Hi List,
A few generic questions.
First: What are gridsets actually for? I know how to create them (the documentation is very good for that), but I can’t figure out what they’re for.
Second: I have a number of large rasters in JPEG2000 format (up to several GB in size). GeoServer can’t access these (we’re not going to use the extension). I have FME so can do lots of processing on them if needed: What’s the best way to serve these up? I was thinking of tiling them (WMS can serve tiled data right?). But then the question becomes, which tiling system do I use? There seem to be several:
imagePyramid - http://docs.geoserver.org/stable/en/user/tutorials/imagepyramid/imagepyramid.html?highlight=tiling
JDBC - http://docs.geoserver.org/stable/en/user/tutorials/imagemosaic-jdbc/imagemosaic-jdbc_tutorial.html?highlight=tiling
imageMosaic - http://docs.geoserver.org/stable/en/user/tutorials/image_mosaic_plugin/imagemosaic.html
What are the advantages/disadvantages of each? I’m guessing some are easier to create/use and possibly faster.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
