[Geoserver-users] query on postgis-raster layer.
Hello,
I want to query on postgis-raster layer.
Can you give me a hint about doing this?
regards
Ahmet Temiz
Jeoloji Müh.
Afet ve Acil Durum Yönetimi Başkanlığı
Bilgi İşlem Dairesi Başkanlığı-CBS Grubu
Ahmet Temiz
Geological Eng.
Information Systems - GIS Group
Disaster and Emergency Management
of Presidency
2015-05-02 8:45 GMT+02:00 Ahmet Temiz <ahmettemiz88@anonymised.com>:
Hello,
What do you mean by "query"? Check what's the value in single point?
Extract a subset of the raster?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
thank you ,
subset,
say, I have DEM from which I am trying the pixels values bigger than 100.
DEM values >100 areas
regards
On Sat, May 2, 2015 at 11:52 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hello,
What do you mean by “query”? Check what’s the value in single point?
Ing. Andrea Aime
@geowolf
Technical Lead
Ahmet Temiz
Jeoloji Müh.
Ahmet Temiz
Geological Eng.
of Presidency
On Sat, May 2, 2015 at 2:27 PM, Ahmet Temiz <ahmettemiz88@anonymised.com> wrote:
thank you ,
subset,
If this is a pure visualization thing, you can create a SLD style that uses
a color map
in interval mode, that will make it display the values above 100 (have the
other values
use transparency so that they will not display):
http://docs.geoserver.org/stable/en/user/styling/sld-cookbook/rasters.html#discrete-colors
If instead you want to download the data that answers that question, we
currently have no
out of the box way to support that.
The two natural ways in OGC protocols are:
* WCPS, a mix of WCS and WPS that we currently do not support
* WPS with a process that can answer that kind of comparison, which we do
not have
  in releases... there is a pull request with a process that imho should be
able to
  do that, but it has been in incomplete state for quite a while:
  https://github.com/geotools/geotools/pull/534
Ing. Andrea Aime
@geowolf
Technical Lead
