I took your SLD and edited it in a few places to suit for the “tasmania_cities” layer:
se:Nametasmania_cities</se:Name>
ogc:PropertyNameADMIN_NAME</ogc:PropertyName>
ogc:LiteralTasmania</ogc:Literal>
</ogc:PropertyIsEqualTo>
</ogc:Filter>
I places some small png into my data_dir/styles named as and attached the new style to Tasmania_cities and it works for me. Unfortunately I have no idea why it fails for you.
I am using Geoserver 2.6.
-Jukka-
Deeb Haddad
Here is a test SLD
Best regards,
Deeb N. Haddad |System Support Engineer
International Relief & Development (Regional Office)
22 Sumaya Bent Al Hasan St | PO Box 852795 | Amman 11185 Jordan
T: 962 6 5857756 | F: 962 6 5857751 | M: +962790218658
From: Rahkonen Jukka (Tike) [mailto:jukka.rahkonen@…486…]
Sent: Wednesday, October 01, 2014 12:08 PM
To: ‘Deeb Haddad’; ‘Geoserver-users@lists.sourceforge.net’
Subject: Re: [Geoserver-users] Question: Graphic symbology in GeoServer/External Graphics
Did you try to edit the burg.sld as I suggested with your symbol saved into data_dir/styles? If you can change your png file into it you’d know that it is possible. Next you can try if it can be read from your icon directory.
I do not understand what you mean with:
Although when I use http://server-name:8080/geo GEOSERVER_DATA_DIR/styles /… it validates OK, but the link gives nothing
Could you share your whole SLD?
-Jukka Rahkonen-
Deeb Haddad wrote:
Well Thanks Andrea, I have tried your suggestion
But I suspect that its permission issue, although I had given full permission to that but no result.
Still giving same exception
Best regards,
From: andrea.aime@…84… [mailto:andrea.aime@…84…] On Behalf Of Andrea Aime
Sent: Wednesday, October 01, 2014 11:41 AM
To: Deeb Haddad
Cc: Rahkonen Jukka (Tike); GeoServer Mailing List List
On Wed, Oct 1, 2014 at 11:28 AM, Deeb Haddad <dhaddad@…6701…> wrote:
Thanks Rahkonen
Well I have tried to do that earlier, the thing it keeps giving me same error:
Parsing failed for ExternalGraphic: java.lang.IllegalArgumentException: URI is not absolute
Are you using SLD 1.1? It’s not working as good as the SLD 1.0, which is instead well supported.
Before rewriting your styles to SLD 1.0, or trying to make a bug fix for the SLD 1.1 parser, I’d make a last try using “file://./icon/cluster.png”
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
