Hi I am a user of Geoserver. I have configured Geo Server with SDE plugin. I
am able to access all my SDE layers. I have successfully published my SDE
layers as well. From layers preview I have generated Google Earth KML file.
There I found an issue that layers projection is slightly shifted with an 50
meters distance.
My spatial reference was pointing to QND95 and EPSG:2932 or wkid is 2932.
For cross checking I have exported my feature classes into shape files and I
exported them POSTGIS Database using command shp2psql. After exporting I
have done the set_Transform command for all the tables that I exported.
I have configured postgresql in Geo Server and was successfully accessing
the postgis table.
That seems to be projecting in a correct way.
I am confused where exactly the problem lies. It should be considered as
major issue.
50 m sounds very specific. I would check the data at each stage and look for a difference in spatial reference system, or the definition of the spatial reference system between ArcSDE and GeoServer and Google Earth.
meters distance.
the postgis table.
major issue.
Subversion Kills Productivity. Get off Subversion & Make the Move to Perforce.
With Perforce, you get hassle-free workflows. Merge that actually works.
Faster operations. Version large binaries. Built-in WAN optimization and the
freedom to use Git, Perforce or both. Make the move to Perforce. http://pubads.g.doubleclick.net/gampad/clk?id=122218951&iu=/4140/ostg.clktrk
