[Geoserver-users] Raster quality downgrade in LayerGroup
there are requests from 2011 and 2013 concerning this topic.
I'm using goeserver 2.8.1 with Java 1.8.0_65.
When serving a layer group containing 4 different ImageMosaic Store based layers, the image quality is less then requesting them as single wms-layers. Default caching is turned off.
In version 2.5.1 this effect is not existent. Can somebody help ?
Best Regards Guido Blome
Bundesstadt Bonn
Amt für Bodenmanagement und Geoinformation
Stadthaus, Berliner Platz 2, 53111 Bonn
Telefon +49(0)2 28.77 3009
Telefax +49(0)2 28.77 2618
E-Mail guido.blome@anonymised.com
Internet www.bonn.de
Bleiben Sie mit dem mehrmals in der Woche erscheinenden Newsletter 'BonnLive online' auf dem Laufenden. Informationen aus dem Rathaus, Veranstaltungstipps und aktuelle Nachrichten jetzt im Abo, kostenlos unter www.bonn.de<http://www.bonn.de>
Recyclingpapierfreundlichste Stadt Deutschlands 2010 bis 2015.
Bitte prüfen Sie, ob diese Mail wirklich ausgedruckt werden muss.
On Fri, May 6, 2016 at 12:54 PM, Blome, Guido (62-24) <guido.blome@anonymised.com..>
wrote:
I'm not aware of any work done in this area, nor what the cause could be.
Is your issue similar to https://osgeo-org.atlassian.net/browse/GEOS-6614 ?
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi Andrea,
no my issue isn`t similar to GEOS-6614, more like the related:
https://osgeo-org.atlassian.net/browse/GEOS-7005
The problem seems to appear and disappear from Version to Version, maybe caused by the default interpolation method setting ???
It seems to be the same effect like in that entrees in the users-list:
https://sourceforge.net/p/geoserver/mailman/message/27750315/
https://sourceforge.net/p/geoserver/mailman/message/30390872/
Thanks and Best regards, Guido
On Fri, May 6, 2016 at 12:54 PM, Blome, Guido (62-24) <guido.blome@…7590…> wrote:
I’m using goeserver 2.8.1 with Java 1.8.0_65.
I’m not aware of any work done in this area, nor what the cause could be.
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, May 9, 2016 at 6:45 PM, Blome, Guido (62-24) <guido.blome@anonymised.com.>
wrote:
Hi Andrea,
I honestly don't know, my company has been working in production deploys
for basically all past
versions and I did not receive reports of this particular issue...
wondering if it needs some special trigger.
What we need here is a simple reproducable case, a few small raster data
sets and a request showing the problem.
Given there seems to be no one sponsoring a fix, it's particuarly important
to at least have a very quick way
to reproduce to the developer that might be willing to crush his/her spare
time on it
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Andrea,
I will try to build up a test scenario to reproduce this issue and give a notice when its ready.
Maybe we can give some sponsoring for solving that problem.
Thank you for answering my questions
Guido Blome
On Mon, May 9, 2016 at 6:45 PM, Blome, Guido (62-24) <guido.blome@…7590…> wrote:
Hi Andrea,
I honestly don’t know, my company has been working in production deploys for basically all past
versions and I did not receive reports of this particular issue… wondering if it needs some special trigger.
What we need here is a simple reproducable case, a few small raster data sets and a request showing the problem.
Given there seems to be no one sponsoring a fix, it’s particuarly important to at least have a very quick way
to reproduce to the developer that might be willing to crush his/her spare time on it
Ing. Andrea Aime
@geowolf
Technical Lead
