Thanks, i solve the problem…
My mistake is the path where i have put the file smiley…
Now i set the correct path and all work perfectly…
Thanks
GBZ
Inviato: martedì 10 dicembre 2013 13:40
On Mon, Dec 9, 2013 at 3:20 PM, gzaccagnino <[hidden email]> wrote:
Thank you, for the fantastic geoserver.
I’m try the example
with the normal point, all works fine, with the triangle, all works fine.
when i try with the example above, qgis, collegated via wms don’t show
nothing.
the question is where i have to put the file smileyface.png?
is a way to set a path un my pc?
I 'm using windows7, xampp (tomcat e Apache), and i have installed
geoserver, last version.
when i use the style, point as graphics, with a shape file of point, don’t
show the smiley…
with normal point graphics show the point rightly…
where’s my mistake?
The smileyface.png file should be placed in the styles folder of the Geoserver
data directory, that is, in the same place as the SLD file, in order to work.
Otherwise, you can also use an absolute path to the file, or a reference to a
resource served by an HTTP server (e.g., http://maps.google.com/mapfiles/kml/shapes/airports.png)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Sponsored by Intel(R) XDK
Develop, test and display web and hybrid apps with a single code base.
Download it for free now!
http://pubads.g.doubleclick.net/gampad/clk?id=111408631&iu=/4140/ostg.clktrk
Geoserver-users mailing list
[hidden email]
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Point-as-Graphic-tp5093328p5093517.html
To unsubscribe from Point as Graphic, click here.
NAML
