway, I think, there is a bug too. In fact, all the polygons which are cut
by the antimeridian are the ones not correctly displayed with the color
outside of the envelope because it seems in that configuration that the
polygons are not closed anymore. For Antartica, it is even worst, it's not
appearing anymore.
It is even more visible in that view:
http://www.fao.org/figis/geoserver/wms?bbox=-22041257.773878,-14322638.1338445,22041257.773878,13613811.2422463&styles=&Format=application/openlayers&request=GetMap&version=1.1.1&layers=fifao:ISO3_COUNTRY&width=800&height=362&srs=EPSG:3349
Do i have to add this bug into JIRA for GeoServer of For GeoTools?
Do you have any other suggestions to eade this problem?
Thanks again for your help.
Sylvain
Mark Leslie
LISAsoft
springrider wrote:
Good afternoon
After
not
parameters
Sylvain
This SF.Net email is sponsored by the Moblin Your Move Developer's
challenge
Build the coolest Linux based applications with Moblin SDK & win great
prizes
Grand prize is a trip for two to an Open Source event anywhere in the
world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
View this message in context: http://www.nabble.com/Projection-centered-on-the-Pacific-Ocean-tp18983741p19050545.html
appearing anymore.
It is even more visible in that view: http://www.fao.org/figis/geoserver/wms?bbox=-22041257.773878,-14322638.1338445,22041257.773878,13613811.2422463&styles=&Format=application/openlayers&request=GetMap&version=1.1.1&layers=fifao:ISO3_COUNTRY&width=800&height=362&srs=EPSG:3349
At the moment it's not possible to do what you're asking for,
and the fix is definitely not trivial. We'd have to determine
the validity area of the destination projection, notice that
the polygons go beyond that, split them along the discontinuity
line, and render them separately.
Due to a bug in GT2 referencing, we cannot even guess where the
discontinuities are (http://jira.codehaus.org/browse/GEOT-1578).
Martin, any suggestion on how to deal with this case? How
do we figure out when polygon splitting is needed, and where?
Does anyone have any pointers on how to deal with the problem of
GeoServer not able to render polygons straddling the anti-meridian
correctly?
From what I've been reading this is still a "bug" in GeoServer
(GeoTools?) and that it cannot be fixed easily. I'm surprised this
hasn't been addressed. We're trying to "port" our Swing-based
application using OpenMap to a web-based one using
OpenLayers/GeoServer. OpenMap seems to handle our straddling
anti-meridian polygons just fine...
One solution I've read about is to take the offending polygons and
split them along the anti-meridian, but you'll end up with a line on
the anti-meridian without some fancy SLD action. Does anyone have any
code examples on how to do all this?
Many thanks in advance!
Rob
appearing anymore.
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
I have been investigating this and similar problems myself even recently.
The problem, or better limitation, is at the geotools level and due to
the various checks performed on the Area of Definitions of the various
CRS.
Fixing/improving this is not going to be trivial, given also the
amount of code that depends on this part.
Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
correctly?
Rob
appearing anymore.
Create and Deploy Rich Internet Apps outside the browser with Adobe(R)AIR(TM)
software. With Adobe AIR, Ajax developers can use existing skills and code to
build responsive, highly engaging applications that combine the power of local
resources and data with the reach of the web. Download the Adobe AIR SDK and
Ajax docs to start building applications today-http://p.sf.net/sfu/adobe-com
