[Geoserver-users] Question Regarding LayerGroups
Hi list,
I've realized that when viewing or consulting a layer group it's necessary to have the workspace prefix in the requests.. Can anyone confirm that this is mandatory? Is there any way to avoid specifying the workspace?
Thanks.
Agur bero bat,
David Alda Fernández de Lezea
Área de Sistemas de Información Geográfica, Planificación Territorial y Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren Arloa.
dalda@anonymised.com | www.hazi.eus
T 945 003 240 - M 627 923 170 - F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
********************* LEGE OHARRA ******************* AVISOLEGAL ******************* DISCLAIMER *****************************
Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
Este mensaje es personal y confidencial y su uso no autorizado está prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo, sin reenviarlo ni conservarlo.
This message is personal and confidential, unauthorised use is legally prohibited. If you are not the intended recipient, delete it without resending or backing it.
On Wed, Feb 3, 2016 at 8:36 AM, David Alda Fernandez de Lezea <
dalda@anonymised.com> wrote:
Hi list,
As far as I can tell, GeoServer will search an un-qualified name only as
global layer group.
You can set it up as a global group instead of as a workspace specific one.
Or are you hitting a workspace specific service? It's not clear by your
mail.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Andrea,
I finally decided to leave them as global as you said. Now it works.
Thanks.
Agur bero bat,
dalda@...6818... | www.hazi.eus
T 945 003 240 – M 627 923 170 – F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
De: andrea.aime@...84... [mailto:andrea.aime@…84…] En nombre de Andrea Aime
Enviado el: viernes, 05 de febrero de 2016 8:27
Para: David Alda Fernandez de Lezea
CC: GeoServer Users
Asunto: Re: [Geoserver-users] Question Regarding LayerGroups
On Wed, Feb 3, 2016 at 8:36 AM, David Alda Fernandez de Lezea <dalda@...6818...> wrote:
Hi list,
As far as I can tell, GeoServer will search an un-qualified name only as global layer group.
Or are you hitting a workspace specific service? It's not clear by your mail.
Ing. Andrea Aime
@geowolf
Technical Lead
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
