[Geoserver-users] Proposed Issues List Module
Hi guys,
As per the GeoServer Improvement Proposal guidelines, Richard, Pablo, and myself are proposing a module to provide a client service for a shared issues list. An "issue" can be a task or geographical feature which requires attention, but other uses are possible too. uDig will be taking advantage of this service very soon. The implementation will use hibernate to back the list onto a database. Some preliminary details are available (and will be expanded) here:
http://docs.codehaus.org/display/GEOS/GSIP+3+-+Issues+List+Module
Comments and questions are welcome.
Cory.
Hi Cory,
This idea sounds great. I added a comment at the bottom of the page.
Cory Horner wrote:
Hi guys,
Cory.
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
!DSPAM:1004,44e21419280852207481331!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Very Nice Cory :slight_smile:
I am going to take a run at the page, based on the IRC discussion we need define this in a very specific manner.
How ever some quick answers:
- this is not a new service
- makes no use of feature model, or GML
- defines an API to access the same Issue Model used by uDig (based on the shared validation code with GeoServer Transactions)
- the API is made available to client code via Spring remoting
- the API is available to other geoserver modules via Spring
- the first implementation uses hibernate for persistence
I had not thought of story integrating this module with the default GeoServer install (as this is not the point).
The possibility of generating out a list of validation errors from transactions, or listing the validation errors present
in the dataset both sound good.
What I would like this module to do is get people comfortable working together, and explore using the GeoServer
module system as a platform. Doing this using a community module that is available for public review makes this process
easier.
I will be making plenty of commercial modules using GeoServer 1.4.0 as a base, since this is the smallest one of public utility we
can work on from the get go.
Jody
Hi guys,
Cory.
geoserver-devel List Signup and Options
Hey Cory,
Now that I have gone over the page I can have some useful feedback. It seems most of the confusion was in the IRC meeting.
I have added a bit of text to the proposal talking about the motivation for the proposal.
But I think it is time to ask Andrea for some feedback on the IssueList interface itself, since the API is used for Spring Remoting
we need to think about "deep" or "shallow" copy issues. You have this mostly covered with the list of issues (ie shallow) vs individual
issue (deep) accessor methods.
Andrea is there any "traditional" naming conventions we should be following here? Can you run over the page and provide us with
feedback? The only one I can spot right now is the use of a long ID rather then a string, and some note about the horrible equals
method implementation needed for remote api use.
Jody
Hi guys,
Cory.
Sounds great. Community module makes a lot of sense, and yeah, no GSIP
should be needed.
I could see this eventually evolving to something that could be quite
useful for more than just uDig. My vision for GeoServer is 'cvs for the
geospatial web', and it'd be great if this could turn in to something
like 'bugzilla for the geospatial web'.
I'd ideally like to see it available as WFS/WFS-T - though forcing that
as _the_ design is obviously not the right call, especially since
complex features aren't yet available. But ideally we could expose an
interface to viewing and updating the issues through WFS. Then any WFS
client could look to see where there are marked issues on the area of
the map that they care about. It's sort of the flip side of using WFS to
expose a version table/history, in that case you're seeing what's been
modified recently, in the issue case it's to see what needs to be modified.
Would also be very cool to build it in to a transaction workflow - as an
optional plug-in to a transaction. Some users would only have
permission to report an issue, and perhaps attach a 'fix'. It'd then
live in the issue database until someone with commit rights can review
and close the issue. And automatic validation could happen before or
after.
Jody, what's the status with the Hibernate datastore? Wasn't that one
of your work items? Perhaps that could be used just to expose this in a
naive way?
But yes, it's great to see a community module so soon. Also, an
interesting post on small packages:
http://blog.ianbicking.org/why-small-packages-matter.html We should
perhaps start distributing a 'geoserver-core' download, indeed I'd
eventually like to see such a thing as it's own project.
Chris
easier.
Jody
Hi guys,
Cory.
!DSPAM:1003,44e2d0817911665516417!
Chris Holmes
http://topp.openplans.org
By the sounds of it, we can just go ahead and write our module -- it is in the community space and does not require approval, unless one day it wants to be part of the official build. Can Pablo get commit access so he can work on it? It would be handy for myself and Richard to be able to commit as well.
Cory.
should be needed.
cholmes ++
Chris can we have some page constructed please on the care and feeding of community modules? Basically I would like a policy in place
where we accept community modules, and offer svn access for developers building up stuff around GeoServer.
uDig has a very simple policy of "please email the list", and "make a page on the wiki", I see no reason to suggest otherwise for GeoServer. Since this is a project policy does it need a GSIP number?
after.
Now you are thinking :wink:
naive way?
Andrea will be taking it to the geotools community the moment he is off critical path :slight_smile: But it works pretty darn well right now, although we have focused on read only access right now (and obviously only map content into flat features).
Chris we are actually going to have three community proposals "in the pipe" these represent modules needed for our commercial application but are of general interested to the community. So we can "prime the pump" with some well defined (despite email confusion) modules and figure out how to handle such things as svn access, documentation requirements, etc...
Three modules:
- preference module (jesse)
- status module (richard)
- issues module (corey & pablo)
Jody
Hi Jody,
I think your right, we need a process in place. At the same time we
don't want to have people jump through too many hoops. One thing I am
concerned about is just giving people a community module and never
hearing from them again. An example is the preferences store, it was
created and has been inactive for the last month or so, with no docs on
how to use it so it really isn't all that useful to geoserver at the moment.
It would be nice to come up with a way to keep community module
maintainers as close to everyone else as possible. One possible solution
is including community modules in the build bye default. Anyone else
have any ideas.
