Hello,
I have problems diplaying raster files, both in the demo preview and when I
use it as a WMS. I see a blank (white) map, but when I click on the map I
get correct feature info.
I use Geoserver 1.7.5
Gdalinfo says:
Driver: GTiff/GeoTIFF
Files: Kbakarta8_99.tif
Size is 11934, 11927
Coordinate System is:
PROJCS["unnamed",
GEOGCS["unnamed",
DATUM["unknown",
SPHEROID["unretrievable - using WGS84",6378137,298.257223563]],
PRIMEM["Greenwich",0],
UNIT[,0.0174532925199433]],
UNIT["unknown",1]]
Origin = (141373.450000000010000,6387245.500000000000000)
Pixel Size = (3.000000000000000,-3.000000000000000)
Metadata:
AREA_OR_POINT=Area
TIFFTAG_XRESOLUTION=127
TIFFTAG_YRESOLUTION=127
TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Image Structure Metadata:
COMPRESSION=LZW
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 141373.450, 6387245.500)
Lower Left ( 141373.450, 6351464.500)
Upper Right ( 177175.450, 6387245.500)
Lower Right ( 177175.450, 6351464.500)
Center ( 159274.450, 6369355.000)
Band 1 Block=11934x512 Type=Byte, ColorInterp=Red
Band 2 Block=11934x512 Type=Byte, ColorInterp=Green
Band 3 Block=11934x512 Type=Byte, ColorInterp=Blue
What's the problem?
Thanks for help!
/Per S
View this message in context: http://www.nabble.com/Raster-display-problem-tp24358466p24358466.html
