Done: it's issue number GEOS-831. I marked it to belong to the Configuration component, I hope it was right.
Thank you and good work,
Fabio
-----Messaggio originale-----
Da: geoserver-users-bounces@lists.sourceforge.net
[mailto:geoserver-users-bounces@lists.sourceforge.net] Per
conto di Brent Owens
Inviato: giovedì 4 gennaio 2007 17.57
A: Fabio Da Soghe
Cc: 'geoserver-users@lists.sourceforge.net'
Oggetto: Re: [Geoserver-users] Problem with custom schema.xml
(geoserver 1.4.0)The issue you have found is related to the existing one, but
a little different and needs to be addressed separately. So
yeh go ahead and file a bug report.
Thanks for finding the issue Fabio!Brent Owens
(The Open Planning Project)Fabio Da Soghe wrote:
> Hello list.
> It appears to me a problem with geoserver 1.4.0 stable,
regarding configuring FeatureType with custom schema.xml file.
> I follow the procedure explained in the documentation, in
page "Geoserver config files": I have a PostGIS table in my
datastore, I don't create the FeatureType with the web admin
but create a directory with the proper name in the data
directory, then put into it the info.xml and schema.xml files
(handwritten), with a custom GML Schema. Then I open
Geoserver's web admin and hit "Load". All works fine: it
loads the new configuration, I can see the new feature type
and the WFS DescribeFeatureType request returns the right
schema. I tested the WMS and WFS interfaces on these datas
and all works perfectly, so I'm confident my info.xml and
schema.xml files are correct.
> Then I use the web admin to edit another already existent
feature type (I change a trivial parameter, like the bounding
box), hit "Apply", then "Save". Geoserver takes the new
parameter correctly, but my custom schema.xml file is
rewritten. If I repeat the DescribeFeatureType request I
still get the correct result, but only because Geoserver has
it in some cache: if I hit "Load" or restart Tomcat, the
response gets corrupted.
> I searched through the issue tracker and found something
related, particularly
http://jira.codehaus.org/browse/GEOS-510 which is still open,
but it's related to the web admin itself, not a custom
schema.xml file.
> Have I to fill a bug report for this or is it a duplicate
(in which case I apologize: I searched extensively through
Jira but I was unable to find it)?
> Thank you for any feedback.
> Cheers,
> Fabio
> --- Take Surveys. Earn Cash. Influence the Future of IT Join
> SourceForge.net's Techsay panel and you'll get the chance to share
> your opinions on IT & business topics through brief surveys
- and earn
> cash
http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEV
> DEV _______________________________________________
> Geoserver-users mailing list
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
share your opinions on IT & business topics through brief
surveys - and earn cash
&CID=DEVDEV