As for official process, how about having the community module
maintainer do :
1. A GSIP
2. A wiki page with some overview background information
One thing I found when the issues list was proposed is that there was no
information about it, so I was a little reluctant to just say yes. It
doesn't have to be much, I would say perhaps a quick few notes about the
design, and perhaps some of the more interesting implementation details.
-Justin
Jody Garnett wrote:
should be needed.
cholmes ++
after.
naive way?
Three modules:
Jody
!DSPAM:1004,44e9c91b71311410093335!
Justin Deoliveira
Justin Deoliveira wrote:
Hi Jody,
have any ideas.
My concern here would be if the maintainer doesn't maintain and the build gets broken. Also, half finished modules as part of the build.
maintainer do :
1. A GSIP
3. Once it is finished, a 'how-to' and more documentation
4. Test cases?
Use-cases for the module would help a lot too.
-Justin
Brent Owens
(The Open Planning Project)
Jody Garnett wrote:
should be needed.
cholmes ++
after.
naive way?
Three modules:
Jody
Hi Jody,
Heh, well Jesse will be back from holiday / other projects. That module is on a deadline for early September :slight_smile:
have any ideas.
Ack, well having the build fail will keep them close (or will keep people from checking out the community modules (this is what happened with uDig).
maintainer do :
1. A GSIP
Chris just nicked that idea, hense this discussion on how to do a lite process. Note they would do a GSIP if they wanted to be included in the GeoServer release proper. (GSIP == formal GeoServer product as it were).
I like this idea, one other option is to set up a jira for them to track progress. Including the jira issues on the page would be a low effort way of reporting status.
That is mostly my fault :frowning: As an architect I did not have the "big picture" in place for Cory and Pablo to understand what
they were getting into. On the bright side as "guinea pigs" they are flushing out the basic needs the project needs to meet
for this whole idea to be a success.
Jody
Hi Jody,
have any ideas.
I do like the idea of a very low barrier for entry for community modules. I mean, the fact that people put their stuff in a community svn puts them much 'closer' than just developing on their own. And if there are too many requirements for a community module then they'll be more likely to just do it on their own.
So I don't so much like being part of the build as a requirement. But I think they could opt for it if they wanted.
maintainer do :
1. A GSIP
Yeah, and thus should definitely be part of the build. Perhaps we could have 'incubating' modules, that aren't formal GSIP's yet, aren't part of the formal product, but have an intention to be. They would be part of the build to 'prove' that the developers stay close and track what else is going on.
+1 on JIRA. And I like the wiki stuff too. Perhaps people start with a child page of RnD, where their community module starts. This allows them to get feedback about fitting in to the overall architecture. Then they could advance to 'incubating', which would then place them somewhere on the roadmap (even if it's not at a scheduled date). Then it gets refined and gets a GSIP. And of course no modules are required to do this. But we should put a page on the benefits of getting included - attracting more developers, wider pool to help maintain, ect.
Chris
Jody
!DSPAM:1003,44e9d5ee177891804284693!
Chris Holmes
Various people wrote:
1. A GSIP
4. Test cases?
Those are big hoops. Pseudo-reasonable if one expects to have the code in the build, but I don't think this should happen by default. Perhaps there should be 2 procedures: 1 for getting a space to work (commit access), and 1 for getting into the build?
Anyhow, this is interesting guys -- but we've got work to do... are we suitable for commit access?
Cory.
1. A GSIP
4. Test cases?
Yeah, more or less what I proposed as well.
Well, policy in place for commit access is 3 +1's from committers, no -1's. And we can propose commit access for just an area of the code, reserving full commit rights for a later date.
So I'm +1 on Cory and Pablo for commit rights on a issues community module (based on Cory's work on uDig and the fact that they're limited to a community module that's not in the build).
Chris
Cory.
!DSPAM:1003,44ea00b1282438365517736!
Chris Holmes
Fair enough, the GSIP is overkill. I would be happy with just the wiki page.
+1 on commit access.
So go and request to join the geoserver project on xircles.codehaus.org
and let me or jody know so we can accept.
-Justin
1. A GSIP
4. Test cases?
Cory.
!DSPAM:1004,44ea00b1282461116498154!
Justin Deoliveira
I will second that +1, Cory has proved responsible on the geotools and uDig project. And we can get to known Pablo as he works on a community module.
Jody
Chris
Cory.
+1
I agree that there should be a distinction between commit access for a module and for the main build.
Brent Owens
Chris Holmes wrote:
1. A GSIP
4. Test cases?
Chris
Cory.
hehe... now I understand what it is called xircles... I spent 5 minutes trying to find out where to sign up or log-in, but accomplished nothing. Could an esteemed veteran of the labyrinth offer a hint?
Cory.
I will do you one better.
http://docs.codehaus.org/display/GEOSDEV/Getting+Commit+Status
It is still incomplete, as it doesn't state to contact the list first
for permission, etc..
Richard and Cory should now both have commiter status.
-Justin
Cory.
!DSPAM:1004,44ea494f60111410093335!
Justin Deoliveira
Hey, sorry for the late response Jody, have been off and swamped since I've gotten back.
Is our current community stuff sufficient? Did this get resolved enough for you? Or is there more we need in place? Let me know, supporting community modules is a priority for us.
best regards,
Chris
Jody Garnett wrote:
should be needed.
cholmes ++
after.
naive way?
Three modules:
Jody
!DSPAM:1003,44e9c90970111995013331!
Chris Holmes
Well I do not think we wrote it down as policy yet, we just kind of did it. People showed up for meetings, and or emailed the list - and we gave them svn access. Lets treat these first couple community modules as tests and see what we can learn.
I think we need a happy "how to hack" page, much like we have for geotools in the developers guide.
Chris are there any plans for an in person geoserver meeting next week? Or has adrian custer book us all up solid?
Jody
