[Geoserver-users] Raster error on certain zoom
Hello.
Im having some trouble showing a raster image on geoserver.
added the geotif, create layer, apply style.
it shows up nice. as i zoom in it continues to show but when i reach certain
zoom it gives an error.
I display it in Qgis with no problem at all.
Info about the raster, style and error below.
any help will be greatly appreciated.
*style:*
*gdalinfo:*
Error:
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoServer-User-f3786390.html
Please join the list and use a proper mail client - nabble eats the xml and other special text so we get no information to help you.
Ian
On 4 September 2017 at 09:42, Filipe <filipesilva1@anonymised.com.84…> wrote:
Hello.
style:
gdalinfo:
Error:
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
Geoserver-users@anonymised.com.382…sourceforge.net
Ian Turton
Hello.
Weird. Im on the list. Probably didnt check the html email.
sorry.
bellow, original text.
Hello.
geoserver:
windows 2008 R2
geoserver 2.11.2
tomcat 9.0.0.M21
JAVA_OPTS -Xms48m -Xmx408M
JVM - Oracle Corporation: 1.8.0_131 (Java HotSpot™ Client VM)
raster file is ~ 400mb
Style:
    raster-channels: auto;
    raster-contrast-enhancement: normalize;
    /colormap removed to simplify, but the same error./
gdalinfo:
Driver: GTiff/GeoTIFF
Files: raster.tif
raster.tif.aux.xml
Size is 11292, 15341
Coordinate System is:
PROJCS[“WGS 84 / UTM zone 29N”,
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
SPHEROID[“WGS 84”,6378137,298.257223563,
AUTHORITY[“EPSG”,“7030”]],
AUTHORITY[“EPSG”,“6326”]],
PRIMEM[“Greenwich”,0,
AUTHORITY[“EPSG”,“8901”]],
UNIT[“degree”,0.0174532925199433,
AUTHORITY[“EPSG”,“9122”]],
AUTHORITY[“EPSG”,“4326”]],
PROJECTION[“Transverse_Mercator”],
PARAMETER[“latitude_of_origin”,0],
PARAMETER[“central_meridian”,-9],
PARAMETER[“scale_factor”,0.9996],
PARAMETER[“false_easting”,500000],
PARAMETER[“false_northing”,0],
UNIT[“metre”,1,
AUTHORITY[“EPSG”,“9001”]],
AXIS[“Easting”,EAST],
AXIS[“Northing”,NORTH],
AUTHORITY[“EPSG”,“32629”]]
Origin = (625112.266270000021905,4251066.704270000569522)
Pixel Size = (0.235070000000000,-0.235070000000000)
Metadata:
AREA_OR_POINT=Area
TIFFTAG_SOFTWARE=pix4dmapper
Image Structure Metadata:
COMPRESSION=LZW
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 625112.266, 4251066.704) ( 7d34’ 2.00"W, 38d23’56.68"N)
Lower Left ( 625112.266, 4247460.495) ( 7d34’ 4.31"W, 38d21’59.71"N)
Upper Right ( 627766.677, 4251066.704) ( 7d32’12.60"W, 38d23’55.33"N)
Lower Right ( 627766.677, 4247460.495) ( 7d32’14.96"W, 38d21’58.36"N)
Center ( 626439.471, 4249263.600) ( 7d33’ 8.47"W, 38d22’57.52"N)
Band 1 Block=11292x1 Type=Float32, ColorInterp=Gray
Min=-0.613 Max=0.942
Minimum=-0.613, Maximum=0.942, Mean=0.402, StdDev=0.138
NoData Value=-10000
Metadata:
STATISTICS_MAXIMUM=0.94206058979034
STATISTICS_MEAN=0.40219365318959
STATISTICS_MINIMUM=-0.61281371116638
STATISTICS_STDDEV=0.13782531220071
Error:
2017-09-04 09:34:17,246 INFO [geoserver.wms] -
Request: getServiceInfo
2017-09-04 09:34:17,355 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Error rendering coverage on the fast path
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:363)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:278)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:141)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:623)
at org.geoserver.wms.GetMap.run(GetMap.java:279)
at org.geoserver.wms.GetMap.run(GetMap.java:125)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:320)
at sun.reflect.GeneratedMethodAccessor322.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:302)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:190)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:157)
at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:62)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:36)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:80)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:55)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:208)
at com.sun.proxy.$Proxy62.getMap(Unknown Source)
at sun.reflect.GeneratedMethodAccessor285.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:857)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:268)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:859)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:635)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:742)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:84)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:89)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:475)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:80)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:624)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:498)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:796)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1366)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Unknown Source)
Caused by: org.geoserver.platform.ServiceException: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: java.lang.NullPointerException
at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:1107)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:361)
… 125 more
Caused by: org.geotools.coverage.processing.CoverageProcessingException: org.geotools.coverage.processing.CoverageProcessingException: java.lang.NullPointerException
at org.geotools.renderer.lite.gridcoverage2d.BaseCoverageProcessingNode.getOutput(BaseCoverageProcessingNode.java:343)
at org.geotools.renderer.lite.gridcoverage2d.BaseCoverageProcessingNode.getOutput(BaseCoverageProcessingNode.java:46)
at org.geotools.renderer.lite.gridcoverage2d.StyleVisitorCoverageProcessingNodeAdapter.getOutput(StyleVisitorCoverageProcessingNodeAdapter.java:141)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.symbolize(GridCoverageRenderer.java:484)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:970)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:786)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:995)
… 126 more
Caused by: org.geotools.coverage.processing.CoverageProcessingException: java.lang.NullPointerException
at org.geotools.renderer.lite.gridcoverage2d.SubchainStyleVisitorCoverageProcessingAdapter.execute(SubchainStyleVisitorCoverageProcessingAdapter.java:116)
at org.geotools.renderer.lite.gridcoverage2d.RasterSymbolizerHelper.execute(RasterSymbolizerHelper.java:78)
at org.geotools.renderer.lite.gridcoverage2d.RasterSymbolizerHelper.execute(RasterSymbolizerHelper.java:58)
at org.geotools.renderer.lite.gridcoverage2d.StyleVisitorCoverageProcessingNodeAdapter$1.execute(StyleVisitorCoverageProcessingNodeAdapter.java:102)
at org.geotools.renderer.lite.gridcoverage2d.BaseCoverageProcessingNode.checkExecuted(BaseCoverageProcessingNode.java:238)
at org.geotools.renderer.lite.gridcoverage2d.BaseCoverageProcessingNode.getOutput(BaseCoverageProcessingNode.java:341)
… 132 more
Caused by: java.lang.NullPointerException
at javax.media.jai.PlanarImage.getData(PlanarImage.java:2110)
at javax.media.jai.StatisticsOpImage.getProperty(StatisticsOpImage.java:292)
at com.sun.media.jai.opimage.ExtremaOpImage.getProperty(ExtremaOpImage.java:100)
at javax.media.jai.RenderedOp$1.getProperty(RenderedOp.java:1808)
at javax.media.jai.PropertyEnvironment.getProperty(PropertyEnvironment.java:197)
at javax.media.jai.PropertySourceImpl.getProperty(PropertySourceImpl.java:277)
at javax.media.jai.WritablePropertySourceImpl.getProperty(WritablePropertySourceImpl.java:130)
at javax.media.jai.RenderedOp.getProperty(RenderedOp.java:1982)
at org.geotools.image.ImageWorker.getComputedProperty(ImageWorker.java:984)
at org.geotools.image.ImageWorker.getExtremas(ImageWorker.java:1038)
at org.geotools.image.ImageWorker.getMinimums(ImageWorker.java:1190)
at org.geotools.renderer.lite.gridcoverage2d.ContrastEnhancementType$4.process(ContrastEnhancementType.java:291)
at org.geotools.renderer.lite.gridcoverage2d.ContrastEnhancementNode.performContrastEnhancement(ContrastEnhancementNode.java:516)
at org.geotools.renderer.lite.gridcoverage2d.ContrastEnhancementNode.execute(ContrastEnhancementNode.java:365)
at org.geotools.renderer.lite.gridcoverage2d.ContrastEnhancementNode.execute(ContrastEnhancementNode.java:77)
… 140 more
Ian
On 4 September 2017 at 09:42, Filipe <filipesilva1@anonymised.com> wrote:
Hello.
style:
gdalinfo:
Error:
Geoserver-users@anonymised.comrge.net
Ian Turton
