hi again!
I'm trying to put into the same GetMap request; the problem is that one of
the layer uses a SLD and when applying a raster file, an undefined error
raises... it doesn't happens if I use sld_layer+vectorials
It WORKS
http://mygeoserver/...&LAYERS=vectorial,sld_layer&STYLES=&SLD=http://.../sld.sld
(taking the default styles for vectorial and SLD for sld_layer)
DOESN'T WORK
http://mygeoserver/...&LAYERS=raster,sld_layer&STYLES=&SLD=http://.../sld.sld
have also tried without success applying the default raster :
http://mygeoserver/...&LAYERS=raster,sld_layer&STYLES=raster&SLD=http://.../sld.sld
http://mygeoserver/...&LAYERS=raster,sld_layer&STYLES=raster,&SLD=http://.../sld.sld
if I try raster+vectorial+sld_layer WITHOUT specifying SLD parameter it
works (but using default style, not the without the desired sld file...)
Some reason for this behaviour? missing something?
thanks!
Pere
View this message in context: http://www.nabble.com/raster%2BSLD-specified-style-not-working-in-GetMap-request-tp18010553p18010553.html
hi,
I send you below some URLs if you want to check...
I insist on sending ALL the layers in the same GetMap request because I want
to compose with the returned image a .png, .jpeg... to let user download and
create PDFs also with these images. So, if I send the requests separetely, I
get different images than have to be mixed (using PHP's GD extension); here
you have to say the percentage of opacity for each layer, and here come the
problems and the composed final image loses quality.
If the all-in-one GetMap is not possible, some workaround?
thanks!
Pere
WORKS:
http://edit3.csic.es/geoserver/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=topp:province_europe,topp:test_csvimportgispoints2&STYLES=&format=image/jpeg&bbox=-9.65,35.6,4.85,43.85&WIDTH=760&HEIGHT=380&SLD=http://edit.csic.es/fitxers/sld/pou.sld
using RASTER+SLD doesn't work:
http://edit3.csic.es/geoserver/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=topp:distcoast_iberia_150sec,topp:test_csvimportgispoints2&STYLES=&format=image/jpeg&bbox=-9.65,35.6,4.85,43.85&WIDTH=760&HEIGHT=380&SLD=http://edit.csic.es/fitxers/sld/pou.sld
pere roca wrote:
hi again!
of the layer uses a SLD and when applying a raster file, an undefined
error raises... it doesn't happens if I use sld_layer+vectorials
It WORKS
DOESN'T WORK
thanks!
Pere
View this message in context: http://www.nabble.com/raster%2BSLD-specified-style-not-working-in-GetMap-request-tp18010553p18027363.html
pere roca wrote:
hi,
I send you below some URLs if you want to check... I insist on sending ALL the layers in the same GetMap request because I want
I believe you're stumblin in some bug but we're all at a hacking event
with plenty of stuff on our hands so no one has had the time to look into this problem you're experiencing. Please wait for next week
the error log (using INFO logging level) is too big (113 lines) to post in
the forum.
Maybe the RASTER+SLd problem is solved in the last version? maybe someone
using this last version can check it for me?
thanks!
Pere
aaime wrote:
pere roca wrote:
hi,
want
and
separetely, I
here
the
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
Geoserver-users mailing list
View this message in context: http://www.nabble.com/raster%2BSLD-specified-style-not-working-in-GetMap-request-tp18010553p18156345.html
the forum. Maybe the RASTER+SLd problem is solved in the last version? maybe someone
113 lines are not such a big content, I believe you can upload up to 20kb without issues. If you need to post bigger files, you can use the
Nabble attach features (the file will be kept in the Nabble servers,
the ml will only receive a link to it).
ok, I think the interesting part is not so large.
thanks a lot,
Pere
27-jun-2008 18:23:46 org.vfny.geoserver.wms.requests.GetMapKvpReader parseStyledLayerDescriptor
INFO: request comes in “library” mode
27-jun-2008 18:23:46 org.vfny.geoserver.servlets.AbstractService sendError
INFO: Had an undefined error: null
GRAVE: Service exception occurred
org.vfny.geoserver.wms.WmsException
at org.vfny.geoserests.GetMapKvpReader.parseStyledLayerDescriptor(GetMapKvpReader.java:1221)
at org.vfny.geoserver.wms.requests.GetMapKvpReader.parseSldParam(GetMapKvpReader.java:1123)
at org.vfny.geoserver.wms.requests.GetMapKvpReader.parseLayersAndStyles(GetMapKvpReader.java:853)
at org.vfny.geoserver.wms.requests.GetMapKvpReader.parseMandatoryParameters(GetMapKvpReader.java:483)
at org.vfny.geoserver.wms.requests.GetMapKvpReader.getRequest(GetMapKvpReader.java:215)
at org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:299)
… 28 more
at org.vfny.geoserver.wms.WmsExceptionHandler.newServiceException(WmsExceptionHandler.java:65)
at org.vfny.geoserver.servlets.AbstractService.sendError(AbstractService.java:865)
at org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:308)
at org.geoserver.request.Dispatcher.dispatch(Dispatcher.java:192)
at org.geoserver.request.Dispatcher.handleRequestInternal(Dispatcher.java:52)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:103)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:202)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:199)
at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:282)
at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:744)
at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:674)
at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:866)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684)
at java.lang.Thread.run(Thread.java:595)
Caused by: java.lang.NullPointerException
at org.vfny.geoserver.wms.requests.GetMapKvpReader.findStyleOf(GetMapKvpReader.java:1448)
at org.vfny.geoserver.wms.requests.GetMapKvpReader.parseStyledLayerDescriptor(GetMapKvpReader.java:1221)
… 28 more
2008/6/27 Andrea Aime <aaime@anonymised.com>:
