Hi Ouke,
If I understand your question correctly, you would like to add a label to the start and end of the line that bounds a polygon. There is a geometric filter function to extract the start and end points of a line, e.g.:
the_geom
More info to be found here:
http://docs.geoserver.org/latest/en/user/styling/sld-extensions/geometry-transformations.html#start-and-end-point
Also, you indicated that the label should follow the direction of this line. For this, another geometric filter function is required, e.g.
<PointPlacement>
<Rotation>
<ogc:Function name=“startAngle”>
ogc:PropertyNamethe_geom</ogc:PropertyName>
</ogc:Function>
</Rotation>
</PointPlacement>
Hope that helps
Kind regards,
Edward
Date: Fri, 20 Sep 2013 02:31:37 -0700
To: geoserver-users@anonymised.comge.net
Subject: [Geoserver-users] question placing labels
I would like at the start of a polygon to insert a label, and at the end of
the polygon. how can I fix this in geoserver. up to now the geoserver places
it on any position above or below the polygon. by the way the labels are
different and they must be in the direction of the polygon.
View this message in context: http://osgeo-org.1560.x6.nabble.com/question-placing-labels-tp5078826.html
LIMITED TIME SALE - Full Year of Microsoft Training For Just $49.99!
1,500+ hours of tutorials including VisualStudio 2012, Windows 8, SharePoint
2013, SQL 2012, MVC 4, more. BEST VALUE: New Multi-Library Power Pack includes
Mobile, Cloud, Java, and UX Design. Lowest price ever! Ends 9/20/13.
http://pubads.g.doubleclick.net/gampad/clk?id=58041151&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Geoserver-users@anonymised.comge.net
