[Geoserver-users] Publishing Raster data from PostGres-Table
Hey Guys,
I am trying to publish raster-data from my Postgres-Table. I am
currently using MapServer as I could not find a working solution to use
geoserver, but the MapServer is pretty slow and I prefer GeoServer for
other layers etc. and thus would like to know if someone has a working
example using geoserver?
Thanks in advance,
Felix
What have you tried? What doesn’t work? What does the log file say?
Ian Turton
Hi Felix,
while I have never tried it out, there is a community module that should allow publishing rasters from within PostgreSQL databases:
https://docs.geoserver.org/main/en/user/community/pgraster/pgraster.html
Mind, it’s unsupported, and I know nobody using it. Storing rasters in databases never became popular, as far as I know,
it’s a good idea if you want to perform spatial analysis inside the DB, but for map rendering, better keep your data in
well optimized GeoTIFF files instead.
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
