[Geoserver-users] R: R: R: Problems with EPSG lookup
-----Messaggio originale-----
Da: geoserver-users-bounces@lists.sourceforge.net
[mailto:geoserver-users-bounces@lists.sourceforge.net] Per
conto di Andrea Aime
Inviato: lunedì 19 febbraio 2007 16.25
A: Fabio Da Soghe
Cc: Brent Owens; 'geoserver-users@lists.sourceforge.net'
Oggetto: Re: [Geoserver-users] R: R: Problems with EPSG lookup
Fabio Da Soghe ha scritto:
> Eheh, I was just posting a little update: I tried a geotiff (WGS84)
> and it worked perfectly.
> Another little note: the first time I tried the 3003 raster
(forcing
> the SRID), I opened the web publishing interface embedded
in Geoserver
> (MapBuilder) and it showed a popup saying "unsupported map
> projection: EPSG:3003", and the map was white empty.
This is MapBuilder, not geoserver. MapBuilder tries to show
you the lat/lon of your mouse pointer independent of the
projection you chose, so it has to reproject the coordinates
from the native CRS to 4326. It does this in javascript code,
and supports a limited set of projections. 3003 is not among them.
My mispelling: that was what I meant. I was only reporting that, not assuming a bug in Geoserver.
Anyway, I did some other digging around the tif+tfw case. In the wms capabilities document I found:
  <Layer queryable="0">
  <Name>ddm:cascinanuova2</Name>
  <Title>cascinanuova2 is a A raster file accompanied by a spatial data file</Title>
  <Abstract>Generated from SettimoPrg</Abstract>
  <KeywordList>
    <Keyword>WCS</Keyword>
    <Keyword>SettimoPrg</Keyword>
    <Keyword>cascinanuova2</Keyword>
  </KeywordList>
  <!--WKT definition of this CRS:
GEOGCS["WGS 84",
DATUM["World Geodetic System 1984",
SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
UNIT["degree", 0.017453292519943295],
AXIS["Geodetic longitude", EAST],
AXIS["Geodetic latitude", NORTH],
AUTHORITY["EPSG","4326"]]-->
  <SRS>EPSG:3003</SRS>
  <LatLonBoundingBox minx="1402796.7678433256" miny="5000064.879096299" maxx="1404032.8544883041" maxy="5000626.033560928"/>
  <BoundingBox SRS="EPSG:3003" minx="1402796.7678433256" miny="5000064.879096299" maxx="1404032.8544883041" maxy="5000626.033560928"/>
  <Style>
    <Name>raster</Name>
  </Style>
  </Layer>
It really seems it ignores my hand-input CRS and keep using 4326 for its calculation: it reports the same original coordinates in the LatLonBoundingBox, as if it should not transform it.
I wanted to try with a geotiff with EPSG:3003 coded into it, but I'm not able to find an application capable to generate it: noone knows of that CRS! Damned Murphy's Law...
I have plenty of rasters to publish, and the only way I see by now is to convert all of them to 4326. Is there any hope to have Geoserver take my tif+tfw and listen to me about the CRS?
Fabio
Brent, this keeps on confusing users, that do think Geoserver
does not support 3003 (instead of MapBuilder). Is there a way
to make MapBuilder show native coordinates instead?
Take Surveys. Earn Cash. Influence the Future of IT Join
SourceForge.net's Techsay panel and you'll get the chance to
share your opinions on IT & business topics through brief
surveys-and earn cash
http://www.techsay.com/default.php?page=join.php&p=sourceforge
&CID=DEVDEV
Geoserver-users mailing list
You can use gdal_translate and, if it does not understand EPSG:3003,
you can try with the equivalent WKT, on a single line.
Hum, I think if you provide a .prj file with the same WKT as reported
by Geoserver for 3003 it should work fine. Oh, to be sure, put the whole
WKT in a single line, not nicely formatted as in the Geoserver output.
Let me know if this helps.
Is it possible to have some sample data?
A: Fabio Da Soghe
Cc: Brent Owens; ‘geoserver-users@anonymised.comge.net
(forcing
in Geoserver
(MapBuilder) and it showed a popup saying “unsupported map
projection: EPSG:3003”, and the map was white empty.
ddm:cascinanuova2 cascinanuova2 is a A raster file accompanied by a spatial data file Generated from SettimoPrg WCS SettimoPrg cascinanuova2 EPSG:3003 raster [...]
I wanted to try with a geotiff with EPSG:3003 coded into it, but I’m not able to find an application capable to generate it: noone knows of that CRS! Damned Murphy’s Law…
Fabio
SourceForge.net 's Techsay panel and you’ll get the chance to
&CID=DEVDEV
Join SourceForge.net’s Techsay panel and you’ll get the chance to share your
opinions on IT & business topics through brief surveys-and earn cash
Eng. Alessio Fabiani
Vice President/CTO GeoSolutions
