[Geoserver-users] Qgis generated sld and geoserver 2.7
Is there an alternative way to create great looking complex SLDs for
GeoServer?
I would second this - the lack of QGIS integration is a thorny issue. I did
manage to get AtlasStyler to smei-function, but it seems the latest version
of Java has broken it permanently - lack of a manifest or something. Is
there any possiblity of getting a new version of Atlas?
Michael
On Mon, May 11, 2015 at 5:50 AM, Michael Patrick <geodesy99@anonymised.com>
GeoServer?
did manage to get AtlasStyler to smei-function, but it seems the latest
version of Java has broken it permanently - lack of a manifest or
something. Is there any possiblity of getting a new version of Atlas?
Atlas development stopped years ago. There is uDig out there that generates
valid SLD files (that is, stuff that is actually SLD according to the spec,
unlike what QGis generates)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
GeoServer?
Btw, I got frustrated me too about QGis inability to generate valid SLD (I
mean, to me they are not even trying, these
kind of errors can be found by a simple schema validation tool, stuff that
anyone working with XML has handy),
and I thought, well, if they are not going to maintain SLD export
correctly, they at least have to maintain
correctly their project file, and was fancying creating a import tool that
would parse it instead.
Sure, it will change over time, but at least, we could maintain this
importer, while I believe none of the
current GeoServer devs has enough experience in C++ and python to look at
the SLD export (I did
search for it in the qgis code, cannot even find where it's done...).
That said... it did not happen due to lack of resources/funding, it's no
small batch of work either...
Ing. Andrea Aime
@geowolf
Technical Lead
