Is it possible to enforce viewing a particular (bbox) extent within a GS
WMS Layer ?
That is: I have feature data covering the entire Netherlands, but for this
layer I only need to serve a particular (inner) bbox without showing data
outside of that bbox. I can set a bbox in the FeatureType Editor, but GS
always will serve the according to the extent of the dataset not the
(inner) bbox. (btw UMN MapServer will do the same). thanks,
Just van den Broecke
http://www.justobjects.nl
I believe the WMS specs demand it.
If you have a client that can do tiling you can use the built-in GeoWebCache. It will just serve the same, transparent PNG for anything falling outside the bounds.
-Arne
Just van den Broecke wrote:
WMS Layer ?
Register Now & Save for Velocity, the Web Performance & Operations Conference from O'Reilly Media. Velocity features a full day of expert-led, hands-on workshops and two days of sessions from industry leaders in dedicated Performance & Operations tracks. Use code vel09scf and Save an extra 15% before 5/3. http://p.sf.net/sfu/velocityconf
Geoserver-users mailing list
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
