[Geoserver-users] Purpose of TOWGS
In the description of how to create a custom projection, there is something labeled TOWGS. What is this?
Bursa Wolf transform parameters needed to go from one ellipsoid
to the reference one, WGS84 (thus "to WGS").
You don't need them if your reference system is based on the WGS84
ellipsoid, otherwise they are needed if you need to perform a transform
between your CRS and another specified with a different ellipsoid.
See also:
http://udig.refractions.net/docs/api-geotools/org/geotools/referencing/datum/BursaWolfParameters.html
Hope this helps
