[Geoserver-users] R: [Geoserver-devel] geoserver-wcs: connection parameters are invalid error for every CoverageStore
I had to reinstall my pc. As soon as I can I'll try your suggestion and keep you informed.
Thank you,
Fabio
-----Messaggio originale-----
Da: Alexander Petkov [mailto:greenkov@anonymised.com]
Inviato: mercoledì 18 ottobre 2006 17.24
A: Fabio Da Soghe
Cc: Geoserver-devel; geoserver-users@lists.sourceforge.net
Oggetto: Re: [Geoserver-users] [Geoserver-devel] geoserver-wcs: connection parameters are invalid error for every CoverageStore
Hello Fabio:
Can you try adding a (backward/forward, I am not 100% sure) slash at the end of your path?
Like in:
<context-param>
    <param-name>GEOSERVER_DATA_DIR</param-name>
      <param-value>D:\datastore\geoserver\wcs-data-dir\</param-value>
</context-param>
Alex
On 10/18/06, Fabio Da Soghe <fabio.dasoghe@anonymised.com> wrote:
I thought the path separator was handled transparently by the JVM.
Anyway I tried as you suggested but nothing changed :frowning:
Thanks for your interest.
Fabio
Saul Farber ha scritto:
Fabio,
You might try that path with forward-slashes (i.e.:
"D:/datastore/geoserver/wcs-data-dir"
Java tends to like those better than backslashes, and your error
messages look like geoserver isn't finding your GEOSERVER_DATA_DIR.
--saul
Fabio Da Soghe wrote:
Yes. I added this to the web.xml:
<context-param>
<param-value>D:\datastore\geoserver\wcs-data-dir</param-value>
</context-param>
--- Using Tomcat but need to do more? Need to support web services,
security?
Get stuff done quickly with pre-integrated technology to make your job
easier Download IBM WebSphere Application Server v.1.0.1 based on
Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=1216
42
Geoserver-users mailing list
