What is the best way to publish a single table as two separate layers? Does this required defining a SQL View for one of the layers? It seems like the UI only allows publishing a table as a single layer via the “Publish” mechanism.
On Wed, Apr 22, 2015 at 6:23 PM, Martin Davis <mtnclimb@anonymised.com> wrote:
"Publish" mechanism.
You can re-publish the same table with a different layer name, there is a
"publish again" link the second time around.
SQL views are useful if you want the two layers to have different contents
(different filters in the sql view)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks - I just discovered this thread giving the same advice:
This wasn’t obvious to me from the UI… is it documented in the User Guide?
On Wed, Apr 22, 2015 at 9:36 AM, Andrea Aime <andrea.aime@anonymised.com.1107…> wrote:
You can re-publish the same table with a different layer name, there is a “publish again” link the second time around.
SQL views are useful if you want the two layers to have different contents (different filters in the sql view)
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Apr 22, 2015 at 6:43 PM, Martin Davis <mtnclimb@anonymised.com> wrote:
This wasn't obvious to me from the UI... is it documented in the User
Guide?
Probably not but.... you want to publish two times the same table,
you try to do "add layer" two times...what would have you expected to see
instead?
The doc page where I would have expected to find this would have been this
one:
http://docs.geoserver.org/2.6.x/en/user/webadmin/data/layers.html#add-or-delete-a-layer
Want to make a pull request and add this bit?
Ing. Andrea Aime
@geowolf
Technical Lead
No problem with the workflow knowing that it’s possible to change the layer name. It just would be nice to see a bit of advice about this on the screen (a tooltip maybe - but I don’t think any UI controls have tooltips?).
Agreed, that is the place in the docs for it. I’ll work on adding some doc for this feature there.
On Wed, Apr 22, 2015 at 9:47 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Probably not but… you want to publish two times the same table,
you try to do “add layer” two times…what would have you expected to see instead?
The doc page where I would have expected to find this would have been this one:
Ing. Andrea Aime
@geowolf
Technical Lead
