[Geoserver-users] R: R: Problem with Geoserver 1.5.0 RC1 and geotiff
Wow, great! You’re right!!
Well, then I think there is a little defect in the Create CoverageStore form: when I create a new CoverageStore, it fills the URL field with the default value “file:data/coverages/”, which for the default installation is wrong (if this is the case, I’ll create a Jira issue if you think it’s appropriate).
Thank you for your support!!
Fabio
Da: Alessio Fabiani [mailto:alessio.fabiani@anonymised.com]
Inviato: lunedì 19 febbraio 2007 12.28
A: Fabio Da Soghe
Oggetto: Re: [Geoserver-users] R: Problem with Geoserver 1.5.0 RC1 and geotiff
No, it should be
file:coverages/settimoprg/cascinanuova2.tif
I think … it depends on your GEOSERVER_DATA_DIR root, if the latter is setted to /root/webapps/geoserver-1.5.0-RC1/data then the path to the image is file:coverages/…
Otherwise, use a full path, like this:
file:/ root/webapps/geoserver-1.5.0-RC1/data/coverages/settimoprg/cascinanuova2.tif
On 2/19/07, Fabio Da Soghe <fabio.dasoghe@anonymised.com> wrote:
The path inserted during the CoverageStore creation is this:
file:data/coverages/settimoprg/cascinanuova2.tif
and it exists in the geoserver installation directory (obtained from the war file extracted by tomcat itself); I have this directory in my file system:
/root/webapps/geoserver-1.5.0-RC1/data/coverages/settimoprg
I think this is right… right?
Fabio
PS: thank you for your blazing fast replay!
Inviato: lunedì 19 febbraio 2007 12.10
A: Fabio Da Soghe
Oggetto: Re: [Geoserver-users] Problem with Geoserver 1.5.0 RC1 and geotiff
It seems like the CoverageStore is not able to find the file … maybe the path specified is wrong?
On 2/19/07, Fabio Da Soghe < fabio.dasoghe@anonymised.com> wrote:
Hello list.
I’m doing some test with Geoserver 1.5.0 RC1 and I’m not able to create a coverage, following the tutorial at:
http://docs.codehaus.org/display/GEOSDOC/User+Tutorial+Coverage
I follow all the steps, using the geotiff sample file; I create the CoverageStore, but when I create the Coverage from it I get this error on the web page:
GeoServer - Exception
The following exception was thrown:
java.lang.IllegalArgumentException: No input stream for the provided source
From the tomcat log I read this:
19-feb-2007 11.56.56 org.vfny.geoserver.global.CoverageStoreInfo getReader
GRAVE: No input stream for the provided source
at org.geotools.gce.geotiff.GeoTiffReader.(GeoTiffReader.java:193)
at org.geotools.gce.geotiff.GeoTiffFormat.getReader (GeoTiffFormat.java:252)
at org.geotools.gce.geotiff.GeoTiffFormat.getReader(GeoTiffFormat.java:212)
at org.vfny.geoserver.global.CoverageStoreInfo.getReader(CoverageStoreInfo.java:380)
at org.vfny.geoserver.action.data.DataCoveragesNewAction.execute(DataCoveragesNewAction.java:94)
at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:102)
at org.apache.struts.action.RequestProcessor.processActionPerform (RequestProcessor.java:431)
I’m using Linux Fedora Core 4, Sun Jdk 1.5.0_06, Tomcat 5.5, jai-1_1_4-pre-dr-b03-lib-linux-i586-16_Oct_2006.zip and jai_imageio-1_1-beta-lib-linux-i586-jar.zip.
Maybe I have to update my JAI native libraries?
Thank you,
Fabio Da Soghe
Join SourceForge.net’s Techsay panel and you’ll get the chance to share your
opinions on IT & business topics through brief surveys-and earn cash
Geoserver-users mailing list
Eng. Alessio Fabiani
Vice President/CTO GeoSolutions
Geoserver-users@anonymised.comists.sourceforge.net
Yes please, a Jira will be useful.
Thanks.
Fabio
Da: Alessio Fabiani [mailto:alessio.fabiani@anonymised.com…]
A: Fabio Da Soghe
No, it should be
Fabio
A: Fabio Da Soghe
Cc: geoserver-users@anonymised.comrceforge.net
Hello list.
Thank you,
Fabio Da Soghe
Did we get a JIRA for this? This is a pretty critical mistake, I'd like to be sure it's fixed for RC2.
Chris
Thanks.
On 2/19/07, *Fabio Da Soghe* <fabio.dasoghe@anonymised.com <mailto:fabio.dasoghe@anonymised.com> > wrote:
    Wow, great! You're right!!
    URL field with the default value "file:data/coverages/", which for
    the default installation is wrong (if this is the case, I'll create
    a Jira issue if you think it's appropriate).
         Fabio
        *Da:* Alessio Fabiani [mailto:alessio.fabiani@anonymised.com
        <mailto:alessio.fabiani@anonymised.com>]
        *Inviato:* lunedì 19 febbraio 2007 12.28
        *A:* Fabio Da Soghe
        *Cc:* geoserver-users@lists.sourceforge.net
        <mailto:geoserver-users@lists.sourceforge.net>
        *Oggetto:* Re: [Geoserver-users] R: Problem with Geoserver 1.5.0
        RC1 and geotiff
        No, it should be
        I think ... it depends on your GEOSERVER_DATA_DIR root, if the
        the path to the image is file:coverages/...
        file:/
                         I think this is right... right?
                         Fabio
                * Inviato:* lunedì 19 febbraio 2007 12.10
                *A:* Fabio Da Soghe
                *Oggetto:* Re: [Geoserver-users] Problem with Geoserver
                file ... maybe the path specified is wrong?
                On 2/19/07, *Fabio Da Soghe* < fabio.dasoghe@anonymised.com
                    Hello list.
                    I'm doing some test with Geoserver 1.5.0 RC1 and I'm
                    tutorial at:
                    <http://docs.codehaus.org/display/GEOSDOC/User+Tutorial+Coverage&gt;
                     >From the tomcat log I read this:
                            at
                    org.geotools.gce.geotiff.GeoTiffReader.<init>(GeoTiffReader.java:193)
                            at
                            at
                            at
                            at
                            at
                            at
                    I'm using Linux Fedora Core 4, Sun Jdk 1.5.0_06,
                    Tomcat 5.5,
                    Thank you,
                    Fabio Da Soghe
                    Join SourceForge.net's Techsay panel and you'll get
                    <http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV&gt;
                    <mailto:Geoserver-users@lists.sourceforge.net>
            Join SourceForge.net's Techsay panel and you'll get the
            earn cash
            <https://lists.sourceforge.net/lists/listinfo/geoserver-users&gt;
    Join SourceForge.net's Techsay panel and you'll get the chance to
    share your
--------------------------------------------------------- !DSPAM:1003,45d98f5d232887785049143!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
yeh there is a jira for it to be fixed for next release.
Brent Owens
(The Open Planning Project)
Chris
Thanks.
         Fabio
        *A:* Fabio Da Soghe
        RC1 and geotiff
        No, it should be
        file:/
                         Fabio
                *A:* Fabio Da Soghe
                    Hello list.
                    tutorial at:
                            at
                            at
                            at
                            at
                            at
                            at
                            at
                    Tomcat 5.5,
                    Thank you,
                    Fabio Da Soghe
            earn cash
    share your
