[Geoserver-users] publish coverage with a different name from the native name
Hi…
This is a weird one.
I try to publish a coverage where
coverage_newname coverage_orginalname ....
url - http://localhost:8080/geoserver/rest/workspaces/AllenProject/coveragestores/圖2/coverages.xml
error - The specified coverageName coverage_newname is not supported
If both name uses coverage_orginalname (original filename) then it would work. I was also able to use geoserver’s interface and create different name as well.
So why does this happen? What do I do so REST will accept a publish a new coverage with different name?
Allen
