[Geoserver-users] Python Extension BeanCreationException
Hello,
I am trying to install the Python Extension, but I get several
BeanCreationExceptions. Any suggestions?
I am using GeoServer 2.7.0 with Tomcat 8.0.14 and Apache 2.4.10 on Debian 8.0
Thank you,
Martin
Here is my complete log:
2015-03-26 11:35:43,261 INFO [geoserver.global] - Falling back to
embedded data directory: /var/lib/tomcat8/webapps/geoserver27/data
2015-03-26 11:35:43,490 INFO [org.geoserver] - Loaded style 'rain'
2015-03-26 11:35:43,494 INFO [org.geoserver] - Loaded style 'capitals'
2015-03-26 11:35:43,498 INFO [org.geoserver] - Loaded style 'tiger_roads'
2015-03-26 11:35:43,502 INFO [org.geoserver] - Loaded style 'poi'
2015-03-26 11:35:43,506 INFO [org.geoserver] - Loaded style 'simple_streams'
2015-03-26 11:35:43,511 INFO [org.geoserver] - Loaded style 'cite_lakes'
2015-03-26 11:35:43,516 INFO [org.geoserver] - Loaded style 'green'
2015-03-26 11:35:43,522 INFO [org.geoserver] - Loaded style 'grass'
2015-03-26 11:35:43,528 INFO [org.geoserver] - Loaded style 'giant_polygon'
2015-03-26 11:35:43,533 INFO [org.geoserver] - Loaded style 'line'
2015-03-26 11:35:43,537 INFO [org.geoserver] - Loaded style 'poly_landmarks'
2015-03-26 11:35:43,541 INFO [org.geoserver] - Loaded style 'raster'
2015-03-26 11:35:43,544 INFO [org.geoserver] - Loaded style 'dem'
2015-03-26 11:35:43,548 INFO [org.geoserver] - Loaded style 'simple_roads'
2015-03-26 11:35:43,551 INFO [org.geoserver] - Loaded style 'population'
2015-03-26 11:35:43,556 INFO [org.geoserver] - Loaded style 'burg'
2015-03-26 11:35:43,562 INFO [org.geoserver] - Loaded style 'point'
2015-03-26 11:35:43,567 INFO [org.geoserver] - Loaded style 'pophatch'
2015-03-26 11:35:43,572 INFO [org.geoserver] - Loaded style 'polygon'
2015-03-26 11:35:43,575 INFO [org.geoserver] - Loaded style 'restricted'
2015-03-26 11:35:43,575 INFO [org.geoserver] - Loaded default workspace topp
2015-03-26 11:35:43,581 INFO [org.geoserver] - Loaded workspace 'topp'
2015-03-26 11:35:43,588 INFO [org.geoserver] - Loaded workspace 'cite'
2015-03-26 11:35:43,596 INFO [org.geoserver] - Loaded workspace 'sf'
2015-03-26 11:35:43,604 INFO [org.geoserver] - Loaded workspace 'tiger'
2015-03-26 11:35:43,611 INFO [org.geoserver] - Loaded workspace 'sde'
2015-03-26 11:35:43,618 INFO [org.geoserver] - Loaded workspace 'nurc'
2015-03-26 11:35:43,671 INFO [org.geoserver] - Loaded workspace
'it.geosolutions'
2015-03-26 11:35:43,682 INFO [org.geoserver] - Loaded store
'taz_shapes', enabled
2015-03-26 11:35:43,689 INFO [org.geoserver] - Loaded data store 'taz_shapes'
2015-03-26 11:35:44,319 INFO [org.geoserver] - Loaded feature type
'tasmania_cities', enabled
2015-03-26 11:35:44,328 INFO [org.geoserver] - Loaded feature type 'taz_shapes'
2015-03-26 11:35:44,345 INFO [org.geoserver] - Loaded layer 'tasmania_cities'
2015-03-26 11:35:44,349 INFO [org.geoserver] - Loaded feature type
'tasmania_water_bodies', enabled
2015-03-26 11:35:44,352 INFO [org.geoserver] - Loaded feature type 'taz_shapes'
2015-03-26 11:35:44,356 INFO [org.geoserver] - Loaded layer
2015-03-26 11:35:44,359 INFO [org.geoserver] - Loaded feature type
'tasmania_state_boundaries', enabled
2015-03-26 11:35:44,361 INFO [org.geoserver] - Loaded feature type 'taz_shapes'
2015-03-26 11:35:44,364 INFO [org.geoserver] - Loaded layer
2015-03-26 11:35:44,367 INFO [org.geoserver] - Loaded feature type
'tasmania_roads', enabled
2015-03-26 11:35:44,369 INFO [org.geoserver] - Loaded feature type 'taz_shapes'
2015-03-26 11:35:44,371 INFO [org.geoserver] - Loaded layer 'tasmania_roads'
2015-03-26 11:35:44,373 INFO [org.geoserver] - Loaded store
'states_shapefile', enabled
2015-03-26 11:35:44,374 INFO [org.geoserver] - Loaded data store
'states_shapefile'
2015-03-26 11:35:44,401 INFO [org.geoserver] - Loaded feature type
'states', enabled
2015-03-26 11:35:44,403 INFO [org.geoserver] - Loaded feature type
'states_shapefile'
2015-03-26 11:35:44,405 INFO [org.geoserver] - Loaded layer 'states'
2015-03-26 11:35:44,407 INFO [org.geoserver] - Loaded store 'sf', enabled
2015-03-26 11:35:44,408 INFO [org.geoserver] - Loaded data store 'sf'
2015-03-26 11:35:44,671 INFO [org.geoserver] - Loaded feature type
'streams', enabled
2015-03-26 11:35:44,674 INFO [org.geoserver] - Loaded feature type 'sf'
