[Geoserver-users] publish postgis table which has a raster
Hi Vineendra,
you will have to use a Image Mosaic JDBC store:
http://docs.geoserver.org/stable/en/user/data/raster/postgisraster.html
Best Regards
Message: 1
Date: Tue, 3 Sep 2013 04:43:44 -0700 (PDT)
From: Vineendra <vineendra.sriramoju@anonymised.com>
Subject: [Geoserver-users] publish postgis table which has a raster
  image using rest API services
Message-ID: <1378208624143-5075792.post@anonymised.com>
Content-Type: text/plain; charset=us-ascii
I am storing a thumbnail of an image which represent a large image in the
postgresql database. The size of the image is 1 to 2MB. Now i want to display the image in the database on the map in order to
represent the large image. I want to do this using geoserver REST API
services.
Previously i have published the postgis table which has vector data. How to
do it with raster data in table
Hi Frederik,
Thanks for the reply.
I have followed the tutorial to add a postgis raster to geoserver(which was suggested by you), but i am getting an error.
“Could not list layers for this store, an error occurred retrieving them: Argument “value” should not be null.”
I have followed the tutorial as it is. Every thing went well. But at the end, when i try to use the Image Mosaic JDBC store
Am attaching the screen shot of that error and geoserver log. Please do check them.
Screenshot from 2013-09-04 19:03:03.png
geoserver.log (503 KB)
On Tue, Sep 3, 2013 at 7:09 PM, Frederik Haefker <fhaefker@anonymised.com> wrote:
Hi Vineendra,
Best Regards
Message: 1
From: Vineendra <vineendra.sriramoju@amigooptima.in>
To: geoserver-users@anonymised.comsourceforge.net
Message-ID: <1378208624143-5075792.post@n6.nabble.com>
services.
I had a quick look at the log file.
The problem is that the java image library cannot decode the image data fetched from postgis raster.
Can you send the output of
gdalinfo myimage
Perhaps your image format is not supported.
Christian
On Thu, Sep 5, 2013 at 7:45 AM, Vineendra Sriramoju <vineendra.sriramoju@anonymised.com> wrote:
---------- Forwarded message ----------
From: Vineendra Sriramoju <vineendra.sriramoju@anonymised.com790…>
Date: Wed, Sep 4, 2013 at 7:13 PM
Subject: Re: publish postgis table which has a raster
To: Frederik Haefker <fhaefker@anonymised.com>
Hi Frederik,
Learn the latest–Visual Studio 2012, SharePoint 2013, SQL 2012, more!
Discover the easy way to master current and previous Microsoft technologies
and advance your career. Get an incredible 1,500+ hours of step-by-step
tutorial videos with LearnDevNow. Subscribe today and save!
http://pubads.g.doubleclick.net/gampad/clk?id=58041391&iu=/4140/ostg.clktrk
Geoserver-users mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Hi Vineendra,
Best Regards
Message: 1
services.
Hi Christian,
This is the gdalinfo of the image
Driver: GTiff/GeoTIFF
Files: test.tif
test.tfw
Size is 750, 750
Coordinate System is:
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
SPHEROID[“WGS 84”,6378137,298.257223563,
AUTHORITY[“EPSG”,“7030”]],
AUTHORITY[“EPSG”,“6326”]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433],
AUTHORITY[“EPSG”,“4326”]]
Origin = (79.999583817610983,25.000417126729928)
Pixel Size = (0.006666666666667,-0.006666666666667)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 79.9995838, 25.0004171) ( 79d59’58.50"E, 25d 0’ 1.50"N)
Lower Left ( 79.9995838, 20.0004171) ( 79d59’58.50"E, 20d 0’ 1.50"N)
Upper Right ( 84.9995838, 25.0004171) ( 84d59’58.50"E, 25d 0’ 1.50"N)
Lower Right ( 84.9995838, 20.0004171) ( 84d59’58.50"E, 20d 0’ 1.50"N)
Center ( 82.4995838, 22.5004171) ( 82d29’58.50"E, 22d30’ 1.50"N)
Band 1 Block=750x5 Type=Int16, ColorInterp=Gray
On Thu, Sep 5, 2013 at 7:14 PM, Christian Mueller <christian.mueller@anonymised.com> wrote:
gdalinfo myimage
Christian
On Thu, Sep 5, 2013 at 7:45 AM, Vineendra Sriramoju <vineendra.sriramoju@anonymised.com90…> wrote:
From: Vineendra Sriramoju <vineendra.sriramoju@anonymised.com>
Hi Frederik,
Hi Vineendra,
Best Regards
Message: 1
services.
