[Geoserver-users] Publishing pyramid to geoserver
Dear all
I want to publish programmatically a pyramid to geoserver. Once zipped the file is about 11GB.
For that I am using httpclient in groovy using the following code:
method = new PutMethod(“http://myhost:8080/geoserver/rest/workspaces/pf/coveragestores/129images/file.imagepyramid?coverageName=129images”)
requestEntity = new FileRequestEntity(new File(localUri), “application/zip”)
method.setRequestEntity(requestEntity)
status = client.executeMethod(method)
this hangs. No message!
When I try using curl locally, I got this message:
curl -u admin:geoserver -v -XPUT -H “Content-type: application/zip” --data-binary @/mnt/tmp/pyramids.zip http://localhost:8080/geoserver/rest/workspaces/pf/coveragestores/129images/file.imagepyramid
curl: option --data-binary: out of memory
curl: try ‘curl --help’ or ‘curl --manual’ for more information
I was suspecting that curl was trying to load the 11GB file (which is a bad idea) therefore I tried this:
curl -u admin:geoserver -v -XPUT -H “Content-type: application/zip” --header “Transfer-Encoding: chunked” --data-binary @/mnt/tmp/pyramids.zip http://localhost:8080/geoserver/rest/workspaces/pf/coveragestores/129images/file.imagepyramid
but get the same error.
Is there something I should do differently ?
Best Regards
Guillaume
PGP KeyID: 2048R/EA31CFC9 subkeys.pgp.net
Curl goes out of memory because it tries to load all the file in memory.
I didn’ t tested it, but you can try to use the -T option ( this allows to do this transfer in streaming.
Check the man page of curl for details .
Lorenzo
Il 19/nov/2013 18:07 “tog” <guillaume.alleon@anonymised.com> ha scritto:
Dear all
Best Regards
Guillaume
Shape the Mobile Experience: Free Subscription
Software experts and developers: Be at the forefront of tech innovation.
Intel(R) Software Adrenaline delivers strategic insight and game-changing
conversations that shape the rapidly evolving mobile landscape. Sign up now.
http://pubads.g.doubleclick.net/gampad/clk?id=63431311&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Ciao Guillame.
is it a requirement to upload a 11gb to the server?
The best option would be to place the file somewhere where it is
reachable and then use the "external" method
which does not perform an upload.
Check the REST docs for this.
Simone Giannecchini
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Tue, Nov 19, 2013 at 5:00 PM, tog <guillaume.alleon@anonymised.com> wrote:
Dear all
file is about 11GB.
method = new
PutMethod("http://myhost:8080/geoserver/rest/workspaces/pf/coveragestores/129images/file.imagepyramid?coverageName=129images&quot;\)
"application/zip")
curl -u admin:geoserver -v -XPUT -H "Content-type: application/zip"
curl: try 'curl --help' or 'curl --manual' for more information
curl -u admin:geoserver -v -XPUT -H "Content-type: application/zip" --header
"Transfer-Encoding: chunked" --data-binary @/mnt/tmp/pyramids.zip
Best Regards
Guillaume
Hi Simone
Thanks for the answer.
Yep I need to transfer my mosaic to the server :wink:
I was indeed contemplating 2 options:
option1: upload the file to the server using REST api …/file.imagepyramid
option2: as you suggest in 2 phases:
  • upload the file on an accessible filesystem
  • use the REST api that will use the local zip file
  • delete the uploaded file
I thought option 1 was simpler (for info an scp just take 6mn).
Any idea/explaination why option 1 is not that good ?
Regards
Guillaume
On Wed, Nov 20, 2013 at 8:25 AM, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Ciao Guillame.
reachable and then use the “external” method
Simone Giannecchini
more information.
@simogeo
Founder/Director
Dear all
file is about 11GB.
method = new
“application/zip”)
–data-binary @/mnt/tmp/pyramids.zip
Best Regards
Guillaume
Update:
Apparently even though the POST does not return on the client side … the pyramid gets published.
Nevertheless the log shows the following. Any comment ?