2015-03-26 11:35:44,678 INFO [org.geoserver] - Loaded layer 'streams'
2015-03-26 11:35:44,682 INFO [org.geoserver] - Loaded feature type
'restricted', enabled
2015-03-26 11:35:44,687 INFO [org.geoserver] - Loaded feature type 'sf'
2015-03-26 11:35:44,693 INFO [org.geoserver] - Loaded layer 'restricted'
2015-03-26 11:35:44,698 INFO [org.geoserver] - Loaded feature type
'roads', enabled
2015-03-26 11:35:44,703 INFO [org.geoserver] - Loaded feature type 'sf'
2015-03-26 11:35:44,709 INFO [org.geoserver] - Loaded layer 'roads'
2015-03-26 11:35:44,714 INFO [org.geoserver] - Loaded feature type
'archsites', enabled
2015-03-26 11:35:44,717 INFO [org.geoserver] - Loaded feature type 'sf'
2015-03-26 11:35:44,720 INFO [org.geoserver] - Loaded layer 'archsites'
2015-03-26 11:35:44,724 INFO [org.geoserver] - Loaded feature type
'bugsites', enabled
2015-03-26 11:35:44,727 INFO [org.geoserver] - Loaded feature type 'sf'
2015-03-26 11:35:44,731 INFO [org.geoserver] - Loaded layer 'bugsites'
2015-03-26 11:35:44,734 INFO [org.geoserver] - Loaded store 'sfdem', enabled
2015-03-26 11:35:44,739 INFO [org.geoserver] - Loaded coverage store 'sfdem'
2015-03-26 11:35:44,761 INFO [org.geoserver] - Loaded coverage 'sfdem', enabled
2015-03-26 11:35:44,769 INFO [org.geoserver] - Loaded coverage 'sfdem'
2015-03-26 11:35:44,773 INFO [org.geoserver] - Loaded layer 'sfdem'
2015-03-26 11:35:44,778 INFO [org.geoserver] - Loaded store 'nyc', enabled
2015-03-26 11:35:44,781 INFO [org.geoserver] - Loaded data store 'nyc'
2015-03-26 11:35:44,802 INFO [org.geoserver] - Loaded feature type
'poly_landmarks', enabled
2015-03-26 11:35:44,804 INFO [org.geoserver] - Loaded feature type 'nyc'
2015-03-26 11:35:44,808 INFO [org.geoserver] - Loaded layer 'poly_landmarks'
2015-03-26 11:35:44,812 INFO [org.geoserver] - Loaded feature type
'poi', enabled
2015-03-26 11:35:44,816 INFO [org.geoserver] - Loaded feature type 'nyc'
2015-03-26 11:35:44,820 INFO [org.geoserver] - Loaded layer 'poi'
2015-03-26 11:35:44,824 INFO [org.geoserver] - Loaded feature type
'giant_polygon', enabled
2015-03-26 11:35:44,828 INFO [org.geoserver] - Loaded feature type 'nyc'
2015-03-26 11:35:44,831 INFO [org.geoserver] - Loaded layer 'giant_polygon'
2015-03-26 11:35:44,833 INFO [org.geoserver] - Loaded feature type
'tiger_roads', enabled
2015-03-26 11:35:44,836 INFO [org.geoserver] - Loaded feature type 'nyc'
2015-03-26 11:35:44,840 INFO [org.geoserver] - Loaded layer 'tiger_roads'
2015-03-26 11:35:44,843 INFO [org.geoserver] - Loaded store 'mosaic', enabled
2015-03-26 11:35:44,845 INFO [org.geoserver] - Loaded coverage store 'mosaic'
2015-03-26 11:35:44,852 INFO [org.geoserver] - Loaded coverage 'mosaic', enabled
2015-03-26 11:35:44,859 INFO [org.geoserver] - Loaded coverage 'mosaic'
2015-03-26 11:35:44,865 INFO [org.geoserver] - Loaded layer 'mosaic'
2015-03-26 11:35:44,867 INFO [org.geoserver] - Loaded store
'img_sample2', disabled
2015-03-26 11:35:44,869 INFO [org.geoserver] - Loaded coverage store
'img_sample2'
2015-03-26 11:35:44,884 INFO [org.geoserver] - Loaded coverage
'Pk50095', disabled
2015-03-26 11:35:44,887 INFO [org.geoserver] - Loaded coverage 'img_sample2'
2015-03-26 11:35:44,890 INFO [org.geoserver] - Loaded layer 'Pk50095'
2015-03-26 11:35:44,893 INFO [org.geoserver] - Loaded store
'arcGridSample', enabled
2015-03-26 11:35:44,895 INFO [org.geoserver] - Loaded coverage store
'arcGridSample'
2015-03-26 11:35:44,898 INFO [org.geoserver] - Loaded coverage
'Arc_Sample', enabled
2015-03-26 11:35:44,900 INFO [org.geoserver] - Loaded coverage 'arcGridSample'
2015-03-26 11:35:44,903 INFO [org.geoserver] - Loaded layer 'Arc_Sample'
2015-03-26 11:35:44,907 INFO [org.geoserver] - Loaded store
'worldImageSample', enabled
2015-03-26 11:35:44,911 INFO [org.geoserver] - Loaded coverage store
'worldImageSample'
2015-03-26 11:35:44,915 INFO [org.geoserver] - Loaded coverage
'Img_Sample', enabled
2015-03-26 11:35:44,919 INFO [org.geoserver] - Loaded coverage
'worldImageSample'
2015-03-26 11:35:44,922 INFO [org.geoserver] - Loaded layer 'Img_Sample'
2015-03-26 11:35:44,930 INFO [org.geoserver] - Loaded layer group 'tiger-ny'
2015-03-26 11:35:44,934 INFO [org.geoserver] - Loaded layer group 'spearfish'
2015-03-26 11:35:44,937 INFO [org.geoserver] - Loaded layer group 'tasmania'
2015-03-26 11:35:44,972 WARN [support.DisposableBeanAdapter] -