Do you have the possibility to write a tiny java program reading the image from the file system and writing it back for testing.
If not, can you send me a small sample image extracted with the gdal utilities. I can make the test.
Christian
On Thu, Sep 5, 2013 at 4:55 PM, Vineendra Sriramoju <vineendra.sriramoju@anonymised.com…5790…> wrote:
Hi Christian,
Files: test.tif
test.tfw
Size is 750, 750
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
Metadata:
AREA_OR_POINT=Area
INTERLEAVE=BAND
Corner Coordinates:
gdalinfo myimage
Christian
Hi Frederik,
Hi Vineendra,
Best Regards
Message: 1
services.
On Thu, Sep 5, 2013 at 8:38 PM, Christian Mueller <
Christian
Hi Christian,
Files: test.tif
       test.tfw
Size is 750, 750
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0],
    UNIT["degree",0.0174532925199433],
    AUTHORITY["EPSG","4326"]]
Metadata:
  AREA_OR_POINT=Area
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 79.9995838, 25.0004171) ( 79d59'58.50"E, 25d 0' 1.50"N)
Lower Left ( 79.9995838, 20.0004171) ( 79d59'58.50"E, 20d 0' 1.50"N)
Upper Right ( 84.9995838, 25.0004171) ( 84d59'58.50"E, 25d 0' 1.50"N)
Lower Right ( 84.9995838, 20.0004171) ( 84d59'58.50"E, 20d 0' 1.50"N)
Center ( 82.4995838, 22.5004171) ( 82d29'58.50"E, 22d30' 1.50"N)
gdalinfo myimage
Christian
Hi Frederik,
"Could not list layers for this store, an error occurred retrieving
them: Argument "value" should not be null."
check them.
On Tue, Sep 3, 2013 at 7:09 PM, Frederik Haefker <fhaefker@anonymised.com>wrote:
Hi Vineendra,
http://docs.geoserver.org/**stable/en/user/data/raster/**
postgisraster.html<http://docs.geoserver.org/stable/en/user/data/raster/postgisraster.html&gt;
Best Regards
Message: 1
From: Vineendra <vineendra.sriramoju@**amigooptima.in<vineendra.sriramoju@anonymised.com>
To: geoserver-users@anonymised.com**sourceforge.net<geoserver-users@lists.sourceforge.net>
Message-ID: <1378208624143-5075792.post@**n6.nabble.com<1378208624143-5075792.post@anonymised.com>
the
services.
How to
Learn the latest--Visual Studio 2012, SharePoint 2013, SQL 2012, more!
technologies
image.zip (659 KB)
Hi Vineendra
Found the reason, look at http://jira.codehaus.org/browse/GEOT-4561
The problem is fixed on geotools 10.x series and will be available in geotools version 10.0 (geoserver version 2.4.0).
I will send you a jar file in a private mail for testing.
Christian
On Fri, Sep 6, 2013 at 8:19 AM, Vineendra Sriramoju <vineendra.sriramoju@anonymised.com> wrote:
On Thu, Sep 5, 2013 at 8:38 PM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Christian
On Thu, Sep 5, 2013 at 4:55 PM, Vineendra Sriramoju <vineendra.sriramoju@anonymised.com> wrote:
Hi Christian,
Files: test.tif
test.tfw
Size is 750, 750
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
Metadata:
AREA_OR_POINT=Area
INTERLEAVE=BAND
Corner Coordinates:
On Thu, Sep 5, 2013 at 7:14 PM, Christian Mueller <christian.mueller@anonymised.com45…> wrote:
gdalinfo myimage
Christian
Hi Frederik,
Hi Vineendra,
Best Regards
Message: 1
services.
