I’m calling a geoserver 2.2 with a the following filter over wfs:
<ogc:Filter xmlns:ogc=“http://www.opengis.net/ogc”>
ogc:And
ogc:DWithin
ogc:PropertyNameGeometri</ogc:PropertyName>
<gml:Point xmlns:gml=“http://www.opengis.net/gml” srsName=“EPSG:900913”>
gml:pos2006635.412538 8263825.7559183</gml:pos>
</gml:Point>
<ogc:Distance units=“m”>50</ogc:Distance>
</ogc:DWithin>
<ogc:PropertyIsLike wildCard="" singleChar=“.” escapeChar=“!”>
ogc:PropertyNameInnehavare</ogc:PropertyName>
ogc:Literalic</ogc:Literal>
</ogc:PropertyIsLike>
</ogc:And>
</ogc:Filter>
Within 50m are 3 features, two of them with Innehavare = ica and one with another name.
When I execute the query I get 0 features in the result.
If I set the Like filters literal to * all three features are returned.
I checked the log and saw that this is the sql that is executed:
SELECT * FROM (SELECT “Id”,“Innehavare”,“NuvarandeTillstaand”,“Publicerad”,“Adress”,“Postnummer”,“Ort”,“Vaaningsplan”,“Placering”,“Kommun”,“Laen”,“OevrigInfo”,“Geometri”.STAsBinary() as “Geometri”, ROW_NUMBER() OVER (ORDER BY CURRENT_TIMESTAMP) AS _GT_ROW_NUMBER FROM “HjaertstartarPositionsVy” WHERE (“Geometri”.Filter(geometry::STGeomFromText(‘POINT (2006637.8011951 8263826.9502469)’, 900913)) = 1 AND “Geometri”.STDistance(geometry::STGeomFromText(‘POINT (2006637.8011951 8263826.9502469)’, 900913))<50.0 AND “Innehavare” LIKE ‘ica%’ )) AS _GT_PAGING_SUBQUERY WHERE _GT_ROW_NUMBER <= 1000000
and after a while I figured out that I could get it to work correctly if I removed
so that the query is:
SELECT * FROM (SELECT “Id”,“Innehavare”,“NuvarandeTillstaand”,“Publicerad”,“Adress”,“Postnummer”,“Ort”,“Vaaningsplan”,“Placering”,“Kommun”,“Laen”,“OevrigInfo”,“Geometri”.STAsBinary() as “Geometri”, ROW_NUMBER() OVER (ORDER BY CURRENT_TIMESTAMP) AS _GT_ROW_NUMBER FROM “HjaertstartarPositionsVy” WHERE (“Geometri”.STDistance(geometry::STGeomFromText(‘POINT (2006637.8011951 8263826.9502469)’, 900913))<50.0 AND “Innehavare” LIKE ‘ica%’ )) AS _GT_PAGING_SUBQUERY WHERE _GT_ROW_NUMBER <= 1000000
So, basicly why does the DWitin create a Geometry.Filter()? And how can I stop it from doing so?
Thank you for your time.
Best Regards
Lukas
Lukas Bergliden
Civilingenjör
Mobil 070 644 96 61 Electrum 234, 164 40 Kista
Direkt 08 630 75 09 Kistagången 16, 7 tr