Guillaume
2013-11-20 03:19:12,830 ERROR [geoserver.rest] - No such workspace: 6c6cfbfc
org.geoserver.rest.RestletException
at org.geoserver.catalog.rest.WorkspaceFinder.findTarget(WorkspaceFinder.java:33)
at org.restlet.Finder.handle(Finder.java:268)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:37)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:204)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:86)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:201)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
at com.thetransactioncompany.cors.CORSFilter.doFilter(CORSFilter.java:168)
at com.thetransactioncompany.cors.CORSFilter.doFilter(CORSFilter.java:233)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:224)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:169)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:927)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:987)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:579)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:307)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:744)
2013-11-20 03:19:12,934 INFO [catalog.rest] - POST workspace 6c6cfbfc
2013-11-20 03:19:12,950 INFO [org.geoserver] - Loaded store ‘QL’, enabled
2013-11-20 03:19:12,954 INFO [catalog.rest] - POST coverage store QL
2013-11-20 03:19:12,988 INFO [catalog.rest] - PUT file, mimetype: application/zip
2013-11-20 03:28:19,682 INFO [catalog.rest] - Using existing coverage store: QL
2013-11-20 03:29:51,913 WARN [geoserver.web] - Unable to find property: ‘format.wms.application/vnd.google-earth.kmz xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2013-11-20 03:29:51,914 WARN [geoserver.web] - Unable to find property: ‘format.wms.application/vnd.google-earth.kmz’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2013-11-20 03:29:51,914 WARN [geoserver.web] - Unable to find property: ‘format.wms.kmz’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2013-11-20 03:29:51,914 WARN [geoserver.web] - Unable to find property: ‘format.wms.image/png; mode=8bit’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2013-11-20 03:29:51,914 WARN [geoserver.web] - Unable to find property: ‘format.wms.openlayers’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2013-11-20 03:29:51,914 WARN [geoserver.web] - Unable to find property: ‘format.wms.text/html’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2013-11-20 03:29:51,914 WARN [geoserver.web] - Unable to find property: ‘format.wms.atom’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2013-11-20 03:29:51,914 WARN [geoserver.web] - Unable to find property: ‘format.wms.application/atom xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2013-11-20 03:29:51,914 WARN [geoserver.web] - Unable to find property: ‘format.wms.application/xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2013-11-20 03:29:51,914 WARN [geoserver.web] - Unable to find property: ‘format.wms.image/svg’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2013-11-20 03:29:51,914 WARN [geoserver.web] - Unable to find property: ‘format.wms.image/svg xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2013-11-20 03:29:51,915 WARN [geoserver.web] - Unable to find property: ‘format.wfs.application/vnd.google-earth.kml xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2013-11-20 03:29:51,915 WARN [geoserver.web] - Unable to find property: ‘format.wfs.KML’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2013-11-20 03:29:51,916 WARN [geoserver.web] - Unable to find property: ‘format.wfs.KML’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2013-11-20 03:29:51,916 WARN [geoserver.web] - Unable to find property: ‘format.wfs.application/vnd.google-earth.kml xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2013-11-20 03:29:51,916 WARN [geoserver.web] - Unable to find property: ‘format.wfs.application/json’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2013-11-20 03:29:51,917 WARN [geoserver.web] - Unable to find property: ‘format.wfs.application/vnd.google-earth.kml xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2013-11-20 03:29:51,917 WARN [geoserver.web] - Unable to find property: ‘format.wfs.application/json’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
2013-11-20 03:29:52,162 WARN [imagemosaic.catalog] - This granule catalog was not properly dispose as it still points to:ServiceInfo
description=Features from ShapefileDataStore
2013-11-20 03:30:01,276 INFO [geoserver.wms] -
Request: getServiceInfo
2013-11-20 03:30:01,329 INFO [geoserver.wms] -
On Wed, Nov 20, 2013 at 8:36 AM, tog <guillaume.alleon@anonymised.com> wrote:
Hi Simone
Regards
Guillaume
Ciao Guillame.
Simone Giannecchini
more information.
@simogeo
Founder/Director
Dear all
file is about 11GB.
method = new
“application/zip”)
Best Regards
Guillaume
about CURL:
I didn’ t tested it, but you can try to use the -T option ( this allows to do this transfer in streaming)
About Alternative solutions:
Using the 2nd option you have a better control of the upload phase, and you can also think to transfer files chunked (I think that scp is better for this kind of transfers) .
Furthermore big files like the one you’re are using needs to be sent and saved in streaming, so the problems you encountered using curl can recur even server side.
Using dedicated systems to transfer big files is better in general.
You can use the PUT method of the ReST interface for smaller files.
About the error:
POST is allowed only for xml, not for file transfer (see http://docs.geoserver.org/stable/en/user/rest/api/index.html ).
If you were using the POST method in that way, the error seems like the request is not well formed (No such workspace: 6c6cfbfc) . Anyway I couldn’t see the original request.
Lorenzo
2013/11/20 tog <guillaume.alleon@anonymised.com>
Update:
Guillaume
more information.
Lorenzo Natali
Dott. Ing. Lorenzo Natali
@lorenzonatali
Software Engineer
Hi Simone
Regards
Guillaume
Ciao Guillame.
Simone Giannecchini
more information.
@simogeo
Founder/Director
Dear all
file is about 11GB.
method = new
“application/zip”)
Best Regards
Guillaume
Hi Lorenzo
Well actually curl is not really an option I used it in a command line when my http client hanged in order to check if I could get more info on what was happening.
The POST error you have seen results from a request we do to check if a workspace exists. If we get a 404 it means we need to create the workspace. There might be a better way to do that :slight_smile:
Actually the PUT method using httpclient works and the pyramid gets published.
method = new PutMethod(“${scheme}://${host}:${port}/geoserver/rest/workspaces/${workspace}/coveragestores/${prefix}/${uploadMethod}.imagepyramid?coverageName=${prefix}”)requestEntity = new FileRequestEntity(new File(localUri), “application/zip”)
Apparently the code is blocked in the last statement ( client.executeMethod(method) ) - at least this is what jdb says.
How could I see that everything went well on the server side and that geoserver sent back a status ?
Working in the cloud I am a bit reluctant in opening too much port so currently instead of putting in place a new server that will receive the zip file, we are investigating if we could not have a WPS taking care of that.
Actually we have in mind of implementing 2 WPS:
  • one will receive the level 0 tif files of my future pyramid
  • the second one will call gdal_retile / gdaladdo
Any comments welcome.
Regards
Guillaume
On Wed, Nov 20, 2013 at 3:46 PM, Lorenzo Natali <lorenzo.natali@anonymised.com> wrote:
about CURL:
About the error:
Lorenzo
Update:
Guillaume
more information.
Lorenzo Natali
@lorenzonatali
Software Engineer
Hi Simone
Regards
Guillaume
Ciao Guillame.
Simone Giannecchini
more information.
@simogeo
Founder/Director
Dear all
file is about 11GB.
method = new
“application/zip”)
Best Regards
Guillaume
