[Geoserver-users] Projection using geoserve example
Hi everyone.
I have a geoserver on a ubuntu server and it’s pretty nice to test it. But I have a problem using it.
I am making some test with the tazmania example give with the 1.5.3 version of geoserver. I would like to see the “boundaries” shape, in WMS, while I have the yahoo map beneath. I am trying to play with projection, but it seems useless as I don’t see any difference.
  • Do I have to create my map in a particular way (i.e. with a “900913” SRS projection) ?
  • Do I have to modify the data on the server side or is it enough to play with openlayers ?
Here is a part of the code that I have right now :
map = new OpenLayers.Map( $(‘map’) );
OpenLayers.IMAGE_RELOAD_ATTEMPTS = 3;
externalLayer = new OpenLayers.Layer.Yahoo(“Yahoo”, {“sphercialMercator”: true});
map.addLayer(externalLayer);
var tasmaniaTestLayer = new OpenLayers.Layer.WMS( “Tasmania test”, “/geoserver/wms”, {layers: ‘topp:tasmania_state_boundaries’, ‘transparent’: true, format: ‘image/png’, ‘sphericalMercator’: true}, {‘isBaseLayer’: false, projection: “EPSG:900913”} );
map.addLayer(tasmaniaTestLayer);
View this message in context: Projection using geoserve example
Which version of OpenLayers are you using? I think the spherical
mercator stuff was added in 2.5... I could be wrong though. Also have
you seen the following example:
http://svn.openlayers.org/branches/openlayers/2.5/examples/spherical-mercator.html
It might be useful to use this as a starting point. I just tried an
example with tasmania_state_boundaries and it works great.
-Justin
Bakoi wrote:
Hi everyone.
I have a geoserver on a ubuntu server and it's pretty nice to test it.
version of geoserver. I would like to see the "boundaries" shape, in
projection, but it seems useless as I don't see any difference.
    * Do I have to create my map in a particular way (i.e. with a
      "900913" SRS projection) ?
    * Do I have to modify the data on the server side or is it enough to
    map = new OpenLayers.Map( $('map') );
    externalLayer = new OpenLayers.Layer.Yahoo("Yahoo",
    {"sphercialMercator": true});
    var tasmaniaTestLayer = new OpenLayers.Layer.WMS( "Tasmania test",
    "/geoserver/wms", {layers: 'topp:tasmania_state_boundaries',
    'transparent': true, format: 'image/png', 'sphericalMercator':
    true}, {'isBaseLayer': false, projection: "EPSG:900913"} );
<http://www.nabble.com/Projection-using-geoserve-example-tf4711879.html#a13468224&gt;
<http://www.nabble.com/GeoServer---User-f1194.html&gt; at Nabble.com.
!DSPAM:4007,4725ee49263042458217002!
Geoserver-users mailing list
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Thank you Justin.
I am taking a look at this example.
I am using OpenLayers 2.5. I have been forced to use it because I need the
"modify control".
Keep me in touch if you are able to make it works with tazmania example.
-Justin
Bakoi wrote:
Hi everyone.
Justin Deoliveira
View this message in context: http://www.nabble.com/Projection-using-geoserve-example-tf4711879.html#a13471023
