[Geoserver-users] Publish a shp file layer with name different from filename
Hi I have loaded the shp file using the curl as given here
http://docs.geoserver.org/stable/en/user/rest/examples/curl.html
but problem is the layer is automatically created with same name as the shp
filename. By appending the "?configure=none" at end of URL I have managed to
stop the auto publishing of layer. Now when I upload a shp file, a store is
created in geoserver.
But when I try to create a layer, I have to use the layer name in curl
command which is same as shp filename.
but if I create the layer from geoserver GUI, I can change the name of the
layer and layer is published with that name. How can I do that using cURL.
Any help..
Regards
Pankaj Bansal
View this message in context: http://osgeo-org.1560.x6.nabble.com/Publish-a-shp-file-layer-with-name-different-from-filename-tp5092501.html
Anyone having any idea please.
Regards
Pankaj Bansal
View this message in context: http://osgeo-org.1560.x6.nabble.com/Publish-a-shp-file-layer-with-name-different-from-filename-tp5092501p5092934.html
Hello,
I guess the only way is to send the REST POST with the full list of properties you need to customize for your layer.
If this still doesn’t work, you need to make two REST steps, POST for the insert and PUT for the update.
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via Poggio alle Viti 1187
mob: +39 331 6233686
On Thu, Dec 5, 2013 at 2:58 PM, pankaj123 <pankaj.bansal.jiit@anonymised.com> wrote:
Regards
Pankaj Bansal
Sponsored by Intel(R) XDK
Develop, test and display web and hybrid apps with a single code base.
Download it for free now!
http://pubads.g.doubleclick.net/gampad/clk?id=111408631&iu=/4140/ostg.clktrk
Geoserver-users mailing list
