-----Messaggio originale-----
Da: Andrea Aime [mailto:aaime@anonymised.com]
Inviato: lunedì 19 febbraio 2007 16.03
A: Fabio Da Soghe
Cc: 'geoserver-users@lists.sourceforge.net'; Alessio Fabiani
Oggetto: Re: [Geoserver-users] R: Problems with EPSG lookupFabio Da Soghe ha scritto:
> I understand, thank you for the explanation.
> That means I'm in a situation I don't know how to handle
properly. I
> have a tiff raster with a tfw file attached. The tfw, as
you probably
> know, hasn't CRS information, only information about the raster's
> position. So I thought I had to force a CRS because
Geoserver hasn't a
> secure way to guess it. Infact my raster is in EPSG:3003 CRS.> Since Geoserver keeps forcing 4326 as CRS (pressing the lookup
> button), I think it is processing the raster in that CRS, as you
> stated, even if I force my correct SRID. Is it right?Glab, I think it's right, maybe Alessio can confirm (I know
the reasoning works fine on the vector side, not sure about
the coverage one).
If your data has no CRS the coverage plugin should not report
4326. Guys, are we facing a bug? Image + tfw are still
painfully common around.> If that is the case, I think it cannot process well my raster and
> infact I'm not able to get it displayed properly (it shows a white
> png, when I call it from the WMS interface).
> Have I to georeference my raster in WGS84 to go well? Or
maybe using
> geotiff (which, if I'm not wrong, does contain CRS information)?Using a Geotiff will work, for sure.
Eheh, I was just posting a little update: I tried a geotiff (WGS84) and it worked perfectly.
Another little note: the first time I tried the 3003 raster (forcing the SRID), I opened the web publishing interface embedded in Geoserver (MapBuilder) and it showed a popup saying "unsupported map projection: EPSG:3003", and the map was white empty.
Now I'll try to convert that raster in 4326 and I'll keep you informed.
Thanks again,
Fabio