Invocation of destroy method failed on bean with name
'geoServerLoader': java.lang.NullPointerException
2015-03-26 11:35:44,973 ERROR [context.ContextLoader] - Context
initialization failed
org.springframework.beans.factory.BeanCreationException: Error
creating bean with name 'wcs111ServiceTarget' defined in URL
[jar:file:/var/lib/tomcat8/webapps/geoserver27/WEB-INF/lib/gs-wcs1_1-2.7.0.jar!/applicationContext.xml]:
Cannot resolve reference to bean 'geoServer' while setting constructor
argument; nested exception is
creating bean with name 'geoServer' defined in URL
[jar:file:/var/lib/tomcat8/webapps/geoserver27/WEB-INF/lib/gs-main-2.7.0.jar!/applicationContext.xml]:
Cannot resolve reference to bean 'catalog' while setting bean property
'catalog'; nested exception is
creating bean with name 'localWorkspaceCatalog' defined in URL
Cannot resolve reference to bean 'advertisedCatalog' while setting
constructor argument; nested exception is
creating bean with name 'advertisedCatalog' defined in URL
Cannot resolve reference to bean 'secureCatalog' while setting
creating bean with name 'secureCatalog' defined in URL
Instantiation of bean failed; nested exception is
org.springframework.beans.BeanInstantiationException: Could not
instantiate bean class [org.geoserver.security.SecureCatalogImpl]:
Constructor threw exception; nested exception is
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:329)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:107)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:630)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:148)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1035)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:939)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:607)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:925)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:472)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:388)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:293)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:23)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4797)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5221)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:724)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:700)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:714)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:919)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1703)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
at java.util.concurrent.FutureTask.run(FutureTask.java:262)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.springframework.beans.factory.BeanCreationException:
Error creating bean with name 'geoServer' defined in URL
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1360)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1118)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:517)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:323)
... 31 more
Error creating bean with name 'localWorkspaceCatalog' defined in URL
... 41 more
Error creating bean with name 'advertisedCatalog' defined in URL
... 53 more
Error creating bean with name 'secureCatalog' defined in URL
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:288)
... 65 more
Caused by: org.springframework.beans.BeanInstantiationException: Could
not instantiate bean class [org.geoserver.security.SecureCatalogImpl]:
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:162)
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:121)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:280)
... 74 more
Caused by: java.lang.NullPointerException
at org.geoserver.security.impl.DefaultResourceAccessManager.buildAuthorizationTree(DefaultResourceAccessManager.java:140)
at org.geoserver.security.impl.DefaultResourceAccessManager.<init>(DefaultResourceAccessManager.java:87)
at org.geoserver.security.SecureCatalogImpl.buildDefaultResourceAccessManager(SecureCatalogImpl.java:108)
at org.geoserver.security.SecureCatalogImpl.lookupResourceAccessManager(SecureCatalogImpl.java:96)
at org.geoserver.security.SecureCatalogImpl.<init>(SecureCatalogImpl.java:80)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:526)
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:147)
... 76 more
