Dear List,
This is geoserver 2.0.2.
I use geoserver to display Landsat7 scenes that were downloaded from the
GLCF website. The files came with the EPSG:32635 projection. I imported the
scenes in grass, pan-sharpened the image (with i.fusion.brovey), formed a
true-color indexed output image (with r.composite) and output it to a
single-band, 16 bits GeoTiFF (with r.out.gdal). I then used gdal_translate
to transform it into a 8-bits rgba GeoTiFF image :
gdal_translate -expand rgba -ot Byte -a_nodata 0 00_marm_pan.rgb.tif
00_marm_pan.rgb.tif
I then used gdalwarp to mosaic and reproject two adjacent files into on
Google Merkator projection :
gdalwarp -co "TILED=YES" -t_srs EPSG:900913 00_marm_pan.rgb_900913.tif
00_bb_pan.rgb_900913.tif Landsat_2000.tif
I then add overviews with :
gdaladdo Landsat_2000.tif 2 4 8 16"
I tried to display the resulting file in grass, qgis and openjump. I all
these software, my file overlays nicely with all other vector layers of same
projection and google tiles (qgis with openlayers plugin, see the first
screenshot). I then imported the file in geoserver but here the image is far
off of the same vector layers tested during the previous stage. See the
second screenshot.
The resulting mosaic file reports :
Size is 1507, 920
Coordinate System is:
PROJCS["Google Maps Global Mercator",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]],
PROJECTION["Mercator_1SP"],
PARAMETER["central_meridian",0],
PARAMETER["scale_factor",1],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (3203626.613789663650095,5031755.790616016834974)
Pixel Size = (37.731260645376345,-37.731260645376345)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 3203626.614, 5031755.791) ( 28d46'43.20"E, 41d19'19.76"N)
Lower Left ( 3203626.614, 4997043.031) ( 28d46'43.20"E, 41d 5'11.94"N)
Upper Right ( 3260487.624, 5031755.791) ( 29d17'22.05"E, 41d19'19.76"N)
Lower Right ( 3260487.624, 4997043.031) ( 29d17'22.05"E, 41d 5'11.94"N)
Center ( 3232057.119, 5014399.411) ( 29d 2'2.63"E, 41d12'16.23"N)
Band 1 Block=1507x1 Type=Byte, ColorInterp=Red
Overviews: 754x460, 377x230, 189x115, 95x58
Mask Flags: PER_DATASET ALPHA
Overviews of mask band: 754x460, 377x230, 189x115, 95x58
Band 2 Block=1507x1 Type=Byte, ColorInterp=Green
Band 3 Block=1507x1 Type=Byte, ColorInterp=Blue
Band 4 Block=1507x1 Type=Byte, ColorInterp=Alpha
Geoserver reports the native SRS of this file as UNKNOWN. There is a blue
link next to it called "unnamed" , when I click on it, I get :
PROJCS["unnamed",
GEOGCS["WGS 84",
DATUM["World Geodetic System 1984",
SPHEROID["WGS 84", 6378137.0, 298.257223563,
PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
UNIT["degree", 0.017453292519943295],
AXIS["Geodetic longitude", EAST],
AXIS["Geodetic latitude", NORTH],
PARAMETER["latitude_of_origin", 0.0],
PARAMETER["central_meridian", 0.0],
PARAMETER["scale_factor", 1.0],
PARAMETER["false_easting", 0.0],
PARAMETER["false_northing", 0.0],
UNIT["m", 1.0],
AXIS["Easting", EAST],
AXIS["Northing", NORTH]]
The Geotif file just before reprojection reports :
Size is 1487, 885
PROJCS["WGS 84 / UTM zone 35N",
GEOGCS["WGS 84",
DATUM["WGS_1984",
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",27],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","32635"]]
Origin = (649806.344271000009030,4554888.908224999904633)
Pixel Size = (28.506380857431072,-28.402912233898281)
Metadata:
AREA_OR_POINT=Area
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 649806.344, 4554888.908) ( 28d47'5.17"E, 41d 7'53.36"N)
Lower Left ( 649806.344, 4529752.331) ( 28d46'43.20"E, 40d54'18.59"N)
Upper Right ( 692195.333, 4554888.908) ( 29d17'21.99"E, 41d 7'21.22"N)
Lower Right ( 692195.333, 4529752.331) ( 29d16'53.82"E, 40d53'46.71"N)
Center ( 671000.838, 4542320.620) ( 29d 2'1.11"E, 41d 0'50.97"N)
Band 1 Block=1487x1 Type=Byte, ColorInterp=Red
NoData Value=0
Band 2 Block=1487x1 Type=Byte, ColorInterp=Green
NoData Value=0
Band 3 Block=1487x1 Type=Byte, ColorInterp=Blue
NoData Value=0
Band 4 Block=1487x1 Type=Byte, ColorInterp=Alpha
NoData Value=0
I can't help but blame geoserver for this as 3 other programs displayed it
correctly. Anyone with a clue?
million thanks beforehand
servet
http://old.nabble.com/file/p29562707/scnsht1.jpeg
http://old.nabble.com/file/p29562707/scnsht2.png
View this message in context: http://old.nabble.com/Projection-problem-of-a-gdalwarp-EPSG%3A900913-file-tp29562707p29562707.html
