Ciao John,
this should not happen unless you manulally dumped the gdal-geotiff
jar from imageio-ext yourself into GeoServer.
That file is not part the gdal extension ( I checked
I would do this, I would remove that JAR from geoserver and change
this one line in the mosaics properties:
SuggestedSPI=it.geosolutions.imageioimpl.plugins.tiff.TIFFImageReaderSpi
this would tell the mosaic to use the standard pure java TIFF reader.
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
On Tue, Nov 5, 2013 at 5:29 PM, John Callahan <john.callahan@anonymised.com> wrote:
I believe the problem is fixed but wanted to describe it to the list in case
an alternate fix would have been more appropriate.
I am serving raster data using both the ImagePyramid and ImageMosaic
plugins. Mostly GeoTiffs. I am also using the integrated GWC and for the
most part, things have been working well for the past few months using
GeoServer 2.4 RC1.
When I upgraded to 2.4.1 last week, one of my layers using ImagePyramid
(with GeoTIFFs as the data source) would not render. GWC cached images
displayed fine but once I went deeper into the imagery where cached images
didn't exist, the following error would appear:
org.geotools.data.DataSourceException: java.lang.ClassNotFoundException:
it.geosolutions.imageio.plugins.geotiff.GeoTiffImageReaderSpi
To fix it, I copied imageio-ext-gdalgeotiff-1.1.7.jar from the 2.4 RC1
installation into the 2.4.1. Apparently, this file was not included in 2.4.1
or the GDAL extension. My guess is that this one particular layer was
using the GDAL GeoTiff driver back in 2.4 RC1 but in 2.4 GeoServre was
trying to use the native (non-GDAL) GeoTiff driver. I probably could have
deleted the later and created it again. However, I didn't want to change
the layer settings if I could help it. It seems this issue may occur again
during the next upgrade. Does this make sense?
- John
John Callahan
Research Scientist
Delaware Geological Survey
University of Delaware
http://www.dgs.udel.edu
November Webinars for C, C++, Fortran Developers
Accelerate application performance with scalable programming models. Explore
techniques for threading, error checking, porting, and tuning. Get the most
from the latest Intel processors and coprocessors. See abstracts and
register
http://pubads.g.doubleclick.net/gampad/clk?id=60136231&iu=/4140/ostg.clktrk
Geoserver-users mailing list
