[Geoserver-users] proxy Server blocks display of map
Suppose I have a web application running from a server that is using geoserver to display map constructed using mapbuilder,
the web application runs just fine but I cannot see the map at all.
My suspicions are that the proxy server at my company is somehow blocking the map display because I can view the map the moment when I am doing so from a public terminal.
How should I advise the security dept in my company so that I can view the map? Are there any particular ports that must be open ?
Thank you.
Regards
Kim Sia
[This e-mail is confidential and may be priviledged. If you are not the
intended recipient, please kindly notify us immediately and delete the message
from your system; please do not copy or use it for any purpose, nor disclose
its contents to any other person. Thank you.]
---ST Electronics Group---
Sim Kim Sia ha scritto:
Well, who is serving the MapBuilder html and javascript? A separate Apache install? Java web containers out of the box do run on 8080,
so that may be the port you have to open, unless of course you configured your web container otherwise.
