[Geoserver-users] Query Regarding URL pattern to access WMS Request
Hi Team,
I have checked documents of Geoserver and found many URL pattern to access WMS Request like below:
http:///geoserver/wms?
http:///geoserver//wms?
http:///geoserver/ows?
http:///geoserver//ows?
http:///geoserver/gwc/service/wms?
http:///geoserver//gwc/service/wms?
http:///geoserver/wms/wms?
http:///geoserver//wms/wms?
http:///geoserver/gwc/service/wms//wms?
http:///geoserver//gwc/service/wms//wms?
http:///geoserver/wms/kml?
http:///geoserver//wms/kml?
http:///geoserver/wms/reflect?
http:///geoserver//wms/reflect?
But I could not ensure that if these are the only URL pattern or there are still more, as all the URL pattern found in different documents.
[Query]
Is there any document which contains all URL pattern to access WMS Request?
Thanks & Regards,
Madhu
There is no such document; but it is a good idea to add to the docs once you have a list.
I am not personally sure of the kml links are “WMS” or not
Note there are community extensions which let you extract parameters from the path (making more variations). And the workspace and layer variations provide a wide range of URL paths.
Jody
On Sat, Nov 25, 2023 at 5:38 PM Madhu via Geoserver-users <geoserver-users@lists.sourceforge.net> wrote:
Hi Team,
[Query]
Thanks & Regards,
Madhu
The contents of this e-mail and any attachment(s) are confidential and intended for the named recipient(s) only. It shall not attach any liability on the originator or NEC Corporation India Private Limited or its affiliates. Any views or opinions presented in this email are solely those of the author and may not necessarily reflect the opinions of NEC Corporation India Private Limited or its affiliates. Any form of reproduction, dissemination, copying, disclosure, modification, distribution and / or publication of this message without the prior written consent of the author of this e-mail is strictly prohibited. If you have received this email in error please delete it and notify the sender immediately.
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
