hi,
I want to query on my postgis raster map.
I need to know:
Can parametric SQL View be used for postgis raster map in geoserver?
how can I query postgis raster map with the dynamic request?
and
Is it possible to build filtering on postgis-raster ?
I will appreciate if you answer my question.
regards
Ahmet Temiz
Jeoloji Müh.
Afet ve Acil Durum Yönetimi Başkanlığı
Bilgi İşlem Dairesi Başkanlığı-CBS Grubu
Ahmet Temiz
Geological Eng.
Information Systems - GIS Group
Disaster and Emergency Management
of Presidency
Hi
If you are using the imagemosaic-jdbc module this is not possible.
On Fri, Jul 22, 2016 at 4:17 PM, Ahmet Temiz <ahmettemiz88@anonymised.com> wrote:
hi,
I need to know:
and
regards
Ahmet Temiz
Jeoloji Müh.
Ahmet Temiz
Geological Eng.
of Presidency
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity planning
reports.http://sdm.link/zohodev2dev
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
