[Geoserver-users] Rasters, Tiles, and FME
The idea is that the GetCapabilities message includes all the necessary information about the configured gridsets which are supported by the server. After that It is up to the client software or programmer to know what to do next. For example uDig knows automatically how to deal with WMS-C service once it has read the GetCapabilities. I am remembering that QGIS can do the same. With OpenLayers the developer needs to know how to make the application to use exactly the same grid system than the server. Information delivered by WMS-C, TMS and WMTS GetCapabilities is enough for that. For the Web Mercator system configuring OpenLayers is easier
http://docs.openlayers.org/library/spherical_mercator.html
Once you have created the gridset and layers are available from the service you have finished your work on the Geoserver/GWS side. Next you will need to start reading the client software documents and learning how to utilize those services.
FME seems to be able to use inner tiling http://docs.safe.com/fme/reader_writerPDF/geotiff.pdf
If you want definitely to use FME you can create the tiled tiffs with that and handle just the overviews/pyramid layers with GDAL by running gdaladdo for the images. Better alternative for Geoserver could be to use gdal_retile http://docs.geoserver.org/stable/en/user/tutorials/imagepyramid/imagepyramid.html
-Jukka Rahkonen-
Jonathan Moules wrote:
Hi Arne,
Thanks for the reply. I get what gridsets do (further clarified by your reply), I don’t understand how to use them. What other parts of GeoServer do they interact with? Or what parts of the client software? And how do you get the client software to use the same gridsets? The documentation only tells me how to create them, it doesn’t say what I should do after that.
Unfortunately FME can’t create GeoTIFFs with overviews and possibly not inner tiling too. I’m aware GDAL does but we’d prefer to use FME.
Does anyone else have any suggestions how to process the rasters?
Jonathan
On 16 December 2012 23:23, Arne Kepp <arne@anonymised.com> wrote:
If you want to have efficient caching it is crucial that clients ask for the tiles that you have already generated. Basically they need to know the grid that you are basing your tiles on (origin of the grid, size of each tile in terms geographical extent and in terms of pixel size). And you need to define this for every zoom level (because for a given resolution the tiles may not cover the full extent exactly).
The result is a set of grids, aka gridset, which all your clients need to know about and use. The most commonly used, but rarely the best, is the one Google- and Bing Maps use for Spherical Mercator.
Not the right person to ask what raster approach is the most efficient, but converting the JPEGs to GeoTIFFs with overviews and inner tiling will probably be quiet fast, even though they take up more space. Performance on that end is less important if you can use tile caching. You can have them act as one layer using imagemosaic.
-Arne
On 12/14/12 14:21 , Jonathan Moules wrote:
Hi List,
A few generic questions.
First: What are gridsets actually for? I know how to create them (the documentation is very good for that), but I can’t figure out what they’re for.
Second: I have a number of large rasters in JPEG2000 format (up to several GB in size). GeoServer can’t access these (we’re not going to use the extension). I have FME so can do lots of processing on them if needed: What’s the best way to serve these up? I was thinking of tiling them (WMS can serve tiled data right?). But then the question becomes, which tiling system do I use? There seem to be several:
imagePyramid - http://docs.geoserver.org/stable/en/user/tutorials/imagepyramid/imagepyramid.html?highlight=tiling
JDBC - http://docs.geoserver.org/stable/en/user/tutorials/imagemosaic-jdbc/imagemosaic-jdbc_tutorial.html?highlight=tiling
imageMosaic - http://docs.geoserver.org/stable/en/user/tutorials/image_mosaic_plugin/imagemosaic.html
What are the advantages/disadvantages of each? I’m guessing some are easier to create/use and possibly faster.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
LogMeIn Rescue: Anywhere, Anytime Remote support for IT. Free Trial
Remotely access PCs and mobile devices and provide instant support
Improve your efficiency, and focus on delivering more value-add services
Discover what IT Professionals Know. Rescue delivers
[http://p.sf.net/sfu/logmein_12329d2d](http://p.sf.net/sfu/logmein_12329d2d)
________________
_________________________
______
Geoserver-users mailing list
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
Hi Jukka,
Thanks for the information.
Relating to the TIFF’s, I’d still prefer to use one single tool (specifically FME) for tile/image creation. FME can create pyramids, but not as part of a GeoTIFF. So I can create separate TIFF files and tile them if necessary too (either internal tiling or regular tiling), but how do I get these into GeoServer?
Is there a resource out there which describes the different Raster serving extensions and the advantages/disadvantages of each?
Jonathan
On 19 December 2012 11:15, Rahkonen Jukka <Jukka.Rahkonen@anonymised.com> wrote:
-Jukka Rahkonen-
Hi Arne,
Jonathan
-Arne
Hi List,
Jonathan
_____
___________
______
Geoserver-users@anonymised.com.net
On Thu, Dec 20, 2012 at 12:16 PM, Jonathan Moules <jonathanmoules@…4942…> wrote:
Hi Jukka,
Here: http://demo.geo-solutions.it/share/foss4g2011/gs_steroids_sgiannec_foss4g2011.pdf
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks Andrea, this looks like a very useful document although it is looking like I’m not going to be able to do this with FME from what I can see.
Jonathan
On 20 December 2012 21:06, Andrea Aime <andrea.aime@anonymised.com7…> wrote:
On Thu, Dec 20, 2012 at 12:16 PM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Hi Jukka,
Ing. Andrea Aime
@geowolf
Technical Lead
Hi list,
Following this up, I’ve decided to go the GeoTIFF/BigTiff route with inner tiling and overviews based on Andrea’s document.But unfortunately there doesn’t seem to be any documentation on the GeoServer pages about this stuff. I’ve never used GDAL before and generally avoid the command line (there’s a reason we’re trying for GeoServer not MapServer :wink: ) so am not sure where to start.
My source input is hundreds/thousands of LZW compressed GeoTIFF tiles. These need to be mosaiced together (I can do that in FME easily enough).
But then what? Do I compress them at this point? Or inner tiling? Or Overview? Does it matter what order these things are done?
And what settings should I use? For instance Andrea’s document gives a “blocksize” of 512, but Jukka’s comments were on the order of 10,000 and the default is 256.
Is there a tutorial out there on this I’ve failed to find?
Jonathan
On 21 December 2012 14:45, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Jonathan
Hi Jukka,
Ing. Andrea Aime
@geowolf
Technical Lead
Bump Anyone?
This seems like the sort of thing that’d be well documented, but my google-fu seems to have failed me.
The closest I can get is a presentation about using the ImagePyramid plugin ( http://www.slideshare.net/geosolutions/creating-a-pyramid-with-gdal-reltile-for-serving-with-geoserver and http://geo-solutions.blogspot.ru/2009/11/preparing-pyramid-for-geoserver-with.html )
Jonathan
On 27 December 2012 13:20, Jonathan Moules <jonathanmoules@anonymised.com942…> wrote:
Hi list,
Jonathan
Jonathan
Hi Jukka,
Ing. Andrea Aime
@geowolf
Technical Lead
This might not be exactly what you want but my workflow (Under Linux) is
  1. Take the raw TIF images
  2. Add a .PRJ file for each image
  3. Add the World file for each
  4. Run gdal_translate for each file
    for file in ls *tif
    do
    gdal_translate -of GTiff -co “TILED=YES” -co “COMPRESS=DEFLATE” -co “BLOCKXSIZE=512” -co “BLOCKYSIZE=512” -a_srs “EPSG:27700” $file out/$file
    done
  5. Ran a gdaladdo for each file in ‘out’
    for file in ls *tif
    do
    gdaladdo -r average $file 1 2 4 8 16 32 64 128
    done
  6. Added them to Geoserver (2.2 RC1) using ImageMosaic
Russ
On 31 Dec 2012, at 10:44, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Bump Anyone?
Jonathan
On 27 December 2012 13:20, Jonathan Moules <jonathanmoules@anonymised.com…> wrote:
Hi list,
Jonathan
Jonathan
Hi Jukka,
Ing. Andrea Aime
@geowolf
Technical Lead
Master Visual Studio, SharePoint, SQL, ASP.NET, C# 2012, HTML5, CSS,
MVC, Windows 8 Apps, JavaScript and much more. Keep your skills current
with LearnDevNow - 3,200 step-by-step video tutorials by Microsoft
MVPs and experts. SALE $99.99 this month only – learn more at:
http://p.sf.net/sfu/learnmore_122412_______________________________________________
Ciao Jonathan,
I don't know about FME therefore I cannot comment on how to do such
things with it. I hardly believe many people on this list (as well as
on other OS oriented lists) will know it much.
This to say that most intructions you'll find will be oriented towards
OS tools like GDAL utilities rather than towards proprietary solutions
like FME.
That said, the suggestions you are looking for are inside the document
andrea suggested (here the link again http://goo.gl/TXJRS):
- slides 7-9 when do use what
- slides 10-13 how to optimize each single geotiff
- slides 17-19 how to prepare a mosaic
and so on.
If you check on the web you'll also find other docs that compare tile
sizes rather than types of compression, e.g.
http://www.fosslc.org/drupal/content/tuning-gdal-raster-performance
Simone Giannecchini
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
On Thu, Dec 27, 2012 at 2:20 PM, Jonathan Moules
Hi list,
Following this up, I've decided to go the GeoTIFF/BigTiff route with inner
tiling and overviews based on Andrea's document.
But unfortunately there doesn't seem to be any documentation on the
GeoServer pages about this stuff. I've never used GDAL before and generally
avoid the command line (there's a reason we're trying for GeoServer not
And what settings should I use? For instance Andrea's document gives a
"blocksize" of 512, but Jukka's comments were on the order of 10,000 and the
default is 256.
Is there a tutorial out there on this I've failed to find?
Jonathan
looking like I'm not going to be able to do this with FME from what I can
see.
Jonathan
Hi Jukka,
Relating to the TIFF's, I'd still prefer to use one single tool
Here:
information.
Ing. Andrea Aime
@geowolf
Technical Lead
MVPs and experts. ON SALE this month only -- learn more at:
http://p.sf.net/sfu/learnmore_122712
Ciao Jonathan,
please find my answers inline below...
Simone Giannecchini
more information.
@simogeo
Founder/Director
On Wed, Jan 2, 2013 at 2:01 PM, Jonathan Moules
Hi Simone,
I did use pages 7-9 to decide to go for BigTIFF and so 17-19 isn't
applicable as I'm not going to ImageMosaic.
While pages 10-13 are useful, its a slideshow and so lacks details which
were probably included in the spoken part of the presentation. Its the
details that I'm looking for. What tile size is best? What resampling
algorithm? What overview size/scales? Etc.
Don't get me wrong, its an excellent document, but it only provides an
overview so can't substitute for actual detailed documentation.
Your second link answers the tile-size question, but specific for MapServer
(i.e. 256).
Also, page 11 hints at "external overviews" but there's no indication as to
how to create them or use them with GeoServer. FME can create them as I'm
sure GDAL can too, but again, I don't know how to use External Overviews
with Geoserver. A search of the docs for "external overviews" finds nothing
and a google only finds that PDF.
Does anyone have more information on how to use these with GeoServer?
No worries, actually this feedback gives me some hints on how to
update the presentation :slight_smile:
That said, the considerations done for MapServer applies more or less
to GeoServer as they are more related
to how to geotiff works rather than to how MapServer or GeoServer works.
Anyway, my suggestions are as follows:
- tile size-
256 or for very large bigtiff 512 is my preferred size.
Using a tile size that is too small may result in too many seeks
operations on a side and on the other side might result into a TIFF
directory explosion.
The more tiles we have the more info we need to encode in the TIFF
Directory, which is essentially a list of offset locations that tells
us where the data is on disk.
For bigtiff where we have thousands of tiles it can be MB big.
- Resampling -
This depends on the data.
For RGB like data (orthos and the like) I would gor for higher order
interpolation to reduce aliasing (cripsy images).
For data like DEM or other data that contains real values to which you
will want to apply a color map I would for for Nearest neighbor to NOT
introduce artificial values.
In some case you might want to use bilinear of average but this
depends much on what you want to do.
- Overviews -
I usually use steps of 2, as many of them as possible although I
usually don't create overviews smaller than the tile size
- External Overviews -
This works only with pure geotiff (or bigtiff as well as the plugin is
the same). ImageMosaic does not (yet) support that.
External overviews are useful just in case you don't want to touch the
original files or in case they do not support inner overviews (which
is not the case for geotiff).
Creating external overviews can be done with gdaladdo, check this link
http://www.gdal.org/gdaladdo.html
   I'm fine with no FME specific documentation and wouldn't really expect
any, but because I can't find things in the generic documentation (i.e., any
of the above but especially external overviews), I can't necessarily
implement an optimal solution with any utility, be it FME or GDAL.
Let me know if this helps. I will try to update those slides as well
as to create some additional docs.
You might even want to contribute some doc once you get to where you
needed to go :slight_smile:
Jonathan
On 2 January 2013 11:25, Simone Giannecchini
<simone.giannecchini@anonymised.com> wrote:
Ciao Jonathan,
like FME.
and so on.
Simone Giannecchini
more information.
@simogeo
Founder/Director
http://twitter.com/geosolutions _it
> Hi list,
> inner
> generally
> These
> the
> default is 256.
> Thanks,
> Jonathan
>> can
>> see.
>> Cheers,
>> Jonathan
>>>> Hi Jukka,
>>>> but not
>>>> them if
>>>> I get
>>> Here:
>>> Cheers
>>> Andrea
>>> more
>>> information.
>>> Ing. Andrea Aime
>>> @geowolf
>>> Technical Lead
>>> GeoSolutions S.A.S.
>>> Italy
>>> http://twitter.com/geosolutions_it
> or
> error
> us,
> recording
> ______________________ _________________________
Hey Simone,
Thanks for your thorough reply. Useful!
  • Resampling:
    I’ve done some experimenting with Resampling since my email and, at least for the data I was testing, Nearest Neighbour came out best (though obviously entirely subjective). This was for a regular RGB map (Ordnance Survey MiniScale specifically). There was also a significant difference in file sizes, with Nearest Neighbour being the smallest, and Cubic being the largest (double!). I didn’t expect such a significant difference, may be worth noting somewhere.
  • External Overviews:
    Thanks, but I’d found out how to create them with GDAL. My issue is - how do I get GeoServer to use them? Does it just pick them up automatically or do I need some sort of particular directory structure?
    GDAL seems to create a single, absurdly huge file, so I guess it doesn’t compress the external overviews. Based on what I’m seeing, I’m not sure if FME can create them; I expected multiple separate files (one for each layer), but the “external overviews” are basically identical to internal overviews but minus the source data.
-Overviews:
How do you determine how many levels to create? I remember this page from years ago when last I used GeoServer: http://docs.geoserver.org/stable/en/user/tutorials/imagemosaic-jdbc/imagemosaic-jdbc_tutorial.html#how-many-pyramids-are-needed - does this carry over to GeoTIFF’s overviews?
I may be reading this wrong, but the example in the PDF has 7 layers but only really needs about 3 as after that they’re smaller than the 1:1 tiles.
Is there any point in creating pyramids with a value of 1 (as in, 1 2 4 8…) ? GDAL lets you do this but if I’m understanding this correctly, they’re entirely superfluous (I mention it because Russ’s example he generously posted starts at 1).
Tile size:
Might there be a formula for calculating optimal size?
For example, if I have a 94488157480 pixel GeoTIFF (my largest - about 2.5GB compressed), if I divide them by 512 I get
184
307 tiles = 56,488 tiles
For 256 I get:
368*614 tiles = 225,952 tiles
So if there is/was a formula, it might be easier to figure out what size to go with, or at what point you’d want to be scaling up to ImageMosaic.
Based on disk seeks etc, and some experimentation, I’d guess that a number could be contrived allowing the documentation to say:
“If you end up with > X,000 tiles, go with ImageMosiac” and “Aim for between X,000 and X0,000 tiles in a GeoTIFF”
Just a thought, would be helpful for optimisation.
Documentation:
I was considering contributing to it for this but at this point certainly don’t know enough (you may have noticed from my above questions :wink: ).
I would however suggest that this section of the help: http://docs.geoserver.org/stable/en/user/production/data.html?highlight=gdaladdo#pick-the-best-performing-coverage-formats - It would gain from the info on pages 7-9 of your PDF.
Cheers!
Jonathan
On 2 January 2013 15:03, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Ciao Jonathan,
please find my answers inline below…
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hi Simone,
I did use pages 7-9 to decide to go for BigTIFF and so 17-19 isn’t
applicable as I’m not going to ImageMosaic.
details that I’m looking for. What tile size is best? What resampling
Don’t get me wrong, its an excellent document, but it only provides an
overview so can’t substitute for actual detailed documentation.
(i.e. 256).
Also, page 11 hints at “external overviews” but there’s no indication as to
how to create them or use them with GeoServer. FME can create them as I’m
sure GDAL can too, but again, I don’t know how to use External Overviews
with Geoserver. A search of the docs for “external overviews” finds nothing
  • tile size-
  • Resampling -
  • Overviews -
    usually don’t create overviews smaller than the tile size
  • External Overviews -
    External overviews are useful just in case you don’t want to touch the
I’m fine with no FME specific documentation and wouldn’t really expect
any, but because I can’t find things in the generic documentation (i.e., any
of the above but especially external overviews), I can’t necessarily
Jonathan
Ciao Jonathan,
I don’t know about FME therefore I cannot comment on how to do such
This to say that most intructions you’ll find will be oriented towards
like FME.
  • slides 7-9 when do use what
  • slides 10-13 how to optimize each single geotiff
  • slides 17-19 how to prepare a mosaic
and so on.
If you check on the web you’ll also find other docs that compare tile
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hi list,
inner
generally
These
the
default is 256.
Jonathan
can
see.
Jonathan
<jonathanmoules@anonymised.com.> wrote:
Hi Jukka,
but not
them if
I get
Here:
more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
or
error
us,
recording
MVPs and experts. ON SALE this month only – learn more at:
About absurdly large GDAL overview file, it is so big because you ask GDAL to create it for you as uncompressed. Gdaladdo document page has an example about how to create compressed overviews.
Page: http://www.gdal.org/gdaladdo.html
Example:
gdaladdo --config COMPRESS_OVERVIEW JPEG --config PHOTOMETRIC_OVERVIEW YCBCR
         --config INTERLEAVE_OVERVIEW PIXEL rgb_dataset.ext 2 4 8 16
That's good for aerial images. For Ordnance Survey rasters I guess --config COMPRESS_OVERVIEW DEFLATE would suit best.
About number of levels, if your original has 160000 pixels start dividing it by 2:
80000, 40000, 20000, 10000, 5000, 2500, 1250, 625, 312, 156 STOP
Thus, create 10 (or 9) overview levels starting as 2 4 8...
I am not sure but I think that 1 2 4 8 ... will lead to the same result because factor 1 overview level exists and it will not be created at least as internal overviews (the original data) but you can easily test it yourself. Anyway, factor 1 overview does not make sense so you can safely start from 2 just as you were thinking.
-Jukka Rahkonen-
Lähettäjä: Jonathan Moules [jonathanmoules@anonymised.com]
Lähetetty: 2. tammikuuta 2013 18:12
Vastaanottaja: Simone Giannecchini
Kopio: geoserver-users@lists.sourceforge.net
Aihe: Re: [Geoserver-users] Rasters, Tiles, and FME
Hey Simone,
- Resampling:
I've done some experimenting with Resampling since my email and, at least for the data I was testing, Nearest Neighbour came out best (though obviously entirely subjective). This was for a regular RGB map (Ordnance Survey MiniScale specifically). There was also a significant difference in file sizes, with Nearest Neighbour being the smallest, and Cubic being the largest (double!). I didn't expect such a significant difference, may be worth noting somewhere.
- External Overviews:
Thanks, but I'd found out how to create them with GDAL. My issue is - how do I get GeoServer to use them? Does it just pick them up automatically or do I need some sort of particular directory structure?
GDAL seems to create a single, absurdly huge file, so I guess it doesn't compress the external overviews. Based on what I'm seeing, I'm not sure if FME can create them; I expected multiple separate files (one for each layer), but the "external overviews" are basically identical to internal overviews but minus the source data.
-Overviews:
How do you determine how many levels to create? I remember this page from years ago when last I used GeoServer: http://docs.geoserver.org/stable/en/user/tutorials/imagemosaic-jdbc/imagemosaic-jdbc_tutorial.html#how-many-pyramids-are-needed - does this carry over to GeoTIFF's overviews?
I may be reading this wrong, but the example in the PDF has 7 layers but only really needs about 3 as after that they're smaller than the 1:1 tiles.
Is there any point in creating pyramids with a value of 1 (as in, 1 2 4 8...) ? GDAL lets you do this but if I'm understanding this correctly, they're entirely superfluous (I mention it because Russ's example he generously posted starts at 1).
Tile size:
For example, if I have a 94488*157480 pixel GeoTIFF (my largest - about 2.5GB compressed), if I divide them by 512 I get
184*307 tiles = 56,488 tiles
For 256 I get:
So if there is/was a formula, it might be easier to figure out what size to go with, or at what point you'd want to be scaling up to ImageMosaic.
Based on disk seeks etc, and some experimentation, I'd guess that a number could be contrived allowing the documentation to say:
"If you end up with > X,000 tiles, go with ImageMosiac" and "Aim for between X,000 and X0,000 tiles in a GeoTIFF"
Documentation:
I was considering contributing to it for this but at this point certainly don't know enough (you may have noticed from my above questions :wink: ).
Cheers!
Jonathan
On 2 January 2013 15:03, Simone Giannecchini <simone.giannecchini@anonymised.com.<mailto:simone.giannecchini@anonymised.com>> wrote:
Ciao Jonathan,
Simone Giannecchini
more information.
@simogeo
Founder/Director
<jonathanmoules@anonymised.com<mailto:jonathanmoules@anonymised.com>> wrote:
Hi Simone,
(i.e. 256).
- tile size-
- Resampling -
- Overviews -
Jonathan
<simone.giannecchini@anonymised.com<mailto:simone.giannecchini@anonymised.com>> wrote:
Ciao Jonathan,
like FME.
and so on.
Simone Giannecchini
more information.
@simogeo
Founder/Director
> Hi list,
> inner
> generally
> These
> the
> default is 256.
> Thanks,
> Jonathan
>> can
>> see.
>> Cheers,
>> Jonathan
>> On 20 December 2012 21:06, Andrea Aime <andrea.aime@anonymised.com<mailto:andrea.aime@anonymised.com>>
>>>> Hi Jukka,
>>>> but not
>>>> them if
>>>> I get
>>> Here:
>>> Cheers
>>> Andrea
>>> more
>>> information.
>>> Ing. Andrea Aime
>>> @geowolf
>>> Technical Lead
>>> GeoSolutions S.A.S.
>>> Italy
> or
> error
> us,
> recording
> Master Visual Studio, SharePoint, SQL, ASP.NET<http://ASP.NET>, C# 2012, HTML5, CSS,
> _____ _________________ _________________________
> Geoserver-users@lists.sourceforge.net<mailto:Geoserver-users@anonymised.comrceforge.net>
Ciao Jonathan,
please, read my answers inline below....
Simone Giannecchini
more information.
@simogeo
Founder/Director
On Wed, Jan 2, 2013 at 5:12 PM, Jonathan Moules
Hey Simone,
- Resampling:
I belive your data comprises of raster with colormap (i.e each pixel
points to an index in a colormap rather than being a real value). In
this case the only interpolation that will retain the colormap will be
nearest neighbor. If you apply higher order interpolation (i.e
bilinear and so on) that do need to mash-up somehow adiacent values
then we need to perform a color expansion which will transform the
image from 1 band to as many band as the color model has (3 for RGB
images). Hence the image size will explode per-se.
If you are publishing single geotiff files GeoServer should use them
automcatically, if you are using ImageMosaic, currently there is no
way to use them.
-Overviews:
I had a cursory look at the formula and seems correct.
You usually do that to retile/compress/colorconvert high resolution level.
Tile size:
For 256 I get:
Well, I guess this is part of testing + experience. It may very well
depend on where the data resides (local disk, SAN, NAS) how the
filesystem has been configured, if the tiles are compressed, etc. etc.
You would need to do some testing to choose the best ones.
I believe I will update the GeoServer on steroids presentation with
some numbers for different tile sizes, compressions and so on.
Documentation:
Cheers!
Jonathan
Ciao Jonathan,
Simone Giannecchini
more information.
@simogeo
Founder/Director
> Hi Simone,
> MapServer
> (i.e. 256).
> to
> I'm
> nothing
- tile size-
- Resampling -
- Overviews -
> expect
> any
> Thanks,
> Jonathan
>> Ciao Jonathan,
>> like FME.
>> and so on.
>> Regards,
>> Simone Giannecchini
>> more information.
>> @simogeo
>> Founder/Director
>> GeoSolutions S.A.S.
>> Italy
>> > Hi list,
>> > inner
>> > generally
>> > not
>> > tiles.
>> > These
>> > a
>> > and
>> > the
>> > default is 256.
>> > Thanks,
>> > Jonathan
>> >> I
>> >> can
>> >> see.
>> >> Cheers,
>> >> Jonathan
>> >>>> Hi Jukka,
>> >>>> pyramids,
>> >>>> but not
>> >>>> them if
>> >>>> do
>> >>>> I get
>> >>> Here:
>> >>> Cheers
>> >>> Andrea
>> >>> for
>> >>> more
>> >>> information.
>> >>> Ing. Andrea Aime
>> >>> @geowolf
>> >>> Technical Lead
>> >>> GeoSolutions S.A.S.
>> >>> Italy
>> > and
>> > it,
>> > or
>> > error
>> > from
>> > us,
>> > recording
>> > current
> or
> error
> us,
> recording
Master Java SE, Java EE, Eclipse, Spring, Hibernate, JavaScript, jQuery
and much more. Keep your Java skills current with LearnJavaNow -
200+ hours of step-by-step video tutorials by Java experts.
SALE $49.99 this month only -- learn more at:
http://p.sf.net/sfu/learnmore_122612
Hi Jukka,
Thanks for the reply. DEFLATE is definitely the best compression for Ordnance Survey maps, much smaller than LZW.
For reference, a scale factor of “1” does create pyramids in an internal file (I tested it, hence my querying), and as you say, they seem to be entirely superfluous.
Jonathan
On 7 January 2013 21:03, Rahkonen Jukka <Jukka.Rahkonen@anonymised.com> wrote:
Example:
–config INTERLEAVE_OVERVIEW PIXEL rgb_dataset.ext 2 4 8 16
That’s good for aerial images. For Ordnance Survey rasters I guess --config COMPRESS_OVERVIEW DEFLATE would suit best.
Thus, create 10 (or 9) overview levels starting as 2 4 8…
I am not sure but I think that 1 2 4 8 … will lead to the same result because factor 1 overview level exists and it will not be created at least as internal overviews (the original data) but you can easily test it yourself. Anyway, factor 1 overview does not make sense so you can safely start from 2 just as you were thinking.
-Jukka Rahkonen-
Hey Simone,
  • Resampling:
-Overviews:
Tile size:
184
For 256 I get:
Documentation:
Cheers!
Jonathan
On 2 January 2013 15:03, Simone Giannecchini <simone.giannecchini@anonymised.commailto:[simone.giannecchini@anonymised.com](mailto:simone.giannecchini@anonymised.com)> wrote:
Ciao Jonathan,
Simone Giannecchini
more information.
@simogeo
Founder/Director
<jonathanmoules@anonymised.commailto:[jonathanmoules@anonymised.com](mailto:jonathanmoules@anonymised.com)> wrote:
Hi Simone,
(i.e. 256).
  • tile size-
  • Resampling -
  • Overviews -
Jonathan
<simone.giannecchini@anonymised.commailto:[simone.giannecchini@anonymised.com](mailto:simone.giannecchini@anonymised.com7...)> wrote:
Ciao Jonathan,
like FME.
and so on.
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hi list,
inner
generally
These
the
default is 256.
Jonathan
can
see.
Jonathan
On 20 December 2012 21:06, Andrea Aime <andrea.aime@anonymised.com107…mailto:[andrea.aime@...1107...](mailto:andrea.aime@anonymised.com)>
Hi Jukka,
but not
them if
I get
Here:
more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
or
error
us,
recording
Geoserver-users@lists.sourceforge.netmailto:[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
Hi Simone,
The best for resampling was “Average”, as it produced the smoothest image for the pyramids, at least with all of the Ordnance Survey products I’ve processed.
Number of Tiles:
I think some sort of guide may be useful. I appreciate the numbers used will have to change depending on the latency of disk access, but some broad over-arching numbers could be created.
For example, my largest GeoTIFF has about 56,488 inner tiles (512*512 pixels) at the root layer and subjectively at least, there’s a slight lag when serving that compared to other layers which have far fewer. It’s 2.87GB with pyramids, tiles and DEFLATEd, so still quite small.
Jonathan
On 8 January 2013 08:53, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Ciao Jonathan,
please, read my answers inline below…
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hey Simone,
  • Resampling:
way to use them.
-Overviews:
[http://docs.geoserver.org/stable/en/user/tutorials/imagemosaic-jdbc/imagemosaic-jdbc_tutorial.html#how-many-pyramids-are-needed](http://docs.geoserver.org/stable/en/user/tutorials/imagemosaic-jdbc/imagemosaic-jdbc
_tutorial.html#how-many-pyramids-are-needed)
  • does this carry over to GeoTIFF’s overviews?
Tile size:
184
For 256 I get:
Documentation:
  • It would gain from the info on pages 7-9 of your PDF.
Cheers!
Jonathan
Ciao Jonathan,
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hi Simone,
(i.e. 256).
to
I’m
nothing
  • tile size-
  • Resampling -
  • Overviews -
expect
any
Jonathan
<simone.giannecchini@…1107…> wrote:
Ciao Jonathan,
like FME.
and so on.
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hi list,
inner
generally
not
tiles.
These
a
and
the
default is 256.
Jonathan
I
can
see.
Jonathan
Hi Jukka,
pyramids,
but not
them if
do
I get
Here:
for
more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
and
it,
or
error
from
us,
recording
current
Geoserver-users@anonymised.comts.sourceforge.net
or
error
us,
recording
SALE $49.99 this month only – learn more at:
