what do you mean by “I believe you should have all the files that you need. The raster is loaded using the PostgreSQL JDBC connection.”
On Mon, Sep 28, 2015 at 10:35 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi David,
Are you using the image mosaic JDBC module? Like, data stored in postgis raster?
On Mon, Sep 28, 2015 at 5:30 PM, David Haynes II <dahaynes@anonymised.com> wrote:
I will send a google drive invitation to your personal e-mails. I am using geoserver 2.7
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Mon, Sep 28, 2015 at 9:45 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi David,
we likely need data, style and request to reproduce locally, in order to provide any help.
Also, which version of GeoServer are you using?
David Haynes, Ph.D.
Research Associate Terra Populus
Minnesota Population Center
www.terrapop.org
On Mon, Sep 28, 2015 at 4:31 PM, David Haynes II <dahaynes@anonymised.com> wrote:
Hello Jody,
Thanks for the reply. I seem to be encountering an issue related to raster projections and SLD visualization. I shall try to explain.
The goal is to make an application that allows the user to visualize a raster dataset by turning pixel values on and off. Currently we are working with the raster dataset GLC2000, which is the landcover classification of the world for the year 2000. We have created an SLD for this dataset that converts the raster to transparent, setting each pixel value opacity to zero. Through the application users can turn on and off raster pixel values like water. We simply update the SLD with the env parameter ‘env=lcwater:1’. Now all of the water is visible on the map.
Here is a subset of the SLD we are currently using
Title>Global Landcover Legend dynamic
…Text goes here…
The problem we are having is that the raster style (SLD) is not working at all map extents. The raster layer has the native SRS set as 4326 and the declared SRS set to 3857. SRS handling is set to project native to declared. The interpolation is set to nearest neighbor and the default SLD is glc_dynamic.
I preview the glc_dynamic raster layer through geoserver everything shows up fine, the screen is blank.I add the &env=lcwater:1 parameter and now I see water across the whole map. The only thing visible on the map is water. Preview scale is at 1:279M, rough bbox dimensions are -19144282.29W and 13927505.70963E. Now if I Pan west to -19535201.77042 the entire color legend is now visible on the map. This same error will occur if I pan to far east. If map zoom level goes out further to 1:558M. The error disappears, by some potential artifacts appear around the east and west edges of the map.
I pulled the map requests from the log file to determine what was going on. I don’t find any errors. Comparing the two files, I get differences on two lines. However these just look like differences in the bbox request. I am unable to recreate this error using the same raster data set in its native WGS84 projection or if I project it to 3857 and add it as a new data storage. However, this error does appear when I use the geoserver raster projection framework.
Request #1 (Initial View, No error)
AUTHORITY[“EPSG”,“3857”]]
Bbox = SRSEnvelope[-1.926155811957313E7 : 1.3966597672528865E7, -1.6109824066402005E7 : 4.401359194330725E7]
RemoteOwsType = null
RemoteOwsURL = null
Env = {GSUSER=auser, LCWATER=1}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation =
FeatureId = null
StartIndex = null
ViewParams = null
Transparent = true
StyleFormat = sld
SldBody = null
ValidateSchema = false
Sld = null
StyleUrl = null
TilesOrigin = null
Interpolations =
Filters = null
Exceptions = SE_XML
StyleBody = null
SldVersion = null
StyleVersion = null
ScaleMethod = null
Version = 1.1.1
Request = GetMap
Get = true
RawKvp = {TRANSPARENT=true, BBOX=-19261558.11957313,-16109824.066402005,13966597.672528865,44013591.94330725, VERSION=1.1.1, FORMAT=image/jpeg, SERVICE=WMS, HEIGHT=769, ENV=lcwater:1, REQUEST=GetMap, LAYERS=Shoumith:glc_dynamic, STYLES=Shoumith:glc_dynamic, SRS=EPSG:3857, WIDTH=425}
BaseUrl = https://localhost:8080/geoserver/
RequestCharset = UTF-8
Request #2 (Pan West, with error)
Bbox = SRSEnvelope[-1.965247759948021E7 : 1.3575678192621782E7, -1.6109824066402005E7 : 4.401359194330725E7]
RemoteOwsURL = null
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation =
FeatureId = null
StartIndex = null
ViewParams = null
Transparent = true
StyleFormat = sld
SldBody = null
Sld = null
StyleUrl = null
TilesOrigin = null
Interpolations =
Filters = null
Exceptions = SE_XML
StyleBody = null
SldVersion = null
StyleVersion = null
ScaleMethod = null
Version = 1.1.1
Request = GetMap
Get = true
RawKvp = {TRANSPARENT=true, BBOX=-19652477.59948021,-16109824.066402005,13575678.192621782,44013591.94330725, VERSION=1.1.1, FORMAT=image/jpeg, SERVICE=WMS, HEIGHT=769, ENV=lcwater:1, REQUEST=GetMap, LAYERS=Shoumith:glc_dynamic, STYLES=Shoumith:glc_dynamic, SRS=EPSG:3857, WIDTH=425}
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
On Sun, Sep 27, 2015 at 4:20 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
I am not sure I understand you question Dr. Haynes - the blog post is a new feature (rather than an error). The feature has been included in recent GeoServer releases …
For example see 2.6.0 release aouncement
David Haynes, Ph.D.
www.terrapop.org
Jody Garnett
On 25 September 2015 at 13:07, David Haynes II <dahaynes@anonymised.com> wrote:
Hello,
I recently ran into this post and I am wondering if this error will be fixed in updated versions of geoserver. http://www.geo-solutions.it/blog/developers-corner-advanced-raster-projection-geoserver/
David Haynes, Ph.D.
www.terrapop.org
David Haynes, Ph.D.
www.terrapop.org
