Hi Gabriel,
I've done what you said but in the <data_dir>/logs folder I don't
have any geoserver.log
Ale
----Messaggio originale----
Da: groldan@anonymised.com
org
Data: 02/07/2009 17.30
A: "alessandro.sarretta@anonymised.com"<alessandro.
sarretta@anonymised.com>
Cc: <geoserver-users@lists.sourceforge.net>
Ogg: Re:
[Geoserver-users] Geoserver and ArcSDE 9.3
your steps seem good, just
make sure the icu4j.jar file is also copied
to the WEB-INF/lib directory and
restart.
If ArcSDE still doesn't appear like a data store option, please set
the
logging level to GEOTOOLS_DEVELOPER_LOGGING, try again and send back the
log file <data dir>/logs/geoserver.log.
Gabriel
alessandro.
sarretta@anonymised.com wrote:
I have a problem using ArcSDE extension
with Geoserver 1.7.5 (Windows
XP).
I want to connect Geoserver with an
ArcSDE 9.3 service.
I followed these
instructions [1], downloaded
geoserver-1.7.5-arcsde-plugin.zip and copied the
contained .jar files in
WEB-INF/lib directory of the GeoServer installation.
Then I tried to
obtain the external files needed. In the esri support page [2]
I was able
to download only the jpe_sdk.jar but not the jsde_sdk.jar for the
ArcSDE
9.3 version.
I used the one I found in the official installation dvd of
ArcSDE 9.3 and copied both jar files in WEB-INF/lib directory.
When I
restart
Geoserver and try to create a new Data store, I can't find the
ArcSDE option
between the other Feature Data Set Description types.
Am I
doing any mistake?
Are there any compatibility problems with 9.3 version?
Can I provide other
information to help understand the problem?
Your
help would be very much
appreciated!
Thanks
Alessandro[1]
http://docs.geoserver.org/1.7.
x/user/data/arcsde.html
[2] http://support.
esri.com/index.cfm?fa=downloads.
patchesServicePacks.listPatches&PID=66
